[GeoNetwork-users] Harvest ArcSDE from GeoNetwork 2.6.0
For some reason, I'm unable to configure ArcSDE harvesting in GeoNetwork 2.6.0. I get a javascript error in harvester-view.js when I select "ArcSDE Server" + "Add" on the "Harvesting management" page of admin. I have tried this in both Firefox and IE, and I get the same error. Has anyone successfully set up ArcSDE harvesting in GeoNetwork 2.6.0?
Best regards,
Mikael
Mikael Elmquist
Regionchef
Göteborg
Telefon direkt 031-62 76 63
Mobil 070-605 01 61
Telefax 031-62 77 22
mikael.elmquist@anonymised.com
Sweco Position AB
Gullbergs Strandgata 3
Box 2203
403 14 Göteborg
Telefon 031-62 75 00
www.sweco.se<http://www.sweco.se>
[cid:image001.png@anonymised.com]
[cid:image002.png@anonymised.com]Please consider the environment before printing my e-mail.
(attachments)
hi,
what is the error you're getting ?
Some days ago someone was unable to save Settings (in the System
Configuration page). Harvester configurations are stored in the same table
"Settings" that that page operates on. Could you verify whether you can
change any value in the System Configuration page and successfully save
that, or not ? If not, it's probably some inconsistency in the content of
the Settings table.
Kind regards
Heikki Doeleman
On Mon, Sep 27, 2010 at 6:56 PM, Elmquist Mikael
<Mikael.Elmquist@anonymised.com>wrote:
Best regards,
Mikael
Mikael Elmquist
Regionchef
Göteborg
Mobil 070-605 01 61
Sweco Position AB
Box 2203
403 14 Göteborg
printing my e-mail.
Start uncovering the many advantages of virtual appliances
and start using them to simplify application deployment and
accelerate your shift to cloud computing.
http://p.sf.net/sfu/novell-sfdev2dev
GeoNetwork-users mailing list
Well, the error I get is:
Message: 'null' is null or not an object
Line: 64
Char: 2
Code: 0
URI: http://localhost:8080/geonetwork/scripts/harvesting/harvester-view.js
I tried to comment out some lines in harvester-view.js and was able to display the settings page for ArcSDE harvesting. When I tried to save, I got another JS error instead. I didn't go any further than this. Something must be wrong in 2.6. Can anyone setup ArcSDE harvesting, or even get to the settings page for ArcSDE harvesting?
I also had a quick look in the settings-table and find the structure a bit do hard to edit myself that way.
Mikael
Mikael Elmquist
Regionchef
Göteborg
Mobil 070-605 01 61
Sweco Position AB
Box 2203
403 14 Göteborg
Från: heikki [mailto:tropicano@anonymised.com]
Skickat: den 27 september 2010 19:02
Till: Elmquist Mikael
Kopia: geonetwork-users@lists.sourceforge.net
Ämne: Re: [GeoNetwork-users] Harvest ArcSDE from GeoNetwork 2.6.0
hi,
Some days ago someone was unable to save Settings (in the System Configuration page). Harvester configurations are stored in the same table "Settings" that that page operates on. Could you verify whether you can change any value in the System Configuration page and successfully save that, or not ? If not, it's probably some inconsistency in the content of the Settings table.
Kind regards
Heikki Doeleman
On Mon, Sep 27, 2010 at 6:56 PM, Elmquist Mikael <Mikael.Elmquist@anonymised.com<mailto:Mikael.Elmquist@anonymised.com>> wrote:
Best regards,
Mikael
Mikael Elmquist
Regionchef
Göteborg
Mobil 070-605 01 61
mikael.elmquist@anonymised.com<mailto:mikael.elmquist@anonymised.com>
Sweco Position AB
Box 2203
403 14 Göteborg
www.sweco.se<http://www.sweco.se><http://www.sweco.se>
GeoNetwork-users@lists.sourceforge.net<mailto:GeoNetwork-users@anonymised.comforge.net>
(attachments)
