[GeoNetwork-users] Harvesting from Geonetwork 3 to Geonetwork 2
Hello,
I'm using Geonetwork 2, I want to know if it's possible make a harvest from
a Geonetwork 3 installation.
Kind regards
Darwin Quispe
View this message in context: http://osgeo-org.1560.x6.nabble.com/Harvesting-from-Geonetwork-3-to-Geonetwork-2-tp5289835.html
Hi Darwin,
You can always use the CSW harvester.
But if your GeoNetwork 3 is using the srv default node, then it should
be possible to harvest it with a GeoNetwork harvester. It depends on
your exact version of GeoNetwork. Have you tried and didn't work?
María.
On Fri, Oct 7, 2016 at 10:26 PM, Darwin <darwinquill@anonymised.com> wrote:
Hello,
Kind regards
Darwin Quispe
Check out the vibrant tech community on one of the world's most
engaging tech sites, SlashDot.org! http://sdm.link/slashdot
GeoNetwork-users mailing list
Kind regards,
María Arias de Reyna Domínguez
Veenderweg 13
6721 WD Bennekom
The Netherlands
T: +31 (0)318 416664
Please consider the environment before printing this email.
Hello María
Thanks for the response, I've tried but it didn't work. I'm using
Geonetwork 2.10.3 and I want to harvest from Geonetwork 3 nodes but I can't
get it.
Using the option "GeoNetwork v2.1 remote node" and using the URL
http://mtcgeo2.mtc.gob.pe:8080/geonetwork/ I get this error: "Class:
NullPointerException"
http://mtcgeo2.mtc.gob.pe:8080/geonetwork/srv/spa/catalog.search#/home
I get this error:
Error: HTTP Status 404 - Description: The requested resource is not
available.
Class: BadXmlResponseEx
Using the option "Catalogue Services for the Web ISO Profile 2.0 manda el
error:" (It is the CSW harvester? or I'm wrong?)
I get this error:
Unable to add a new entry
Error : error
Message :
Class : NullPointerException
Which option should I use and what could be the correct URL?
Thanks in advance.
Kind regards
On Mon, Oct 10, 2016 at 1:06 AM, Maria Arias de Reyna <
maria.arias@anonymised.com> wrote:
Hi Darwin,
María.
> Hello,
from
> Kind regards
> Darwin Quispe
projects/geonetwork
Kind regards,
Veenderweg 13
6721 WD Bennekom
The Netherlands
Hi
For CSW, try with this:
http://mtcgeo2.mtc.gob.pe:8080/geonetwork/srv/eng/csw?request=GetCapabilities&service=CSW&version=2.0.2
Jose García
On Thu, Oct 13, 2016 at 10:08 PM, Darwin Denis Quispe Llancacuro <
Hello María
get it.
I get this error:
available.
I get this error:
Error : error
Message :
Thanks in advance.
Kind regards
> Hi Darwin,
> Regards,
> María.
> > Hello,
> from
> > Kind regards
> > Darwin Quispe
> > _______________________________________________
> projects/geonetwork
> Kind regards,
> Veenderweg 13
> 6721 WD Bennekom
> The Netherlands
projects/geonetwork
*Vriendelijke groeten / Kind regards,Jose García
<http://www.geocat.net/&gt;Veenderweg 136721 WD BennekomThe NetherlandsT: +31
(0)318 416664 <+31318416664> <https://www.facebook.com/geocatbv&gt;
<https://twitter.com/geocat_bv&gt;
<https://plus.google.com/u/1/+GeocatNetbv/posts&gt;Please consider the
environment before printing this email.*
Hi Jose, María
Thanks for the help, I found the solution to the error message "Unable to
add new entry" following the recommendations you suggested in
https://sourceforge.net/p/geonetwork/mailman/message/32734553/
In addition, the harvest works using CSW / ISO 2.0, although in the case of
the MTC link nothing was harvested but I tried with another node harvest
was successful.
Thanks again and best regards.
Darwin
On Mon, Oct 17, 2016 at 12:18 AM, Jose Garcia <jose.garcia@anonymised.com>
wrote:
Hi
Jose García
Hello María
can't
get it.
I get this error:
available.
I get this error:
Error : error
Message :
Thanks in advance.
Kind regards
> Hi Darwin,
> Regards,
> María.
> > Hello,
> from
> > Kind regards
> > Darwin Quispe
> projects/geonetwork
> Kind regards,
> Veenderweg 13
> 6721 WD Bennekom
> The Netherlands
s/geonetwork
