[GeoNetwork-users] Gonetwork Customization - Metadata Edit Form - Help
All,
How do I change a field from mandatory to non mandatory in metadata editor
form? What changes should I make and where should I make?
Reagrds
Kumaran
[mailto:kumaran.narayanaswamy@anonymised.com]
Sent: Wednesday, April 06, 2011 11:09 PM
To: 'geonetwork-users@lists.sourceforge.net'
Subject: Gonetwork Customization - Metadata Edit Form - Help
Dear Users,
I am a newbie to Geonetwork and have been figuring out to customize the
metadata editor forms. I imported the attached XML and then tried to edit
the metadata and in the resulting screen(attached),
I would like to make the following customization to the metadata editor form
. Few elements to be non editable say for example Individual Name
. Want to create a rectangular frame around minimum value,maximum
value,vertical CRS(box which gets displayed similar to that of temporal
extent.)
. Make Mandatory fields as Non Mandatory for example I want to make
Vertical CRS as non-mandatory
I am trying to play around with the following files
. webapp\xml\schemas\iso19319\present\metadata-iso19319.xsl
. webapp\xsl\metadata.xsl
I am not sure where exactly I need to make change in these files. I googled
in internet and community to find the required steps but was not successful.
Any help or guidance would be really appreciated. Thanks in advance
Regards
Kumaran
