When setting up harvesting you can set up various terms for filtering using
existing as keywords, title, abstract etc.
I have two queries on this
1
Is it possible to be more exact and set a filter for a keyword that exists
within a specific thesaurus?
Right now you can only set filter keywords in general.
2
In version 2.8 you can also assign a xsl for doing some processing.
With this more advanced queries could be set to select specifc records
Eg only process records having a specific keyword and insde a specifc
dateintervall
Can this processing-functions also be used to filter records that should
harvested?
So the process should actually delete havesretd records if they do not
fulfill the expression.
It would though be best if they never got into the database at all so that
the processing take plave before data are inserted into DB
/Michael
View this message in context: http://osgeo-org.1560.n6.nabble.com/Harvest-with-combination-of-thesaurusname-keyword-tp5007013.html
