Hello,
I'm testing the GNV3 with PostgreSQL. Everything went well until I click on
"Clear JS & CSS Cache" from the Web manager. Suddenly after a Tomcat8
restart all the GN pages are messed-up (see attache screen copy). I
attached the catalina.out log file.
I've read several past posts about crash relaxed to WOR4J pb. from the
mailing-list but I don't find any explanation and wonder I this may occur on
this release.
If someone could put me back on tracks, this will be great.
Thanks in advance.
Best regards,
Lionel
2017-07-13 15:32:44,257 WARN [geonetwork.data.directory] - - Data
directory properties is not set. Use geonetwork.dir or geonetwork.dir
properties.
2017-07-13 15:32:44,258 WARN [geonetwork.data.directory] - - Data
directory provided could not be used. Using default location:
/var/lib/tomcat8/webapps/geonetwork/WEB-INF/data
2017-07-13 15:32:44,793 WARN [geonetwork.schemamanager] - WARNING:
gco:Record is a global element without a type - assuming a string
2017-07-13 15:32:44,960 WARN [geonetwork.schemamanager] - WARNING:
2017-07-13 15:32:44,964 WARN [geonetwork.schemamanager] - WARNING:
schema-substitutions.xml has wiped out XSD substitution list for
gml:VerticalDatum
2017-07-13 15:32:44,966 WARN [geonetwork.schemamanager] - WARNING:
gml:CoordinateSystemAxis
2017-07-13 15:32:44,967 WARN [geonetwork.schemamanager] - WARNING:
gml:VerticalCS
2017-07-13 15:32:44,969 WARN [geonetwork.schemamanager] - WARNING:
2017-07-13 15:32:45,714 WARN [geonetwork.schemamanager] - Cannot resolve
http://www.w3.org/2001/03/xml.xsd: will append last component to current
path (not sure it will help though!)
2017-07-13 15:32:46,828 WARN [geonetwork.lucene] - Stopwords file with
incorrect ISO 639-2 language as filename: README
2017-07-13 15:33:39,065 ERROR [geonetwork.wro4j] - Error occurred during a
wro4j request handling
ro.isdc.wro.WroRuntimeException: Cannot build valid CacheKey from request:
/geonetwork/static/gn_feedback_default.less
at
ro.isdc.wro.manager.ResourceBundleProcessor.getSafeCacheKey(ResourceBundleProcessor.java:111)
at
ro.isdc.wro.manager.ResourceBundleProcessor.serveProcessedBundle(ResourceBundleProcessor.java:61)
at ro.isdc.wro.manager.WroManager.process(WroManager.java:159)
at ro.isdc.wro.http.WroFilter.processRequest(WroFilter.java:335)
at ro.isdc.wro.http.WroFilter.doFilter(WroFilter.java:289)
at
org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:240)
at
org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:207)
at
org.tuckey.web.filters.urlrewrite.RuleChain.handleRewrite(RuleChain.java:176)
at org.tuckey.web.filters.urlrewrite.RuleChain.doRules(RuleChain.java:145)
at
org.tuckey.web.filters.urlrewrite.UrlRewriter.processRequest(UrlRewriter.java:92)
at
org.tuckey.web.filters.urlrewrite.UrlRewriteFilter.doFilter(UrlRewriteFilter.java:381)
at
at
at
org.springframework.security.web.FilterChainProxy.doFilterInternal(FilterChainProxy.java:186)
at
org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:160)
at
org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:346)
at
org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:262)
at
jeeves.config.springutil.JeevesDelegatingFilterProxy.doFilter(JeevesDelegatingFilterProxy.java:104)
at
at
at
org.springframework.web.filter.CharacterEncodingFilter.doFilterInternal(CharacterEncodingFilter.java:121)
at
org.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:107)
at
at
at
org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:213)
at
org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:106)
at
org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:141)
at
org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:79)
at
org.apache.catalina.valves.AbstractAccessLogValve.invoke(AbstractAccessLogValve.java:616)
at
org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:88)
at
org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:522)
at
org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:1095)
at
org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:672)
at
org.apache.tomcat.util.net.NioEndpoint$SocketProcessor.doRun(NioEndpoint.java:1504)
at
org.apache.tomcat.util.net.NioEndpoint$SocketProcessor.run(NioEndpoint.java:1460)
at
java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
at
java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
at
org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61)
at java.lang.Thread.run(Thread.java:748)
2017-07-13 15:33:40,984 WARN [geonetwork.thesaurus] - No thesaurus found
for concept scheme http://geonetwork-opensource.org/inspire-theme (lang=eng)
<http://osgeo-org.1560.x6.nabble.com/file/n5327776/Capture_d’écran_2017-07-13_à_15.png>
View this message in context: http://osgeo-org.1560.x6.nabble.com/GN-V3-2-1-O-Clear-JS-CSS-Cache-crashed-look-tp5327776.html
