[GeoNetwork-users] h2 database issues when migrating from 3.0.0 to 3.0.1
Dear list,
I have some serious issues with my h2 database in geonetwork 3.0.1. I
recently upgraded from 3.0.0 to 3.0.1. I'm using the jar installer with the
default h2 database, since the amount of data I'm hosting is relatively
small and I'm running geonetwork under Windows server 2008 R2 enterprise
with only 2 GB RAM.
I had a working h2 database in 3.0.0 and I backed it up before the upgrade.
I removed the old GN install before installing 3.0.1. I'm pointing GN to
the data directory in my startup.bat file:
java -Xms48m -Xmx256m -Xss2M -XX:MaxPermSize=128m
-Dgeonetwork.dir=e:\gn_data\data
-Dmime-mappings=..\web\geonetwork\WEB-INF\mime-types.properties
-DSTOP.PORT=8079 -Djava.awt.headless=true -DSTOP.KEY=geonetwork -jar
start.jar
When GN finally starts and I log in, I cannot see any of my metadata. It
seems the database was not properly migrated to 3.0.1. From the Admin
panel/Information, I can see that the data dir seems to be set correctly,
however:
Catalog information
Thesaurus folder: E:\gn_data\data\config\codelist
Configuration folder: E:\gn_data\data\config
Data directory: E:\gn_data\data\data\metadata_data
Formatter directory: E:\gn_data\data\data\formatter
Resources folder: E:\gn_data\data\data\resources
Standard folder: E:\gn_data\data\config\schema_plugins
Subversion repository: E:\gn_data\data\data\metadata_subversion
Database
Status Database Opened Successfully
JDBC URL jdbc:h2:geonetwork
System information
JVM version 1.8.0_45
JVM name Java HotSpot(TM) Client VM
JVM vendor Oracle Corporation
Total free memory 57686
Total memory 253440
System architecture x86
System name Windows Server 2008 R2
XSLT factory de.fzi.dbs.xml.transform.CachingTransformerFactory
In geonetwork.log, the following error appers:
2015-08-05 15:20:26,534 WARN [geonetwork.schemamanager] - Cannot resolve
http://www.w3.org/2001/03/xml.xsd: will append last component to current
path (not sure it will help though!)
2015-08-05 15:20:30,131 WARN [geonetwork.schemamanager] - WARNING:
gco:Record is a global element without a type - assuming a string
2015-08-05 15:20:32,591 WARN [geonetwork.schemamanager] - WARNING:
2015-08-05 15:20:32,605 WARN [geonetwork.schemamanager] - WARNING:
schema-substitutions.xml has wiped out XSD substitution list for
gml:VerticalDatum
2015-08-05 15:20:32,613 WARN [geonetwork.schemamanager] - WARNING:
gml:CoordinateSystemAxis
2015-08-05 15:20:32,618 WARN [geonetwork.schemamanager] - WARNING:
gml:VerticalCS
2015-08-05 15:20:32,627 WARN [geonetwork.schemamanager] - WARNING:
2015-08-05 15:20:52,863 WARN [geonetwork.lucene] - Stopwords file with
incorrect ISO 639-2 language as filename: README
2015-08-05 15:21:01,567 WARN [geonetwork.svnmanager] - Recreating
subversion repository at E:\gn_data\data\data\metadata_subversion as
previous repository was empty
2015-08-05 15:27:38,176 ERROR [jeeves.service] - Exception when executing
service
2015-08-05 15:27:38,386 ERROR [jeeves.service] - (C) Exc :
MetadataNotFoundEx : Metadata not found
2015-08-05 15:27:38,507 ERROR [jeeves] - Error occurred within a transaction
    at
org.fao.geonet.guiservices.metadata.GetRelated.exec(GetRelated.java:282)
    at
jeeves.server.dispatchers.ServiceInfo.execService(ServiceInfo.java:226)
    at
jeeves.server.dispatchers.ServiceInfo.noTransactionExec(ServiceInfo.java:141)
    at jeeves.server.dispatchers.ServiceInfo.access$000(ServiceInfo.java:45)
    at
jeeves.server.dispatchers.ServiceInfo$1.doInTransaction(ServiceInfo.java:120)
    at
jeeves.server.dispatchers.ServiceInfo$1.doInTransaction(ServiceInfo.java:117)
    at
jeeves.transaction.TransactionManager.runInTransaction(TransactionManager.java:63)
    at
jeeves.server.dispatchers.ServiceInfo.execServices(ServiceInfo.java:114)
    at
jeeves.server.dispatchers.ServiceManager.dispatch(ServiceManager.java:442)
    at
jeeves.server.dispatchers.ServiceManager.dispatch(ServiceManager.java:384)
    at jeeves.server.JeevesEngine.dispatch(JeevesEngine.java:600)
    at
org.fao.geonet.services.main.GenericController.dispatch(GenericController.java:106)
    at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
