[GeoNetwork-users] Gn3.10.0 installation problem
I am doing a clean install of GN3.10.0 - empty PostGIS database, empty external data folder. Redhat Linux 6, Java 8, Jetty 9.4. GeoNetwork appears to load fine, mefs load without error, metadata displays fine. I checked and the PostGIS database is nicely populated, and the provided data resources are in the external folder in the correct spots. However, subsequently I cannot access the resources for display and download, nor do the thumbnails display. So - there appears to be a problem accessing the external folder. No hints in the log file. Any suggestions?
Hi Terry, even with the default samples ?
We have some issues related to MEF in 3.10.0 but it is more related to
download as MEF or harvesting 3.10.0 with GeoNetwork protocol. Import as
MEF should work fine.
If you add a thumbnail, the thumbnail can be found in the datadirectory ?
Any exception when you try to load the thumbnail using the API URL for
example ?
Francois
suggestions?
GeoNetwork-users mailing list
Yes - even with the default samples (the ones with thumbnails, like Africa) . Links to external thumbnails - I have a few like this - do display.
And yes, the resources are present in the folder structure. If I add a thumbnail, it is accepted but I cannot see it.
I tried (this is a wonderful feature) :
curl -X GET "http://soggy.zoology.ubc.ca:8080/geonetwork/srv/api/0.1/records/58531064-0207-4e4a-b3c1-cc2a91aad05b/attachments?sort=name&approved=true&filter=*.*&quot; -H "accept: application/json" -H "X-XSRF-TOKEN: 0d0a0f35-c45f-4aca-a860-84b548a40cca"
with response:
[{"url":"http://localhost:8080/geonetwork/srv/api/records/58531064-0207-4e4a-b3c1-cc2a91aad05b/attachments/58531064-0207-4e4a-b3c1-cc2a91aad05b.pdf&quot;,&quot;size&quot;:148906,&quot;lastModification&quot;:1532203210430,&quot;filename&quot;:&quot;58531064\-0207\-4e4a\-b3c1\-cc2a91aad05b\.pdf&quot;,&quot;id&quot;:&quot;58531064\-0207\-4e4a\-b3c1\-cc2a91aad05b/attachments/58531064\-0207\-4e4a\-b3c1\-cc2a91aad05b\.pdf&quot;,&quot;visibility&quot;:&quot;PRIVATE&quot;\},{"url":"http://localhost:8080/geonetwork/srv/api/records/58531064-0207-4e4a-b3c1-cc2a91aad05b/attachments/58531064-0207-4e4a-b3c1-cc2a91aad05b.png&quot;,&quot;size&quot;:162851,&quot;lastModification&quot;:1532203210403,&quot;filename&quot;:&quot;58531064\-0207\-4e4a\-b3c1\-cc2a91aad05b\.png&quot;,&quot;id&quot;:&quot;58531064\-0207\-4e4a\-b3c1\-cc2a91aad05b/attachments/58531064\-0207\-4e4a\-b3c1\-cc2a91aad05b\.png&quot;,&quot;visibility&quot;:&quot;PUBLIC&quot;\},{"url":"http://localhost:8080/geonetwork/srv/api/records/58531064-0207-4e4a-b3c1-cc2a91aad05b/attachments/58531064-0207-4e4a-b3c1-cc2a91aad05b.xlsx&quot;,&quot;size&quot;:275986,&quot;lastModification&quot;:1532203210418,&quot;filename&quot;:&quot;58531064\-0207\-4e4a\-b3c1\-cc2a91aad05b\.xlsx&quot;,&quot;id&quot;:&quot;58531064\-0207\-4e4a\-b3c1\-cc2a91aad05b/attachments/58531064\-0207\-4e4a\-b3c1\-cc2a91aad05b\.xlsx&quot;,&quot;visibility&quot;:&quot;PRIVATE&quot;
I cannot access these three items normally. With the recent mef upload, I had changed the link "http://soggy.zoology.ubc.ca:8080" to http://localhost:8080". I see the curl uses the more specific format. I could reload the mefs with soggy explicitly, if this is an important difference.
