[GeoNetwork-users] GN3.0.2 XML Services (metadata.insert)
Hi
I am trying to use the metadata.import XML services in GN3.0.2 but it seems
that /geonetwork/srv/eng/metadata.insert is not available in this version.
When I browse this service I get "The service does not exist or you don't
have privileges to access it". I get the same from my python post script.
Is that an issue with my build or have the services changed in GN3.0.2?
The online doco is not completed for 3.0.2 so can anyone share some insight?
Thanks
*Luke Bassett*
* <lukembassett@anonymised.com>*Melbourne Australia
Hi Luke
The service seem now is call md.import. See the documentation in
https://github.com/geonetwork/core-geonetwork/blob/3.0.x/web/src/main/webapp/WEB-INF/config/config-service-admin-io.xml#L5-L33
Jose García
On Thu, Nov 19, 2015 at 2:54 AM, Luke <coolhandluka@anonymised.com> wrote:
Hi
insight?
Thanks
*Luke Bassett*
GeoNetwork-users mailing list
*Vriendelijke groeten / Kind regards,Jose García
<http://www.geocat.net/&gt;Veenderweg 136721 WD BennekomThe NetherlandsT: +31
(0)318 416664 <+31318416664> <https://www.facebook.com/geocatbv&gt;
<https://twitter.com/geocat_bv&gt;
<https://plus.google.com/u/1/+GeocatNetbv/posts&gt;Please consider the
environment before printing this email.*
Another option would be to use the CSW Transaction Insert operation.
Francois
2015-11-19 8:22 GMT+01:00 Jose Garcia <jose.garcia@anonymised.com>:
Hi Luke
Jose García
> Hi
seems
version.
> insight?
> Thanks
> *Luke Bassett*
Thanks for the replies everyone
I ended up changing my script to output metadata xml into a directory and
using the UI import tool - worked great
On Thu, Nov 19, 2015 at 7:27 PM, Francois Prunayre <fx.prunayre@anonymised.com>
wrote:
Francois
Hi Luke
Jose García
> Hi
seems
version.
don't
script.
> insight?
> Thanks
> *Luke Bassett*
+31
*Luke Bassett*
