Hello, I'd like to harvest metadata from a Geonetwork server,
filtering by Geonetwork category.
However, I don't see the option in the Geonetwork harvesting
interface. Is it possible to perform such filtering?
In case is not, would be simple to implement?
Thanks in advance,
César Martínez
César Martínez Izquierdo
GIS developer
ETC-SIA: http://sia.eionet.europa.eu/
Universitat Autònoma de Barcelona (SPAIN)
Hi César,
Using the OAIPMH harvester, you will be able to perform such filters by
specifying a "set", which correspond to GeoNetwork categories.
More information about selective harvesting using OAIPMH here :
http://www.openarchives.org/OAI/openarchivesprotocol.html#SelectiveHarvestingandSets
HTH,
Mathieu
2011/7/1 César Martínez Izquierdo <cesar.izq@anonymised.com>
Thanks in advance,
César Martínez
GIS developer
All of the data generated in your IT infrastructure is seriously valuable.
Why? It contains a definitive record of application performance, security
threats, fraudulent activity, and more. Splunk takes this data and makes
sense of it. IT sense. And common sense.
http://p.sf.net/sfu/splunk-d2d-c2
GeoNetwork-users mailing list
Thanks for your reply Mathieu,
I have been able to select the category from the OAIPMH harvesting
dialog, but I get an exception when executing the harvesting:
BadResumptionTokenException
Message: Invalid Token ////null/null
Thanks anyway for the idea.
Best regards,
César
El día 1 de julio de 2011 16:41, Mathieu Coudert
<mathieu.coudert@anonymised.com> escribió:
Hi César,
HTH,
Mathieu
Thanks in advance,
César Martínez
GIS developer
GIS developer
