Hello
GN 3.0.2
I'm wondering where to put the Google analytics code or is it not possible?
View this message in context: http://osgeo-org.1560.x6.nabble.com/Google-analytics-code-tp5236879.html
I found an old thread with a similar question. Although it relates to a previous version of GN and I haven't tried it myself, hoping this helps:
The file geonetwork/xsl/main.xsl contains the xsl template that creates the
layout of the GeoNetwork pages. Before closing the <body> section of the
page you can add the google analytics snippet.
You'll need to restart GeoNetwork after the change to get it, due to xsl
caching.
Jose GarcĂa
Hopefully if this is not the correct answer for 3.0 someone else will respond.
Kathy
-----Original Message-----
Sent: Tuesday, November 17, 2015 9:29 AM
To: geonetwork-users@lists.sourceforge.net
Subject: [GeoNetwork-users] Google analytics code
Hello
GN 3.0.2
GeoNetwork-users mailing list
