[GeoNetwork-users] GN upgrade
Hi folks,
I'd like to upgrade my GeoNetowork instance from 3.0.1 to current version.
I use Tomcat 8.0.26 and PostgreSQL 9.6.1. I downloaded WAR file rename it
to geonetwork3 (to distinguish old/new version) and deploy it in Tomcat.
Just after that if i try access servername:8080/geonetwork3/
I got this error:
FileError:
'servername:8080/geonetwork3/catalog/lib/style/bootstrap-3.0.1/bootstrap.less'
wasn't found (404)
Then I've edited these files to be same as in old version of GN:
webapps/geonetwork/WEB-INF/config-db/jdbc.properties
webapps/geonetwork/WEB-INF/config-node/srv.xml
webapps/geonetwork/WEB-INF/config.xml
but after that it's not possible start GN at Tomcat at all and got this
error:
FAIL - Application at context path /geonetwork3 could not be started
I've tried to google some advice or manual how to upgrade GN but with no
useful results.
Could you please give some advice how to upgrade with no data loss?
Thanks in advance.
Adam
FileError:
wasn't found (404)
You should have a stacktrace below this message ... Actually this message
is meanless.
On Sun, Mar 12, 2017 at 6:39 PM, Adam Laža <ad.laza32@anonymised.com> wrote:
Hi folks,
I got this error:
FileError:
0.1/bootstrap.less'
wasn't found (404)
error:
useful results.
Thanks in advance.
Adam
Announcing the Oxford Dictionaries API! The API offers world-renowned
dictionary content that is easy and intuitive to access. Sign up for an
account today to start using our lexical data to power your apps and
projects. Get started today and enter our developer competition.
http://sdm.link/oxford
GeoNetwork-users mailing list
geonetwork-users List Signup and Options
GeoNetwork OpenSource is maintained at http://sourceforge.net/
projects/geonetwork
*camptocamp*
INNOVATIVE SOLUTIONS
BY OPEN SOURCE EXPERTS
*Florent Gravin*
0479444492
Hi, I would suspect the WRO4J JS & Less cache initialization not
waiting Tomcat to start completely and failing to init the cache
properly.
You could try to remove the value in
https://github.com/geonetwork/core-geonetwork/blob/develop/web/src/main/webapp/WEB-INF/config-spring-geonetwork.xml#L120
and restart.
If it works, it may be something we should improved by default.
HTH
Francois
2017-03-12 18:39 GMT+01:00 Adam Laža <ad.laza32@anonymised.com>:
Hi folks,
I got this error:
FileError:
wasn't found (404)
error:
useful results.
Thanks in advance.
Adam
I tried to comment the value as you suggested and restart but it didn't
help and I got the same error [1]. I found out that this problem occurs if
I try to run two GN instances under Tomcat. I have old version(3.0.1)
called geonetwork. It runs OK. If I deploy new version (3.2.1) war file
called geonetwork2.war in Tomcat both instances are running, old version
works fine and new one throws the error [1]. If I stop old version (which
works fine) and reload the new version I still got the error [1]. However
if I restart Tomcat, both instances are running but this time the new
version works and the old version throws the error[1].
So my question is if it's possible to run two different versions of GN at
the same time and how.
Thanks!
Adam
[1]:
Raised exception while starting the application. Fix the error and restart.