    at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
    at java.lang.reflect.Method.invoke(Unknown Source)
    at
org.springframework.web.method.support.InvocableHandlerMethod.invoke(InvocableHandlerMethod.java:219)
    at
org.springframework.web.method.support.InvocableHandlerMethod.invokeForRequest(InvocableHandlerMethod.java:132)
    at
org.springframework.web.servlet.mvc.method.annotation.ServletInvocableHandlerMethod.invokeAndHandle(ServletInvocableHandlerMethod.java:104)
    at
org.springframework.web.servlet.mvc.method.annotation.RequestMappingHandlerAdapter.invokeHandleMethod(RequestMappingHandlerAdapter.java:745)
    at
org.springframework.web.servlet.mvc.method.annotation.RequestMappingHandlerAdapter.handleInternal(RequestMappingHandlerAdapter.java:686)
    at
org.springframework.web.servlet.mvc.method.AbstractHandlerMethodAdapter.handle(AbstractHandlerMethodAdapter.java:80)
    at
org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:925)
    at
jeeves.config.springutil.JeevesDispatcherServlet.access$001(JeevesDispatcherServlet.java:17)
    at
jeeves.config.springutil.JeevesDispatcherServlet$1.doInTransaction(JeevesDispatcherServlet.java:30)
    at
jeeves.config.springutil.JeevesDispatcherServlet$1.doInTransaction(JeevesDispatcherServlet.java:27)
    at
    at
jeeves.config.springutil.JeevesDispatcherServlet.doDispatch(JeevesDispatcherServlet.java:24)
    at
org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:856)
    at
org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:936)
    at
org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:827)
    at javax.servlet.http.HttpServlet.service(HttpServlet.java:735)
    at
org.springframework.web.servlet.FrameworkServlet.service(FrameworkServlet.java:812)
    at javax.servlet.http.HttpServlet.service(HttpServlet.java:848)
    at
org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:684)
    at
org.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1496)
    at
org.fao.geonet.monitor.webapp.WebappMetricsFilter.doFilter(WebappMetricsFilter.java:96)
    at
org.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1484)
    at
org.fao.geonet.monitor.webapp.MetricsRegistryInitializerFilter.doFilter(MetricsRegistryInitializerFilter.java:31)
    at
    at
org.tuckey.web.filters.urlrewrite.RuleChain.handleRewrite(RuleChain.java:176)
    at
org.tuckey.web.filters.urlrewrite.RuleChain.doRules(RuleChain.java:145)
    at
org.tuckey.web.filters.urlrewrite.UrlRewriter.processRequest(UrlRewriter.java:92)
    at
org.tuckey.web.filters.urlrewrite.UrlRewriteFilter.doFilter(UrlRewriteFilter.java:381)
    at
    at
org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:330)
    at
org.springframework.security.web.access.intercept.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:118)
    at
org.springframework.security.web.access.intercept.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:84)
    at
org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:342)
    at
org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:113)
    at
    at
org.springframework.security.web.session.SessionManagementFilter.doFilter(SessionManagementFilter.java:103)
    at
    at
org.springframework.security.web.authentication.AnonymousAuthenticationFilter.doFilter(AnonymousAuthenticationFilter.java:113)
    at
    at
org.springframework.security.web.savedrequest.RequestCacheAwareFilter.doFilter(RequestCacheAwareFilter.java:45)
    at
    at
org.springframework.security.web.authentication.AbstractAuthenticationProcessingFilter.doFilter(AbstractAuthenticationProcessingFilter.java:183)
    at
    at
org.springframework.security.web.authentication.www.BasicAuthenticationFilter.doFilter(BasicAuthenticationFilter.java:150)
    at
    at
jeeves.config.springutil.PassthroughFilter.doFilter(PassthroughFilter.java:26)
    at
    at
jeeves.config.springutil.MultiNodeAuthenticationFilter.doFilter(MultiNodeAuthenticationFilter.java:98)
    at
    at
org.springframework.security.web.authentication.logout.LogoutFilter.doFilter(LogoutFilter.java:105)
    at
    at
org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:87)
    at
    at
org.springframework.security.web.FilterChainProxy.doFilterInternal(FilterChainProxy.java:192)
