[GeoNetwork-users] HARVEST problem - BAD XML FORMAT error
I have the following problem:
I have created a xml file by means of an XSL transformation. This file satisfies all the recommendations ISO 19115/19119, the INSPIRE implementing rules and the GeoNetwork recommendations as obtained performing the CHECK.
When I try to harvest this file using the harvesting task I got the error BAD XML FORMAT.
I checked some online validator for XML and I got no error in my xml but I'm still not able to harvest my file.
Could you please tell me any possible solution to this error? Am' I doing something wrong?
thanks in advance
ciao
Bart
_ _
Dr. Ventura Bartolomeo
Institute for Applied Remote Sensing
Technology for Environmental Monitoring
EURAC research
Viale Druso 1, I-39100 Bolzano, Italy
t +39 0471 055 374
f +39 0471 055 389
bartolomeo.ventura@anonymised.com<mailto:bartolomeo.ventura@anonymised.com>
www.eurac.edu<http://www.eurac.edu/&gt;
This transmission is intended only for the use of the addressee and may contain confidential or legally privileged information.
If you receive this transmission by error, please notify the author immediately by mail and delete all copies of this transmission and any attachments.
Any use or dissemination of this communication is strictly prohibited by the "Privacy-Code", D.Lgs. 196/2003 and may lead to penal prosecution and liability for damages.
P Think before you print