*Message*
org.apache.lucene.store.LockObtainFailedException: Lock obtain timed
out: NativeFSLock@/data/GN/data/index/taxonomy/write.lock:
java.nio.channels.OverlappingFileLockException
*Handler*
org.fao.geonet.Geonetwork
*Exception*
java.lang.RuntimeException:
*Stack*
  at org.fao.geonet.kernel.search.index.LuceneIndexLanguageTracker.lazyInit(LuceneIndexLanguageTracker.java:68)
  at org.fao.geonet.kernel.search.index.LuceneIndexLanguageTracker.acquire(LuceneIndexLanguageTracker.java:157)
  at org.fao.geonet.kernel.search.SearchManager.getIndexReader(SearchManager.java:1398)
  at org.fao.geonet.kernel.search.SearchManager.getNewIndexReader(SearchManager.java:1402)
  at org.fao.geonet.kernel.search.SearchManager.getDocsChangeDate(SearchManager.java:1057)
  at org.fao.geonet.kernel.DataManager.init(DataManager.java:239)
  at org.fao.geonet.Geonetwork.start(Geonetwork.java:378)
  at jeeves.server.JeevesEngine.initAppHandler(JeevesEngine.java:452)
  at jeeves.server.JeevesEngine.init(JeevesEngine.java:173)
  at jeeves.server.sources.http.JeevesServlet.init(JeevesServlet.java:82)
  at javax.servlet.GenericServlet.init(GenericServlet.java:158)
  at org.apache.catalina.core.StandardWrapper.initServlet(StandardWrapper.java:1231)
  at org.apache.catalina.core.StandardWrapper.loadServlet(StandardWrapper.java:1144)
  at org.apache.catalina.core.StandardWrapper.load(StandardWrapper.java:1031)
  at org.apache.catalina.core.StandardContext.loadOnStartup(StandardContext.java:4914)
  at org.apache.catalina.core.StandardContext.startInternal(StandardContext.java:5201)
  at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:150)
  at org.apache.catalina.core.StandardContext.reload(StandardContext.java:3746)
  at org.apache.catalina.manager.ManagerServlet.reload(ManagerServlet.java:1006)
  at org.apache.catalina.manager.HTMLManagerServlet.reload(HTMLManagerServlet.java:614)
  at org.apache.catalina.manager.HTMLManagerServlet.doPost(HTMLManagerServlet.java:215)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:648)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:729)
  at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:291)
  at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
  at org.apache.catalina.filters.CsrfPreventionFilter.doFilter(CsrfPreventionFilter.java:213)
  at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:239)
  at org.apache.tomcat.websocket.server.WsFilter.doFilter(WsFilter.java:52)
  at org.apache.catalina.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:108)
  at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:219)
  at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:106)
  at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:614)
  at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:142)
  at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:79)
  at org.apache.catalina.valves.AbstractAccessLogValve.invoke(AbstractAccessLogValve.java:616)
  at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:88)
  at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:518)
  at org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:1091)
  at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:673)
  at org.apache.tomcat.util.net.NioEndpoint$SocketProcessor.doRun(NioEndpoint.java:1526)
  at org.apache.tomcat.util.net.NioEndpoint$SocketProcessor.run(NioEndpoint.java:1482)
  at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
  at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
  at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61)
  at java.lang.Thread.run(Thread.java:745)
Caused by: org.apache.lucene.store.LockObtainFailedException: Lock
obtain timed out:
  at org.apache.lucene.store.Lock.obtain(Lock.java:89)
  at org.apache.lucene.index.IndexWriter.<init>(IndexWriter.java:724)
  at org.apache.lucene.facet.taxonomy.directory.DirectoryTaxonomyWriter.openIndexWriter(DirectoryTaxonomyWriter.java:265)
  at org.apache.lucene.facet.taxonomy.directory.DirectoryTaxonomyWriter.<init>(DirectoryTaxonomyWriter.java:192)
  at org.apache.lucene.facet.taxonomy.directory.DirectoryTaxonomyWriter.<init>(DirectoryTaxonomyWriter.java:315)
  at org.apache.lucene.facet.taxonomy.directory.DirectoryTaxonomyWriter.<init>(DirectoryTaxonomyWriter.java:332)
  at org.fao.geonet.kernel.search.index.TaxonomyIndexTracker.init(TaxonomyIndexTracker.java:46)
  at org.fao.geonet.kernel.search.index.TaxonomyIndexTracker.<init>(TaxonomyIndexTracker.java:40)
  at org.fao.geonet.kernel.search.index.LuceneIndexLanguageTracker.lazyInit(LuceneIndexLanguageTracker.java:59)
  ... 49 more
Caused by: java.nio.channels.OverlappingFileLockException
  at sun.nio.ch.SharedFileLockTable.checkList(FileLockTable.java:255)
  at sun.nio.ch.SharedFileLockTable.add(FileLockTable.java:152)
  at sun.nio.ch.FileChannelImpl.tryLock(FileChannelImpl.java:1108)
  at java.nio.channels.FileChannel.tryLock(FileChannel.java:1155)
  at org.apache.lucene.store.NativeFSLock.obtain(NativeFSLockFactory.java:169)
  at org.apache.lucene.store.Lock.obtain(Lock.java:96)
  ... 57 more
2017-03-13 9:47 GMT+01:00 Francois Prunayre <fx.prunayre@anonymised.com>:
properly.
and restart.
HTH
Francois
> Hi folks,
version.
> I got this error:
> FileError:
0.1/bootstrap.less'
> wasn't found (404)
> error:
> useful results.
