Dear colleagues,
I'm doing some tests with harvesting in GeoNetwork 2.2, in order to try real
interoperability.
I've managed to harvest data from other GeoNetwork nodes.
But now I'm not suceeding in harvesting data from CSW servers (ESRI,
GeoNetwork CSW, Ionic as suggested in previous posts, ...). The error I'm
getting when all the required operations are mentioned in the capabilities
is the following:
"OperationAbortedEx : Raised exception when searching"
Question 1: Harvesting only works with CSW 2.0.1 as red in the past?
Question 2: Could anyone specify any CSW server for test harvesting? I've
run out of ideas/links for continuing my tests.
Thanks in advance,
Oscar Gomez
View this message in context: http://www.nabble.com/Harvesting-CSW-2.0-tp17106186p17106186.html
Sent from the geonetwork-users mailing list archive at Nabble.com.
CSW is highly version-specific and many (most?) servers reject a client requesting anything but the particular version they support. In my experience, not many CSW servers are backwards compatible.
The next version of GN will support CSW 2.0.2 (it's already checked into subversion but is _not_ in GN 2.2).
Running CSW 2.0.1? I'm not sure who's still running that version. Maybe someone here will volunteer. I've got a 2.0.2 server running as a demo.
Archie
-- Archie Warnock warnock@anonymised.com
-- A/WWW Enterprises www.awcubed.com
-- As a matter of fact, I _do_ speak for my employer.
Hi Archie,
Finally I managed to harvest from one server:
http://www.geodata.alterra.nl/excat/csw?request=GetCapabilities&service=CSW
CSW 2.0.2, and I guess they might be using GeoNetwork 2.x. I don't know why
this worked and other GNs didn't (as CSW).
Any other server I've tried (deegree, ArcIMS, Ionic, ...) failed, most of
them with an exception when searching. Other servers failed because of the
Capabilities document.
Regarding your server, yes, I tried it, but it failed too. How did I manage
to find your server? Just searched in Google "inurl:GetCapabilities + csw"
Greeting from Spain,
Oscar
Archie
Hi Oscar,
I assume you are using Gn 2.2.0 and not a version you build using the code in Subversion? The code in subversion has the CSW 2.0.2 code as Archie wrote previously and I would suggest to check that out and test using that code if CSW 2.0.2 is a high priority for you.
Ciao
Jeroen
On May 8, 2008, at 9:28 AM, Oscar Gomez wrote:
Hi Archie,
Oscar
Archie
This SF.net email is sponsored by the 2008 JavaOne(SM) Conference
Don't miss this year's exciting event. There's still time to save $100.
Use priority code J8TL2D2.
http://ad.doubleclick.net/clk;198757673;13503038;p?http://java.sun.com/javaone
GeoNetwork-users mailing list
geonetwork-users List Signup and Options
GeoNetwork OpenSource is maintained at GeoNetwork - Geographic Metadata Catalog download | SourceForge.net
Hi Jeroen,
Yes, I'm using GN 2.2.0.
I will test the code in Subversion as you suggest. My priority is just
interoperability, so I need to try 2.0.2 too.
Thanks for the tip, I'll come back with the results.
Best,
Oscar
On 5/8/08, Jeroen Ticheler <Jeroen.Ticheler@anonymised.com> wrote:
Hi Oscar,
Ciao
Jeroen
Hi Archie,
why
manage
Oscar
Archie
I think that's a good strategy. Many of the changes from 2.0.1 to 2.0.2 were to remove ambiguities and improve interoperability. I think it's a more reliably useful version of the protocol.
Please let me know how it works for you.
Archie
Hi Archie,
YES, it worked. I built geonetwork from the code on subversion. Now I can
harvest from your node, CSW 2.0.2.
*But now, CSW 2.0.1 doesn't work!!!!*
I'm anyway running more tests on other CSW nodes using other software (ESRI,
deegree, ...).
I'm building an "interoperability matrix" that I will share.
But in the meantime, *does anyone know why do I get the error "Missing
'SearchResults'" from harvesting CSW 2.0.2*?
Thanks in advance. Best Regards,
Oscar Gomez
Archie
hi Oscar,
you get that error message "Missing SearchResults" because you're receiving
a message in the CSW 2.0.1 namespace, where GeoNetwork is expecting a
message in the CSW 2.0.2 namespace.
