[GeoNetwork-users] gn3.0.4 code list problem
Hi
I have a new instance running 3.0.4 and I am seeing some code list lookup
problems in my log
The install was a bit bumpy, I had to change the sql data script to get it
working in SQL Server.
Could this be a db issue?
Here are the log entries
2016-04-06 14:41:30,151 ERROR [geonetwork] - Failed to translate codelist
value 'originator' in language 'eng'. Error is null
2016-04-06 14:41:30,159 ERROR [geonetwork] - Failed to translate codelist
value 'boundaries' in language 'eng'. Error is null
value 'pointOfContact' in language 'eng'. Error is null
value 'eng' in language 'eng'. Error is null
2016-04-06 14:41:30,163 ERROR [geonetwork] - Failed to translate codelist
value 'utf8' in language 'eng'. Error is null
value 'revision' in language 'eng'. Error is null
value 'completed' in language 'eng'. Error is null
value 'annually' in language 'eng'. Error is null
2016-04-06 14:41:30,170 ERROR [geonetwork] - Failed to translate codelist
value 'place' in language 'eng'. Error is null
value 'copyright' in language 'eng'. Error is null
value 'otherRestictions' in language 'eng'. Error is null
value 'vector' in language 'eng'. Error is null
value 'dataset' in language 'eng'. Error is null
*Luke Bassett*
* <lukembassett@anonymised.com>*Melbourne Australia
