[GeoNetwork-users] Harvesting a GeoServer as WFS
Hello GeoNetwork Team,
I evaluate GeoNetwork and GeoServer for the first time. And I tried to harvest GeoServer as a WFS:
The main parameters of harvesting management are:
Type of OGC webservice: WFS 1.1.0
Service URL: http://localhost:8081/geoserver/wfs?service=wfs&version=1.1.0&request=GetCapabilities
All happened well. I can view the service on main.home page; but there is no outline of the content of the FeatureTypeList elements from Capabilities document?
Where is FeatureTypeList? Please help me to master this problem!
Best Regards
Roland
_____________________________________________________
Dr. Roland Minde
Air Traffic Control & Business Systems GmbH
Hauptstraße 30
88677 Markdorf
Germany
email: Roland.Minde@anonymised.com<mailto:Roland.Minde@anonymised.com>
phone: +49 7544 5095 36
fax: +49 7544 5095 99
home: www.ac-b.de<../../../../../../Dokumente%20und%20Einstellungen/rminde/Anwendungsdaten/Microsoft/Signatures/www.ac-b.de>
Registered Office: Markdorf
Managing Directors: Javier Ruano, Lucio Galindo
Registration Court: Freiburg HRB 581472
______________________________________________________
Hi Roland,
I think, that geonetwork only harvests the metadata and converts it into ISO19139 documents. Maybe it is able to generate the metadata from the single featuretype objects or their corresponding MetadataURL elements - if given :frowning: . This is the behaviour as it is done for wms layer (see the harvesting admin interface).
Geonetwork is a metadata broker and it does what a metadata broker should do: manage metadata :wink: .
If you need an other solution, you may have a look at http://www.mapbender.org - it can handle featuretypes and you can export the metadata to geonetwork nodes to use its csw interface.
Best regards
Armin
Best Regards
Roland
Dr. Roland Minde
Hauptstraße 30
88677 Markdorf
Germany
Managing the Performance of Cloud-Based Applications
Take advantage of what the Cloud has to offer - Avoid Common Pitfalls.
Read the Whitepaper.
http://pubads.g.doubleclick.net/gampad/clk?id=121051231&iu=/4140/ostg.clktrk
GeoNetwork-users mailing list
Zentrale Stelle Geodateninfrastruktur
Rheinland-Pfalz
LVermGeo-RP
Ferdinand-Sauerbruch-Straße 15
56073 Koblenz
0261/492-466
armin.retterath@anonymised.com
http://www.geoportal.rlp.de
Hello Armin,
Harvesting means to read a Capabilities document, and it contains a metadata
triple: name, title, abstract not only for the service, but also for each
feature; and I expect to get this data presented too.Why does GeoNetwork not
show the metadata of the features: is it a bug or a lack or is it
philosophy?Best RegardsRoland
View this message in context: http://osgeo-org.1560.x6.nabble.com/Harvesting-a-GeoServer-as-WFS-tp5102853p5105463.html
