Hello all!
i am trying to harvest metadata from a geoserver(2.11.x) wfs with
geonetwork(3.4.0) using the following GetFeature-Request:
<wfs:GetFeature xmlns:wfs="http://www.opengis.net/wfs
<http://www.opengis.net/wfs>" service="WFS" version="1.1.0">
<wfs:Query typeName="namespace:layer" />
</wfs:GetFeature>
The harvester drops the following error message:
bad-xml-response
an hour ago
No response or problem getting response from
https://url/geoserver/namespace/wfs
<https://url/geoserver/namespace/wfs>?: <wfs:GetFeature
xmlns:wfs="http://www.opengis.net/wfs"
service="WFS" version="1.1.0"> <wfs:Query typeName="namespace:layer" />
</wfs:GetFeature>
org.fao.geonet.kernel.harvest.
harvester.wfsfeatures.Harvester Harvester.java (247) #harvestResponse
org.fao.geonet.kernel.harvest.harvester.wfsfeatures.Harvester
Harvester.java (229) #harvest
org.fao.geonet.kernel.harvest.harvester.wfsfeatures.WfsFeaturesHarvester
WfsFeaturesHarvester.java (151) #doHarvest
org.fao.geonet.kernel.harvest.harvester.AbstractHarvester$HarvestWithIndexProcessor
AbstractHarvester.java (649) #process
AbstractHarvester.java (721) #harvest
org.fao.geonet.kernel.harvest.harvester.HarvesterJob HarvesterJob.java
(57) #execute
org.quartz.core.JobRunShell JobRunShell.java (213) #run
org.quartz.simpl.SimpleThreadPool$WorkerThread SimpleThreadPool.java
(557) #run
if i use wget to check the request with the getfeature statement in a
file, a response is generated:
wget --http-user=me --http-passwd=mypass --post-file=wfs_request.xml
-O output.xml --header="Content-Type: text/xml"
https://url/geoserver/namespace/wfs?
So where and what am i doing wrong?
Thank you in advance
_____________________________________
ingenieurbüro kauppert
nebeniusstr. 34
d-76137 karlsruhe
fon +49 721 3548969-3
fax +49 721 3548969-5
email uwe.seher@anonymised.com
web www.ib-kauppert.de