We have some issues related to MEF in 3.10.0 but it is more related to download as MEF or harvesting 3.10.0 with GeoNetwork protocol. Import as MEF should work fine.
Any exception when you try to load the thumbnail using the API URL for example ?
Francois
Le mer. 12 févr. 2020 à 07:14, Terry <terry.curran@anonymised.com.1266... <mailto:terry.curran@anonymised.com>> a écrit :
    empty
    fine.
    provided
    Any
    suggestions?
    <mailto:GeoNetwork-users@lists.sourceforge.net>
I misspoke a bit. If I use "Add resources" to add a thumbnail, the app complains but says "add anyway?" which I do, then it adds and the thumbnail is visible.
On 2020-02-12 9:23 a.m., terry wrote:
-------- Forwarded Message --------
Subject: Re: [GeoNetwork-users] Gn3.10.0 installation problem
Date: Wed, 12 Feb 2020 09:22:47 -0800
To: Francois Prunayre <fx.prunayre@anonymised.com>, GeoNetwork-users@lists.sourceforge.net
with response:
Francois
Le mer. 12 févr. 2020 à 07:14, Terry <terry.curran@anonymised.com..1266... <mailto:terry.curran@anonymised.com>> a écrit :
    empty
    fine.
    provided
    file. Any
    suggestions?
So you've to configure host parameter in the admin > settings first.
See
https://geonetwork-opensource.org/manuals/trunk/en/administrator-guide/configuring-the-catalog/system-configuration.html#catalog-server
Francois
is visible.
From: terry <terry.curran@anonymised.com> <terry.curran@anonymised.com>
To: Francois Prunayre <fx.prunayre@anonymised.com> <fx.prunayre@anonymised.com>,
display.
curl -X GET
<http://soggy.zoology.ubc.ca:8080/geonetwork/srv/api/0.1/records/58531064-0207-4e4a-b3c1-cc2a91aad05b/attachments?sort=name&approved=true&filter=*.*&gt;
with response:
    "url": "http://localhost:8080/geonetwork/srv/api/records/58531064-0207-4e4a-b3c1-cc2a91aad05b/attachments/58531064-0207-4e4a-b3c1-cc2a91aad05b.pdf&quot; <http://localhost:8080/geonetwork/srv/api/records/58531064-0207-4e4a-b3c1-cc2a91aad05b/attachments/58531064-0207-4e4a-b3c1-cc2a91aad05b.pdf&gt;,
    "size": 148906,
    "lastModification": 1532203210430,
    "filename": "58531064-0207-4e4a-b3c1-cc2a91aad05b.pdf",
    "id": "58531064-0207-4e4a-b3c1-cc2a91aad05b/attachments/58531064-0207-4e4a-b3c1-cc2a91aad05b.pdf",
    "visibility": "PRIVATE"
    "url": "http://localhost:8080/geonetwork/srv/api/records/58531064-0207-4e4a-b3c1-cc2a91aad05b/attachments/58531064-0207-4e4a-b3c1-cc2a91aad05b.png&quot; <http://localhost:8080/geonetwork/srv/api/records/58531064-0207-4e4a-b3c1-cc2a91aad05b/attachments/58531064-0207-4e4a-b3c1-cc2a91aad05b.png&gt;,
    "size": 162851,
    "lastModification": 1532203210403,
    "filename": "58531064-0207-4e4a-b3c1-cc2a91aad05b.png",
    "id": "58531064-0207-4e4a-b3c1-cc2a91aad05b/attachments/58531064-0207-4e4a-b3c1-cc2a91aad05b.png",
    "visibility": "PUBLIC"
    "url": "http://localhost:8080/geonetwork/srv/api/records/58531064-0207-4e4a-b3c1-cc2a91aad05b/attachments/58531064-0207-4e4a-b3c1-cc2a91aad05b.xlsx&quot; <http://localhost:8080/geonetwork/srv/api/records/58531064-0207-4e4a-b3c1-cc2a91aad05b/attachments/58531064-0207-4e4a-b3c1-cc2a91aad05b.xlsx&gt;,
    "size": 275986,
    "lastModification": 1532203210418,
    "filename": "58531064-0207-4e4a-b3c1-cc2a91aad05b.xlsx",
    "id": "58531064-0207-4e4a-b3c1-cc2a91aad05b/attachments/58531064-0207-4e4a-b3c1-cc2a91aad05b.xlsx",
<http://soggy.zoology.ubc.ca:8080> to http://localhost:8080". I see the
example ?