> Thanks in advance.
> Adam
projects/geonetwork
Hi Adam
This issue seem related to the data directory. You have it externalised
seem. Not really sure if any relation with your initial issue about wroj4.
Check your configuration with
http://geonetwork-opensource.org/manuals/trunk/eng/users/maintainer-guide/installing/customizing-data-directory.html?highlight=external%20data
For example you use for example this format:
-Dgeonetwork.dir=/data/catalogue
You need to make use to change geonetwork, but the name of the
applications, in your case seem geonetwork3:
-Dgeonetwork3.dir=/data/catalogue
Jose García
On Wed, Mar 15, 2017 at 10:08 AM, Adam Laža <ad.laza32@anonymised.com> wrote:
Thanks!
Adam
[1]:
*Message*
*Handler*
*Exception*
*Stack*
java:452)
WsFilter.java:52)
TaskThread.java:61)
obtain timed out:
        ... 49 more
        ... 57 more
> properly.
> and restart.
> HTH
> Francois
> > Hi folks,
> version.
it
Tomcat.
> > I got this error:
> > FileError:
> 0.1/bootstrap.less'
> > wasn't found (404)
> > error:
no
> > useful results.
> > Thanks in advance.
> > Adam
> > _______________________________________________
> projects/geonetwork
Check out the vibrant tech community on one of the world's most
projects/geonetwork
*Vriendelijke groeten / Kind regards,Jose García
<http://www.geocat.net/&gt;Veenderweg 136721 WD BennekomThe NetherlandsT: +31
(0)318 416664 <+31318416664> <https://www.facebook.com/geocatbv&gt;
<https://twitter.com/geocat_bv&gt;
<https://plus.google.com/u/1/+GeocatNetbv/posts&gt;Please consider the
environment before printing this email.*
Hi Jose,
I checked the configuration and added "-Dgeonetwork2.dir=/data/GN/data"
into it so now I have in my tomcat/bin/setenv.sh script:
export JAVA_OPTS="-Dgeonetwork.dir=/data/GN/data
-Djava.awt.headless=true -Dfile.encoding=UTF-8 -Xms2048m -Xmx4500m -server
-XX:+UseParallelGC -XX:PermSize=750m -XX:MaxPermSize=1500m
-Djava.library.path=/usr/local/lib"
But I got almost the same error [1].
Could be the problem that both GN instances have the same data dir?
Adam
[1]:
*Message*
*Handler*
*Exception*
*Stack*
  at org.fao.geonet.kernel.search.index.LuceneIndexLanguageTracker.lazyInit(LuceneIndexLanguageTracker.java:124)
  at org.fao.geonet.kernel.search.index.LuceneIndexLanguageTracker.acquire(LuceneIndexLanguageTracker.java:187)
  at org.fao.geonet.kernel.search.SearchManager.getIndexReader(SearchManager.java:1210)
  at org.fao.geonet.kernel.search.SearchManager.getNewIndexReader(SearchManager.java:1215)
  at org.fao.geonet.kernel.search.SearchManager.getDocsChangeDate(SearchManager.java:945)
  at org.fao.geonet.kernel.DataManager.init(DataManager.java:345)
  at org.fao.geonet.Geonetwork.start(Geonetwork.java:345)
  at jeeves.server.JeevesEngine.initAppHandler(JeevesEngine.java:448)
  at jeeves.server.JeevesEngine.init(JeevesEngine.java:191)
  at jeeves.server.sources.http.JeevesServlet.init(JeevesServlet.java:84)
  at org.apache.catalina.core.ContainerBase.addChildInternal(ContainerBase.java:725)
  at org.apache.catalina.core.ContainerBase.addChild(ContainerBase.java:701)
  at org.apache.catalina.core.StandardHost.addChild(StandardHost.java:717)
  at org.apache.catalina.startup.HostConfig.deployWAR(HostConfig.java:945)
  at org.apache.catalina.startup.HostConfig$DeployWar.run(HostConfig.java:1768)
  at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511)
  at java.util.concurrent.FutureTask.run(FutureTask.java:266)
obtain timed out:
  at org.fao.geonet.kernel.search.index.TaxonomyIndexTracker.init(TaxonomyIndexTracker.java:69)
  at org.fao.geonet.kernel.search.index.TaxonomyIndexTracker.<init>(TaxonomyIndexTracker.java:63)
  at org.fao.geonet.kernel.search.index.LuceneIndexLanguageTracker.lazyInit(LuceneIndexLanguageTracker.java:115)
  ... 26 more
  ... 34 more
2017-03-15 10:20 GMT+01:00 Jose Garcia <jose.garcia@anonymised.com>:
Hi Adam
Check your configuration with http://geonetwork-
For example you use for example this format: -Dgeonetwork.dir=/
data/catalogue
applications, in your case seem geonetwork3: -Dgeonetwork3.
dir=/data/catalogue
Jose García
Thanks!
