Dear all,
a windows2008 - 64 bit machine GN deploys in Tomcat7 32 bit with the 2.10 war file… and issues the following warning:
INFO: Deploying web application archive G:\apps\xampp\tomcat\webapps\geonetwork.war
sept. 03, 2013 11:18:29 AM org.apache.catalina.loader.WebappClassLoader validateJarFile
INFO: validateJarFile(G:\apps\xampp\tomcat\webapps\geonetwork\WEB-INF\lib\servlet-api-2.5.jar) - jar not loaded. See Servlet Spec 2.3, section 9.7.2. Offending class: javax/servlet/Servlet.class
sept. 03, 2013 11:18:31 AM org.apache.catalina.startup.ContextConfig processAnnotationsJar
SEVERE: Unable to process Jar entry [com/ibm/icu/impl/data/LocaleElements_zh__PINYIN.class] from Jar [jar:file:/G:/apps/xampp/tomcat/webapps/geonetwork/WEB-INF/lib/icu4j-2.6.1.jar!/] for annotations
org.apache.tomcat.util.bcel.classfile.ClassFormatException: Invalid byte tag in constant pool: 60
at org.apache.tomcat.util.bcel.classfile.Constant.readConstant(Constant.java:133)
at org.apache.tomcat.util.bcel.classfile.ConstantPool.(ConstantPool.java:60)
at org.apache.tomcat.util.bcel.classfile.ClassParser.readConstantPool(ClassParser.java:209)
at org.apache.tomcat.util.bcel.classfile.ClassParser.parse(ClassParser.java:119)
at org.apache.catalina.startup.ContextConfig.processAnnotationsStream(ContextConfig.java:2118)
at org.apache.catalina.startup.ContextConfig.processAnnotationsJar(ContextConfig.java:1994)
at org.apache.catalina.startup.ContextConfig.processAnnotationsUrl(ContextConfig.java:1960)
at org.apache.catalina.startup.ContextConfig.processAnnotations(ContextConfig.java:1945)
at org.apache.catalina.startup.ContextConfig.webConfig(ContextConfig.java:1319)
at org.apache.catalina.startup.ContextConfig.configureStart(ContextConfig.java:878)
at org.apache.catalina.startup.ContextConfig.lifecycleEvent(ContextConfig.java:376)
at org.apache.catalina.util.LifecycleSupport.fireLifecycleEvent(LifecycleSupport.java:119)
at org.apache.catalina.util.LifecycleBase.fireLifecycleEvent(LifecycleBase.java:90)
at org.apache.catalina.core.StandardContext.startInternal(StandardContext.java:5322)
at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:150)
at org.apache.catalina.core.ContainerBase.addChildInternal(ContainerBase.java:901)
at org.apache.catalina.core.ContainerBase.addChild(ContainerBase.java:877)
at org.apache.catalina.core.StandardHost.addChild(StandardHost.java:633)
at org.apache.catalina.startup.HostConfig.deployWAR(HostConfig.java:976)
at org.apache.catalina.startup.HostConfig$DeployWar.run(HostConfig.java:1653)
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:471)
at java.util.concurrent.FutureTask$Sync.innerRun(FutureTask.java:334)
at java.util.concurrent.FutureTask.run(FutureTask.java:166)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615)
at java.lang.Thread.run(Thread.java:724)
sept. 03, 2013 11:18:47 AM org.geotools.referencing.factory.PropertyAuthorityFactory
WARNING: Axis elements found in a wkt definition, the force longitude first axis order hint might not be respected:
Does anyone has seen the message ? and should I be concerned ?
Hannes
