I use GN2.4.2. All harvesting metadata still exist after restarting the
server. The data in c:/geonetwork/data have never been deleted even when I
remove remote node by harvesting management. Are there anybody know why?
View this message in context: http://osgeo-org.1803224.n2.nabble.com/harvesting-metadatas-still-exist-after-restart-server-tp5444658p5444658.html
Can you check the database whether the records have been removed from the metadata table? /geonetwork/data is the folder where images store. When you remove the harvesting nodes, the metadata under the removing catalog will be deleted from the database, and the images will be deleted from the /geonetwork/data. But there maybe still some folders named"00000-00099" exists.
Kai
Joint Center for Intelligent Spatial Computing
703-395-2337
----- Original Message -----
Date: Friday, August 20, 2010 10:16 am
Subject: [GeoNetwork-users] harvesting metadatas still exist after restart server
restarting the
even when I
know why?
Sent from the GeoNetwork users mailing list archive at Nabble.com.-------------------------------------------------------------------
This SF.net email is sponsored byMake an app they can't live without
Enter the BlackBerry Developer Challenge
http://p.sf.net/sfu/RIM-dev2dev
GeoNetwork-users mailing list
Thanks for your quick reply.
When I restart the server, all data including database still exists and can
be searched in my geonetwork site. After removing the remote node by
harvesting management, all data in database disapears, but all folders and
files in c:/geonetwork/data still there.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/harvesting-metadatas-still-exist-after-restart-server-tp5444658p5445979.html
Sorry, I made some mistakes.
After removing remote node and I checked database again, there is not any
harvesting metadata information in metadata table, but there are still
harvesting node catalogs in sources table. And all data in
c:/geonetwork/data is still there,too.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/harvesting-metadatas-still-exist-after-restart-server-tp5444658p5446054.html
