I'm having trouble harvesting from an ArcSDE on my server. I have the jars
installed and an ArceSDE service running but the error log indicates I have
no instance running. Any help would be much appreciated!
0 Connection refused: connect
NO INSTANCE RUNNING ON SERVER.
2016-11-01 15:25:10,467 WARN [WMS] - Raised exception while harvesting from
: WMS (ArcSDEHarvester)
2016-11-01 15:25:10,467 WARN [WMS] - (C) Class :
ExceptionInInitializerError
2016-11-01 15:25:10,467 WARN [WMS] - (C) Message : null
2016-11-01 15:25:14,008 WARN [geonetwork.resources] - Resource not found
images/harvesting/, default resource returned: /images/harvesting/
First post!
Recently installed 2.10 with 3.02 “angular” interface on a Linux RedHat server
1) Trying to change the default layout for sections within a tab
Noticed that the layout is managed by localhost:8080/geonetwork/static/gn_editor.css
Can someone tell me where to find gn_editor.css?
2) There appear to be a range of directives that are generally used
I would like to add two in parallel with the directive for selecting a cit:party (ISO19115-3)
manage phone numbers
manage contact information
Can someone tell me where to find the directives themselves?
On Thu, Nov 3, 2016 at 9:34 AM, ebleys@anonymised.com <ebleys@anonymised.com> wrote:
First post!
server
This file afaik is created from a less file
(geonetwork/catalog/style/gn_editor.css), it's generated by wro4j. You'll
have to do the changes in that file.
Evert
Developer Access Program for Intel Xeon Phi Processors
Access to Intel Xeon Phi processor-based developer platforms.
With one year of Intel Parallel Studio XE.
Training and support from Colfax.
Order your platform today. http://sdm.link/xeonphi
GeoNetwork-users mailing list
GeoNetwork-users@lists.sourceforge.net https://lists.sourceforge.net/lists/listinfo/geonetwork-users
GeoNetwork OpenSource is maintained at http://sourceforge.net/
projects/geonetwork
In previous mail, when pointed to geonetwork/catalog/style/gn_editor.css,
should be geonetwork/catalog/style/gn_editor.less
On Thu, Nov 3, 2016 at 9:42 AM, Jose Garcia <jose.garcia@anonymised.com> wrote:
Hi
See feedback inline.
Jose García
First post!
server
ic/gn_editor.css
This file afaik is created from a less file (geonetwork/catalog/style/gn_editor.css),
it's generated by wro4j. You'll have to do the changes in that file.
Evert
GeoNetwork OpenSource is maintained at http://sourceforge.net/project
s/geonetwork
2. Not sure what you're talking about.
But for each schema (ie iso115-3), you have a file that config the editor,
you can add matches between metadata elements and angular directives.
See
First post!
server
Evert
GeoNetwork-users@lists.sourceforge.net geonetwork-users List Signup and Options
projects/geonetwork
*camptocamp*
INNOVATIVE SOLUTIONS
BY OPEN SOURCE EXPERTS