Francois
suggestions?
That solved the problem. Thank you very much. I need to work on my reading comprehension skills ;->
See https://geonetwork-opensource.org/manuals/trunk/en/administrator-guide/configuring-the-catalog/system-configuration.html#catalog-server
Francois
Le mer. 12 févr. 2020 à 18:46, Terry <terry.curran@anonymised.com <mailto:terry.curran@anonymised.com>> a écrit :
    From: terry <terry.curran@anonymised.com> <mailto:terry.curran@anonymised.com>
    <mailto:fx.prunayre@anonymised.com>,
    this - do display.
    curl -X GET
    with response:
    <http://localhost:8080/geonetwork/srv/api/records/58531064-0207-4e4a-b3c1-cc2a91aad05b/attachments/58531064-0207-4e4a-b3c1-cc2a91aad05b.pdf&gt;,&quot;size&quot;:148906,&quot;lastModification&quot;:1532203210430,&quot;filename&quot;:&quot;58531064\-0207\-4e4a\-b3c1\-cc2a91aad05b\.pdf&quot;,&quot;id&quot;:&quot;58531064\-0207\-4e4a\-b3c1\-cc2a91aad05b/attachments/58531064\-0207\-4e4a\-b3c1\-cc2a91aad05b\.pdf&quot;,&quot;visibility&quot;:&quot;PRIVATE&quot;\},{"url":"http://localhost:8080/geonetwork/srv/api/records/58531064-0207-4e4a-b3c1-cc2a91aad05b/attachments/58531064-0207-4e4a-b3c1-cc2a91aad05b.png&quot;
    <http://localhost:8080/geonetwork/srv/api/records/58531064-0207-4e4a-b3c1-cc2a91aad05b/attachments/58531064-0207-4e4a-b3c1-cc2a91aad05b.png&gt;,&quot;size&quot;:162851,&quot;lastModification&quot;:1532203210403,&quot;filename&quot;:&quot;58531064\-0207\-4e4a\-b3c1\-cc2a91aad05b\.png&quot;,&quot;id&quot;:&quot;58531064\-0207\-4e4a\-b3c1\-cc2a91aad05b/attachments/58531064\-0207\-4e4a\-b3c1\-cc2a91aad05b\.png&quot;,&quot;visibility&quot;:&quot;PUBLIC&quot;\},{"url":"http://localhost:8080/geonetwork/srv/api/records/58531064-0207-4e4a-b3c1-cc2a91aad05b/attachments/58531064-0207-4e4a-b3c1-cc2a91aad05b.xlsx&quot;
    <http://localhost:8080/geonetwork/srv/api/records/58531064-0207-4e4a-b3c1-cc2a91aad05b/attachments/58531064-0207-4e4a-b3c1-cc2a91aad05b.xlsx&gt;,&quot;size&quot;:275986,&quot;lastModification&quot;:1532203210418,&quot;filename&quot;:&quot;58531064\-0207\-4e4a\-b3c1\-cc2a91aad05b\.xlsx&quot;,&quot;id&quot;:&quot;58531064\-0207\-4e4a\-b3c1\-cc2a91aad05b/attachments/58531064\-0207\-4e4a\-b3c1\-cc2a91aad05b\.xlsx&quot;,&quot;visibility&quot;:&quot;PRIVATE&quot;
    datadirectory ?
    URL for example ?
    Francois
        database, empty
        displays fine.
        the provided
        display and
        to be a
        file. Any
        suggestions?
