Hi
What is the url configured in the harvester?
Check the url points the capabilities document in the remote server. For
example, if the remote server is a GeoNetwork also:
http://*SERVER*
/srv/eng/csw?service=CSW&version=2.0.2&request=GetCapabilities
Jose García
On Thu, Jan 30, 2014 at 11:41 AM, umut <umut_salur@anonymised.com> wrote:
Yes, I used Catalog Services for the
Web ISO Profile 2.0 , and log int tomcat same
<csw:GetRecords xmlns:csw="http://www.opengis.net/cat/csw/2.0.2"
xmlns:dc="http://purl.org/dc/elements/1.1/" service="CSW" version="2.0.2"
resultType="results" outputFormat="application/xml"
outputSchema="http://www.isotc211.org/2005/gmd" startPosition="1"
maxRecords="20">
<csw:Query typeNames="gmd:MD_Metadata,csw:Record">
<csw:ElementSetName>summary</csw:ElementSetName>
</csw:Query>
</csw:GetRecords>
2014-01-30 11:36:12,560 DEBUG [geonetwork.harvester] - Search results:
<html xmlns="http://www.w3.org/1999/xhtml">
<head>
<meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1"
<title>404 - File or directory not found.</title>
</head>
<body>
<div id="header">
Server Error
</div>
<div id="content">
<div class="content-container">
<fieldset>
The resource you are looking for might have been removed, had its name
changed, or is temporarily unavailable.
</fieldset>
</div>
</div>
</body>
</html>
2014-01-30 11:36:12,560 DEBUG [geonetwork.harvester] - Number of child
elements in response: 2
2014-01-30 11:36:12,560 WARN [geonetwork.harvester] - Raised exception
while harvesting from : Test Orman su (CswHarvester)
2014-01-30 11:36:12,560 WARN [geonetwork.harvester] - (C) Class :
OperationAbortedEx
2014-01-30 11:36:12,560 WARN [geonetwork.harvester] - (C) Message :
Missing 'SearchResults'
regards.
View this message in context:
http://osgeo-org.1560.x6.nabble.com/Harvest-From-CSW-Service-tp5100870p5100882.html
WatchGuard Dimension instantly turns raw network data into actionable
security intelligence. It gives you real-time visual feedback on key
security issues and trends. Skip the complicated setup - simply import
a virtual appliance and go from zero to informed in seconds.
http://pubads.g.doubleclick.net/gampad/clk?id=123612991&iu=/4140/ostg.clktrk
GeoNetwork-users mailing list
* GeoCat Bridge for ArcGIS allows instant publishing of data and metadata
on GeoServer and GeoNetwork. Visit http://geocat.net
<http://geocat.net/> for details. _________________________Jose
GarcíaGeoCat bvVeenderweg 13 6721 WD BennekomThe
Netherlandshttp://GeoCat.net/> *
