Hi list,
The keywords list is case sensitive which means that if I type in "global"
it doesn't find the word "Global" (which is in the keywords list, from the
sample data).
Is there a way to desactivate the "case sensitive" mode? I think the
research would be much more eficient without it.
An other related issue:
In the keywords list, the word "Global" is indexed with 2 results. When i
run a search on this keyword I get 2 metadata:
http://n2.nabble.com/file/n3312802/metadata1.jpg
The second metadata contains "Global" in his keywords but not the firts one.
When I look in the complete metadata of the first one I see:
http://n2.nabble.com/file/n3312802/metadata2.jpg
Where I see that the word "Global" is present in the field Coverage.
I don't understand the way the search works here or it's just a bug?
Pierre
View this message in context: http://n2.nabble.com/GNO-2.4---Keywords-list-is-case-sensitive-tp3312802p3312802.html