Adam
[1]:
restart.
*Message*
*Handler*
*Exception*
*Stack*
452)
java:82)
dWrapper.java:1231)
dWrapper.java:1144)
r.java:1031)
java:150)
ext.java:3746)
vlet.java:1006)
r.java:52)
stValve.java:142)
rtValve.java:79)
apter.java:518)
Executor.java:1142)
lExecutor.java:617)
obtain timed out:
724)
        ... 49 more
255)
ory.java:169)
        ... 57 more
> properly.
> and restart.
> HTH
> Francois
> > Hi folks,
> version.
rename it
Tomcat.
> > I got this error:
> > FileError:
> 0.1/bootstrap.less'
> > wasn't found (404)
this
> > error:
no
> > useful results.
> > Thanks in advance.
> > Adam
an
> projects/geonetwork
s/geonetwork
Hi Adam
I was assuming you setup different folders for each instance. If thats not
the case, that explains the problem.
You can not share the data directory between different instances, otherwise
the Lucene index for example will get corrupted.
Jose García
On Wed, Mar 15, 2017 at 12:00 PM, Adam Laža <ad.laza32@anonymised.com> wrote:
Hi Jose,
-Dgeonetwork2.dir=/data/GN/data -Djava.awt.headless=true
-Dfile.encoding=UTF-8 -Xms2048m -Xmx4500m -server -XX:+UseParallelGC
-XX:PermSize=750m -XX:MaxPermSize=1500m -Djava.library.path=/usr/local
/lib"
Adam
[1]:
*Message*
org.apache.lucene.store.LockObtainFailedException: Lock obtain timed out: NativeFSLock@/data/GN/data/index/taxonomy/write.lock: java.nio.channels.OverlappingFileLockException
*Handler*
*Exception*
java.lang.RuntimeException: org.apache.lucene.store.LockObtainFailedException: Lock obtain timed out: NativeFSLock@/data/GN/data/index/taxonomy/write.lock: java.nio.channels.OverlappingFileLockException
*Stack*
Caused by: org.apache.lucene.store.LockObtainFailedException: Lock obtain timed out: NativeFSLock@/data/GN/data/index/taxonomy/write.lock: java.nio.channels.OverlappingFileLockException
  ... 26 more
  ... 34 more
Hi Adam
Check your configuration with http://geonetwork-opensou
For example you use for example this format: -Dgeonetwork.dir=/data
/catalogue
applications, in your case seem geonetwork3: -Dgeonetwork3.di
r=/data/catalogue
Jose García
if
Thanks!
Adam
[1]:
restart.
*Message*
*Handler*
*Exception*
*Stack*
452)
java:82)
dWrapper.java:1231)
dWrapper.java:1144)
r.java:1031)
ava:150)
ext.java:3746)
vlet.java:1006)
r.java:52)
stValve.java:142)
rtValve.java:79)
apter.java:518)
Executor.java:1142)
lExecutor.java:617)
obtain timed out:
724)
        ... 49 more
255)
ory.java:169)
        ... 57 more
> properly.
> and restart.
> HTH
> Francois
> > Hi folks,
> version.
rename it
Tomcat.
> > I got this error:
> > FileError:
> 0.1/bootstrap.less'
> > wasn't found (404)
this
> > error:
with no
> > useful results.
> > Thanks in advance.
> > Adam
an
> projects/geonetwork
s/geonetwork
Thank you Jose!
It explains everything :slight_smile: I tried to keep both version running at the same
time to test if both work the same way. Now I know it's not possible.
Ok, I will stop the old version and keep running only the new one.
Is it possible to say which files or dirs I should copy from old version to
new one to have the same customization?
Adam
2017-03-15 12:07 GMT+01:00 Jose Garcia <jose.garcia@anonymised.com>:
Hi Adam
otherwise the Lucene index for example will get corrupted.
