[GeoNetwork-users] GN2.4 disable xsl caching bug?
we are in the process of customizing a geonetwork site (2.4RC2 with java
1.6.0_13), so I've tried to deactivate the xsl caching so we dont have to
stop/start the server to each xsl modification.
To do so, I've only edited the javax.xml.transform.TransformerFactory file
in the META-INF/services directory and changed the value to
org.apache.xalan.processor.TransformerFactoryImpl.
But then I have a NullPointerException with the following log, have I missed
something?
Regards
Yves
INFO jeeves.service - -> transforming with stylesheet :
/home/yves/Logiciels/geonetwork2.4/web/geonetwork/xsl/main-page.xsl
WARNING: transformerfactory doesnt like saxon attributes!
ID système inconnu; Ligne #22; Colonne #71; Impossible de trouver la
fonction : tokenize
ID système inconnu; Ligne #22; Colonne #71; jeton de fonction introuvable.
(Emplacement inconnu de l'erreur)java.lang.NullPointerException
396763 [8897128@anonymised.com] ERROR jeeves.service - -> exception during
transformation for : main.home
396764 [8897128@anonymised.com] ERROR jeeves.service - -> (C) stylesheet :
396764 [8897128@anonymised.com] ERROR jeeves.service - -> (C) message : null
396764 [8897128@anonymised.com] ERROR jeeves.service - -> (C) exception :
396764 [8897128@anonymised.com] DEBUG jeeves.service - Raised exception while
executing service
<error id="error">
  <message />
  <class>NullPointerException</class>
  <stack>
    <at class="jeeves.utils.Xml" file="Xml.java" line="243"
method="transform" />
    <at class="jeeves.utils.Xml" file="Xml.java" line="204"
    <at class="jeeves.server.dispatchers.ServiceManager"
file="ServiceManager.java" line="678" method="dispatchOutput" />
file="ServiceManager.java" line="383" method="dispatch" />
    <at class="jeeves.server.JeevesEngine" file="JeevesEngine.java"
line="621" method="dispatch" />
    <at class="jeeves.server.sources.http.JeevesServlet"
file="JeevesServlet.java" line="174" method="execute" />
file="JeevesServlet.java" line="89" method="doGet" />
    <at class="javax.servlet.http.HttpServlet" file="HttpServlet.java"
line="707" method="service" />
line="820" method="service" />
    <at class="org.mortbay.jetty.servlet.ServletHolder"
file="ServletHolder.java" line="502" method="handle" />
  </stack>
  <request>
    <language>en</language>
    <service>main.home</service>
  </request>
  <response />
</error>
View this message in context: http://n2.nabble.com/GN2.4-disable-xsl-caching-bug--tp3322121p3322121.html
Ok found it,
as GN2.4 uses now saxon, the actual factory to use is
net.sf.saxon.TransformerFactoryImpl . File README in that directory should
be updated to reflect that
Yves G wrote:
missed something?
Regards
Yves
fonction : tokenize
null
executing service
<error id="error">
  <message />
  <stack>
  </stack>
  <request>
  </request>
  <response />
</error>
View this message in context: http://n2.nabble.com/GN2.4-disable-xsl-caching-bug--tp3322121p3322325.html
Yves G wrote:
Ok found it,
Hallo,
That works for the 'HEAD' xsl files but when I include files (e.g. in
metadata-utils.xsl) I have to restart the server on any change!!
Knows someone a solution for that?
Hans
This is the README text for disabling the caching:
By default XSL caching is active.
The javax.xml.transform.TransformerFactory file is used to define
the XSL processor to use.
* de.fzi.dbs.xml.transform.CachingTransformerFactory for XSL caching
(recommended value for production use).
* org.apache.xalan.processor.TransformerFactoryImpl for no XSL caching
(recommended for dev). When caching is on, only the main XSL stylesheet
last update date is checked and not all included XSL. If you update
an included stylesheet, cache is still used. (!!!! HERE, cache is still used
View this message in context: http://n2.nabble.com/GN2-4-disable-xsl-caching-bug-tp3322121p3566714.html
I think you forgot to include exslt-namespace in a xsl file. I think
'tokenize' is a function of now used saxon.
Hans
fonction : tokenize
Yves G wrote:
missed something?
Regards
Yves
fonction : tokenize
null
executing service
<error id="error">
  <message />
  <stack>
  </stack>
  <request>
  </request>
  <response />
</error>
View this message in context: http://n2.nabble.com/GN2-4-disable-xsl-caching-bug-tp3322121p3596873.html
