Hello all!
i am trying to harvest metadata from a geoserver(2.11.x) wfs with
geonetwork(3.4.0) using the following GetFeature-Request:
<wfs:GetFeature xmlns:wfs="http://www.opengis.net/wfs" service="WFS"
version="1.1.0">
<wfs:Query typeName="namespace:layer" />
</wfs:GetFeature>
The harvester drops the following error message:
bad-xml-response
an hour ago
No response or problem getting response from
https://url/geoserver/namespace/wfs?: <wfs:GetFeature xmlns:wfs="
http://www.opengis.net/wfs" service="WFS" version="1.1.0"> <wfs:Query
typeName="namespace:layer" /> </wfs:GetFeature>org.fao.geonet.kernel.harvest.harvester.wfsfeatures.Harvester Harvester.java (247) #harvestResponseorg.fao.geonet.kernel.harvest.harvester.wfsfeatures.Harvester Harvester.java (229) #harvestorg.fao.geonet.kernel.harvest.harvester.wfsfeatures.WfsFeaturesHarvester WfsFeaturesHarvester.java (151) #doHarvestorg.fao.geonet.kernel.harvest.harvester.AbstractHarvester$HarvestWithIndexProcessor AbstractHarvester.java (649) #processorg.fao.geonet.kernel.harvest.harvester.AbstractHarvester AbstractHarvester.java (721) #harvestorg.fao.geonet.kernel.harvest.harvester.HarvesterJob HarvesterJob.java (57) #executeorg.quartz.core.JobRunShell JobRunShell.java (213) #runorg.quartz.simpl.SimpleThreadPool$WorkerThread SimpleThreadPool.java (557) #run
if i use wget to check the request with the getfeature statement in a
file, a response is generated:
wget --http-user=me --http-passwd=mypass --post-file=wfs_request.xml -O
output.xml --header="Content-Type: text/xml"
So where and what am i doing wrong?
Thank you in advance
Uwe Seher