Jose García
Hi Jose,
/lib"
Adam
[1]:
restart. *Message*
*Handler*
*Exception*
*Stack*
  ... 26 more
  ... 34 more
Hi Adam
/catalogue
r=/data/catalogue
Jose García
if
(which
However
at
Thanks!
Adam
[1]:
restart.
*Message*
*Handler*
*Exception*
*Stack*
452)
java:82)
dWrapper.java:1231)
dWrapper.java:1144)
r.java:1031)
ava:150)
ext.java:3746)
vlet.java:1006)
r.java:52)
stValve.java:142)
rtValve.java:79)
apter.java:518)
Executor.java:1142)
lExecutor.java:617)
obtain timed out:
724)
        ... 49 more
255)
ory.java:169)
        ... 57 more
> properly.
> and restart.
> HTH
> Francois
> > Hi folks,
> version.
rename it
Tomcat.
> > I got this error:
> > FileError:
> 0.1/bootstrap.less'
> > wasn't found (404)
this
> > error:
with no
> > useful results.
> > Thanks in advance.
> > Adam
world-renowned
for an
> projects/geonetwork
s/geonetwork
Hi Adam
You need to configure to use the data directory. Would be good to check
this:
http://geonetwork-opensource.org/manuals/trunk/eng/users/maintainer-guide/installing/customizing-data-directory.html?highlight=external%20data#advanced-data-directory-configuration
The best configuration is to externalise the data directory, except the
schema plugins folder, so they are taken from the deployed folder as these
schemas are updated in each version. Something like:
-Dgeonetwork.schema.dir=/app/tomcat/webapps/geonetwork/WEB-INF/data/config/schema_plugins
You'll need also to copy the database configuration files with your
database connection: WEB-INF/config-db/jdbc.properties,
I think that should be all.
Jose García
On Wed, Mar 15, 2017 at 12:28 PM, Adam Laža <ad.laza32@anonymised.com> wrote:
Thank you Jose!
to new one to have the same customization?
Adam
Hi Adam
not the case, that explains the problem.
Jose García
Hi Jose,
/lib"
Adam
[1]:
restart. *Message*
*Handler*
*Exception*
*Stack*
  ... 26 more
  ... 34 more
Hi Adam
/catalogue
r=/data/catalogue
Jose García
wrote:
occurs if
version
(which
However
at
Thanks!
Adam
[1]:
restart.
*Message*
*Handler*
*Exception*
*Stack*
Tracker.java:68)
racker.java:157)
obtain timed out:
yWriter.java:192)
yWriter.java:315)
yWriter.java:332)
Tracker.java:59)
        ... 49 more
        ... 57 more
> properly.
> and restart.
> HTH
> Francois
> > Hi folks,
> version.
rename it
Tomcat.
> > I got this error:
> > FileError:
> 0.1/bootstrap.less'
> > wasn't found (404)
this
> > error:
started
with no
> > useful results.
> > Thanks in advance.
> > Adam
world-renowned
for an
and
> projects/geonetwork
s/geonetwork
We are using GN 3.2.1 and trying to harvest another CSW 2.0.2 interface. Seems that all the harvesting filters are implemented as PropertyIsEqualTo. Is there any way to configure for example AnyText to use PropertyIsLike to allow using wildcards in the filter?
Best regards,
Kai Koistinen
Expert
National Land Survey of Finland
+358 40 487 9104
kai.koistinen@...608...
Hi Kai
In the code I see the following:
private void buildFilterQueryable(List<Element> queryables, String
name, String value) {
    if (value.contains("%")) {
        buildFilterQueryable(queryables, name, value, "PropertyIsLike");
    } else {
        buildFilterQueryable(queryables, name, value, "PropertyIsEqualTo");
So if using % in the field value, should use PropertyIsLike.
Jose García
On Wed, Mar 15, 2017 at 1:32 PM, Koistinen Kai (MML) <
kai.koistinen@anonymised.com> wrote:
Best regards,
Kai Koistinen
Expert
+358 40 487 9104
projects/geonetwork
Hi, I added recently
(https://github.com/geonetwork/core-geonetwork/commit/c6bb87724a328cca5894fe04aed53ea5c9fc983b)
an info about that which should be displayed next to the set of
criteria.
Cheers.
Francois
2017-03-15 14:10 GMT+01:00 Jose Garcia <jose.garcia@anonymised.com>:
Hi Kai
    } else {
Jose García
Best regards,
Kai Koistinen
Expert
+358 40 487 9104
projects/geonetwork
