[GeoNetwork-users] harvest from directory validation
I'm getting to know the various harvesting methods. I successfully harvested
records from GeoServer (inspire enabled) using the Harvest from --> OGC Web
Services. That was easy!
Using /Harvest from --> Directory/, however, I get mixed results. I have a
question on this:
1. At times harvesting XML metadata files returns a /badFormat/ message in
the Harvester history, even if the harvester is set to /Accept all metadata
without validation/ and XML syntax is correct. What else could raise a
/badFormat/? Strangely enough when uploading the same XML files using
/Contribute --> Import new records/ I don't get any errors, they upload just
fine. Why is that?
2. bonus question Can I edit harvested records within the catalogue?
Logically this shouldn’t be allowed as it would create discrepancies between
metadata source and the catalogue and in any case they would be restated at
the next scheduled harvesting.... Is my assumption correct?
Thanks for taking the time reading my questions.
Armando
Sent from: http://osgeo-org.1560.x6.nabble.com/GeoNetwork-users-f3860293.html