    at
org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:160)
    at
org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:343)
    at
org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:260)
    at
jeeves.config.springutil.JeevesDelegatingFilterProxy.doFilter(JeevesDelegatingFilterProxy.java:64)
    at
    at
org.springframework.web.filter.CharacterEncodingFilter.doFilterInternal(CharacterEncodingFilter.java:88)
    at
org.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:107)
    at
org.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1476)
    at
org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:501)
    at
org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:137)
    at
org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:533)
    at
org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:231)
    at
org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1086)
    at
org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:429)
    at
org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:193)
    at
org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1020)
    at
org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:135)
    at
org.eclipse.jetty.server.handler.ContextHandlerCollection.handle(ContextHandlerCollection.java:255)
    at
org.eclipse.jetty.server.handler.HandlerCollection.handle(HandlerCollection.java:154)
    at
org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:116)
    at org.eclipse.jetty.server.Server.handle(Server.java:370)
    at
org.eclipse.jetty.server.AbstractHttpConnection.handleRequest(AbstractHttpConnection.java:494)
    at
org.eclipse.jetty.server.AbstractHttpConnection.headerComplete(AbstractHttpConnection.java:971)
    at
org.eclipse.jetty.server.AbstractHttpConnection$RequestHandler.headerComplete(AbstractHttpConnection.java:1033)
    at org.eclipse.jetty.http.HttpParser.parseNext(HttpParser.java:644)
    at org.eclipse.jetty.http.HttpParser.parseAvailable(HttpParser.java:235)
    at
org.eclipse.jetty.server.AsyncHttpConnection.handle(AsyncHttpConnection.java:82)
    at
org.eclipse.jetty.io.nio.SelectChannelEndPoint.handle(SelectChannelEndPoint.java:696)
    at
org.eclipse.jetty.io.nio.SelectChannelEndPoint$1.run(SelectChannelEndPoint.java:53)
    at
org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:608)
    at
org.eclipse.jetty.util.thread.QueuedThreadPool$3.run(QueuedThreadPool.java:543)
    at java.lang.Thread.run(Unknown Source)
Any ideas? I have wasted already two days trying to solve this, but nothing
works. I tried re-building the index and deleting all database lock files.
I tried defining the data directory in config.xml. I checked srv.xml and h2
database configuration line is uncommented by default.
Pekka
Hello,
I solved it. The problem was that I was totally unaware that the actual h2
database files are *not* in the geonetwork data folder, but in my case in
the jetty folder (...\geonetwork\jetty). By copying the backed-up *.db files
back there I was able to restore my database. Quite confusing, though. Hope
this helps someone with similar problems.
Pekka
Pekka wrote
Dear list,
the
with only 2 GB RAM.
upgrade.
start.jar
however:
Catalog information
Database
System information
Total memory 253440
gml:VerticalDatum
gml:VerticalCS
service
transaction
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
nothing
h2
Pekka
GeoNetwork-users mailing list
GeoNetwork-users@anonymised.com
View this message in context: http://osgeo-org.1560.x6.nabble.com/Fwd-h2-database-issues-when-migrating-from-3-0-0-to-3-0-1-tp5218721p5218910.html
2015-08-07 14:17 GMT+02:00 Pekka <pekka.hurskainen@anonymised.com>:
Hello,
files
Added to the doc
https://github.com/geonetwork/doc/blob/5a16d2b54345c08b0fd94ad4a0fc01e61f29b508/en/maintainer-guide/installing/configuring-database.rst
(which is currently being updated).
Francois
Pekka
Pekka wrote
> Dear list,
> the
> with only 2 GB RAM.
> upgrade.
> start.jar
> however:
> Catalog information
> Database
> System information
> Total memory 253440
> gml:VerticalDatum
> gml:VerticalCS
> service
> transaction
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> nothing
files.
> h2
> Pekka