I have put in a fix last Friday such that GeoNetwork will first try a
CSW2.0.2, and if that fails, try CSW2.0.1 namespace. If you use the latest
code from Subversion this problem should disappear.
Kind regards
Heikki Doeleman
On Mon, May 19, 2008 at 8:02 AM, Oscar Gomez <ogomez2@anonymised.com> wrote:
Hi Archie,
(ESRI,
deegree, ...).
Oscar Gomez
> Archie
Defy all challenges. Microsoft(R) Visual Studio 2008.
Inventions cannot, in nature, be a subject of property. -- Thomas Jefferson
Thanks heikki,
I will try it as you suggest.
Greetings from Spain!
Oscar
On 5/19/08, heikki <tropicano@anonymised.com> wrote:
hi Oscar,
Kind regards
Heikki Doeleman
Hi Archie,
(ESRI,
deegree, ...).
Oscar Gomez
> Archie
Oscar Gomez
Visita mi blog!! http://ogomez2.blogspot.com
Hello,
is the export to KML working with WMS-Services?
I have Metadata with a WMS-Services, the export to kml works, I get a textfile with the WMS-Link in it. If load this file to Googelearth I get an error message.
Thanks for helping.
David.
geoinformation+planung
reichert+partner ingenieure
gölzstr. 22 72072 tübingen
fon: +49 (0)7071-407360
fax: +49 (0)7071-407361
info@anonymised.com
http://www.geoinformation-planung.de
Regionalplan Schwarzwald-Baar-Heuberg online: http://www.regionalplan-sbh.de
Do you have more details ? Is the error linked to the WMS services ?
Ciao
Francois
Hi Heikki, hi list,
Yes, now I can harvest 2.0.1 and 2.0.2 (only from other GeoNetwork nodes +
Dutch Excat).
What about 2.0.0? There are a number of CSW servers already running using
CSW 2.0.0 (INSPIRE, NASA, ...)
Best Regards,
Oscar
On 5/19/08, Oscar Gomez <ogomez2@anonymised.com> wrote:
Thanks heikki,
Oscar
hi Oscar,
receiving a message in the CSW 2.0.1 namespace, where GeoNetwork is
expecting a message in the CSW 2.0.2 namespace.
Kind regards
Heikki Doeleman
Hi Archie,
(ESRI,
deegree, ...).
Oscar Gomez
2.0.2
a
> Archie
Jefferson
Oscar Gomez
Oscar Gomez
Hi Oscar,
Both version 2.0.0 and 2.0.1 have lots of issues that make it really hard to get good interoperable systems. So we decided to drop support for those altogether. This should make life less complex for us in the future, except for telling people they should not expect these versions of CSW to work
Jeroen
On May 21, 2008, at 4:30 PM, Oscar Gomez wrote:
Hi Heikki, hi list,
Dutch Excat).
Best Regards,
Oscar
Thanks heikki,
Oscar
hi Oscar,
Kind regards
Heikki Doeleman
Hi Archie,
(ESRI,
deegree, ...).
Oscar Gomez
2.0.2
a
Archie
Jefferson
Oscar Gomez
Oscar Gomez
Thanks Jeroen,
So what you suggest is trying to live just with version 2.0.2, right?
That could be ok with me (in fact the project I'm working in is looking more
to the future than to the past).
Do you think that interoperability with other platforms different than
GeoNetwork will be possible from CSW 2.0.2 onwards?
Could anyone suggest CSW 2.0.2 servers, not using GeoNetwork, in order to
try interoperability?
Best Regards,
Oscar
On 5/21/08, Jeroen Ticheler <Jeroen.Ticheler@anonymised.com> wrote:
Hi Oscar,
Jeroen
Hi Heikki, hi list,
Dutch Excat).
Best Regards,
Oscar
Thanks heikki,
Oscar
hi Oscar,
latest
Kind regards
Heikki Doeleman
Hi Archie,
can
(ESRI,
deegree, ...).
Oscar Gomez
2.0.2
a
Archie
Jefferson
Oscar Gomez
Oscar Gomez
Hello,
is it possible to get this patch in the stable Geonetwork 2.2.0?
Thanks, David.
Quoting heikki <tropicano@anonymised.com>:
hi Oscar,
Kind regards
Heikki Doeleman
Hi Archie,
(ESRI,
deegree, ...).
Oscar Gomez
> Archie
info@anonymised.com
