Hello all!
i am trying to harvest metadata from a geoserver(2.11.x) wfs with
geonetwork(3.4.0) using the following GetFeature-Request:
<wfs:GetFeature xmlns:wfs="http://www.opengis.net/wfs" service="WFS" version="1.1.0">
<wfs:Query typeName="namespace:layer" />
</wfs:GetFeature>
The harvester drops the following error message:
bad-xml-response
an hour ago
No response or problem getting response from https://url/geoserver/namespace/wfs?: <wfs:GetFeature xmlns:wfs="http://www.opengis.net/wfs" service="WFS" version="1.1.0"> <wfs:Query typeName="namespace:layer" /> </wfs:GetFeature>
org.fao.geonet.kernel.harvest.harvester.wfsfeatures.Harvester Harvester.java (247) #harvestResponse
org.fao.geonet.kernel.harvest.harvester.wfsfeatures.Harvester Harvester.java (229) #harvest
org.fao.geonet.kernel.harvest.harvester.wfsfeatures.WfsFeaturesHarvester WfsFeaturesHarvester.java (151) #doHarvest
org.fao.geonet.kernel.harvest.harvester.AbstractHarvester$HarvestWithIndexProcessor AbstractHarvester.java (649) #process
org.fao.geonet.kernel.harvest.harvester.AbstractHarvester AbstractHarvester.java (721) #harvest
org.fao.geonet.kernel.harvest.harvester.HarvesterJob HarvesterJob.java (57) #execute
org.quartz.core.JobRunShell JobRunShell.java (213) #run
org.quartz.simpl.SimpleThreadPool$WorkerThread SimpleThreadPool.java (557) #run
if i use wget to check the request with the getfeature statement in a
file, a response is generated:
wget --http-user=me --http-passwd=mypass --post-file=wfs_request.xml -O output.xml --header="Content-Type: text/xml" https://url/geoserver/namespace/wfs?
So where and what am i doing wrong?
Thank you in advance
Hi, what are you trying to do - create metadata records for each feature
types or create directory based on features ?
If it is feature type, then you have to use the OGC service harvester and
choose WFS for protocol. That harvester support WMS/WCS/WFS/WPS. The other
one about WFSFeature is using Stylesheet to create fragments and may
require some advanced config (and I don't really know how to help on this).
HTH.
Francois
Le ven. 14 déc. 2018 à 07:34, Uwe Seher <uwe.seher@anonymised.com> a écrit :
Hello all!
version="1.1.0">
> </wfs:GetFeature>
> bad-xml-response
> an hour ago
(57) #execute
(557) #run
GeoNetwork-users mailing list
Thank you!
I am trying to get metadata
for each feature in a WFS. We have some tracking data from vessels in
a layer or a layer with project-areas for which i want to create a
metadata-record for each feature.
So i need to dive a little deeper.
Best regards
Uwe
PS: ust for ininformation: This is the fourth attempt sending a
message to the list. The former three ended up in an automatic mail
response from the IT-Helpdesk for the university of Queensland.
Changing my mailaddress in the list or the client did not help, this
here is written in the google webmailer, like the first attempt. Maybe
this info is helpful for someone
Am Fr., 14. Dez. 2018 um 08:05 Uhr schrieb Francois Prunayre
<fx.prunayre@anonymised.com>:
Hi, what are you trying to do - create metadata records for each feature types or create directory based on features ?
If it is feature type, then you have to use the OGC service harvester and choose WFS for protocol. That harvester support WMS/WCS/WFS/WPS. The other one about WFSFeature is using Stylesheet to create fragments and may require some advanced config (and I don't really know how to help on this).
HTH.
Francois
Hello all!
> </wfs:GetFeature>
> bad-xml-response
> an hour ago
I suppose you already had a look to
https://geonetwork-opensource.org/manuals/trunk/en/user-guide/harvesting/harvesting-wfs-features.html,
and you'll have to create a conversion for your feature into a complete
metadata record. Example provided only create Extent, Contact or keywords I
think.
Francois
Le ven. 14 déc. 2018 à 08:17, Uwe Seher <uwe.seher@anonymised.com> a écrit :
Thank you!
Best regards
Uwe
> HTH.
> Francois
>> Hello all!
version="1.1.0">
>> > </wfs:GetFeature>
>> > bad-xml-response
>> > an hour ago
(557) #run
>> _______________________________________________
