[GeoNetwork-users] Harvesting of CSW 2.0.2
Hello to all,
I‘ a member of a research team at the Technical University Munich (Technische Universität München - chair of geoinformation-systems of Prof. Schilcher). We are testing different CSW-software against each other (what features are included) and if they work together (especially harvesting and differences in the implementation of the CSW-standard). Most of this takes place in the context of the Humboldt-project (1) and INSPIRE.
Our problem is now that nearly all of our CSWs are CSW 2.0.2, only Geonetwork (so far) is still 2.0.1. So we got some problems with the Harvesting-function in GeoNetwork. It seems to me unpossible to harvest any 2.0.2 CSW with any Geonetwork-Release.
This is really disappointing as we would like to use Geonetwork as main CSW for our part at the Humboldt-project.
I can hardly imagine that we are the first who want to harvest a 2.0.2-CSW with Geonetwork!?
We tried harvesting between Geonetwork, works fine with Geonetwork and CSW-type. But when adding a 2.0.2-csw we always get “OperationAbortedEx, Raised exception when searching, ..”. So far, I was not really concerned as the manual says that only 2.0.1-csw is supported.
So I tried a version of GeoNetwork by Archibald Warnock that I found here (2). This one is able to deliver 2.0.2-csw, but it seems to me that the csw-harvesting-engine won’t work with 2.0.2, neither with 2.0.1 (geonetwork-type harvesting works). I compiled this version on two different machines, WinXP Pro Tablet and Win2003 Server and in both Geonetwork is not able to harvest csw.
So, is there anybody who solved the problem of harvesting 2.0.2-csw in Geonetwork, with or without keeping the ability to harvest 2.0.1-csw?
We would appreciate any help!
Thanks and Best Regards,
Michael Lill
(1) www.esdi-humboldt.eu
(2) www.awcubed.com/index.php?page=csw-installation
GMX startet ShortView.de. Hier findest Du Leute mit Deinen Interessen!
Jetzt dabei sein: http://www.shortview.de/wasistshortview.php?mc=sv_ext_mf@anonymised.com
hi Michael,
your observation that CSW 2.0.2 harvesting won't work in any current
GeoNetwork release is correct.
Amongst the problems were : in the harvesting client part the value of
OutputSchema from the GetCapabilities response was ignored, causing some
Harvesting servers to return metadata in DC, which was subsequently not
stored by GeoNetwork. And in GeoNetwork's harvesting server part the value
of OutputSchema was compared against values that are not the values in the
specification, so if it received a correct OutputSchema value it would throw
an error.
I have recently fixed these issues and you can find them in GeoNetwork's svn
trunk. You can download the source using an svn client, and run
<download-dir>/install/ant to create an installer from the source.
I'm quite curious how the new code will work for you; could you keep us
posted on how you're doing ?
Kind regards
Heikki Doeleman
On Mon, Sep 15, 2008 at 3:07 AM, Michael Lill <Michael-Lill@anonymised.com> wrote:
Hello to all,
I' a member of a research team at the Technical University Munich
with Geonetwork!?
CSW-type. But when adding a 2.0.2-csw we always get "OperationAbortedEx,
Raised exception when searching, ..". So far, I was not really concerned as
csw-harvesting-engine won't work with 2.0.2, neither with 2.0.1
Michael Lill
Jetzt dabei sein:
This SF.Net email is sponsored by the Moblin Your Move Developer's
challenge
Build the coolest Linux based applications with Moblin SDK & win great
prizes
Grand prize is a trip for two to an Open Source event anywhere in the world
http://moblin-contest.org/redirect.php?banner_id=100&url=/
GeoNetwork-users mailing list
thanks for the information, tried it immediately, but nothing changed, still not able to harvest csw2.0.1 or 2.0.2.
I did the following:
Because I never worked with svn bevore, I went to http://geonetwork.svn.sourceforge.net/viewvc/geonetwork/trunk/ and chose "Download GNU Tarball". (Do I need a real svn-client? Did I download old code?)
Then copied it to one of my machines, compiled the installer with ant, copied it to another machine (new, empty and clean except of Java), installed and tested it with several Geonetwork-nodes and other CSWs.
But there is the same error I got on all installations so far when trying to harvest csw:
Class OperationAbortedEx
Message Raised exception when searching
Stack Harvester.java 356
Harvester.java 202
Harvester.java 92
CSWHarvester.java 211
AbstractHarvester.java 329
Executor.java 87
For example I tried harvesting csw from:
1. http://geoportal.dachplus.org:8080/geonetwork/srv/csw?Request=GetCapabilities&Service=CSW
(a Geonetwork 2.2 installation from an initiative in the region of the Lake Constance that wants to offer harmonised data from Germany, Suisse and Austria; of course, I could harvest this one as Geonetwork-node, but we are testing csw..)
2. http://gdz.bkg.bund.de/advmiscsw/advmiscsw?Request=GetCapabilities&Service=CSW
(an "old" Intergraph-System from a german goverment agency).
3. http://www.sdi-suite.de/soapServices/CSWStartup?Request=GetCapabilities&Service=CSW
(another csw-software/catalogue as online demo)
If you're interested in a special log-file or access to the machine, just give me a hint.
Best regards,
Michael Lill
-------- Original-Nachricht --------
Datum: Mon, 15 Sep 2008 03:16:02 -0700
Von: heikki <tropicano@anonymised.com>
An: "Michael Lill" <Michael-Lill@anonymised.com>
CC: geonetwork-users@lists.sourceforge.net
Betreff: Re: [GeoNetwork-users] Harvesting of CSW 2.0.2
hi Michael,
throw
an error.
svn
Kind regards
Heikki Doeleman
> Hello to all,
Prof.
(what
and
takes
any
CSW
2.0.2-CSW
> with Geonetwork!?
concerned as
here
different
not
> Michael Lill
> Jetzt dabei sein:
> challenge
> prizes
world
challenge
prizes
world
GMX Kostenlose Spiele: Einfach online spielen und Spaß haben mit Pastry Passion!
http://games.entertainment.gmx.net/de/entertainment/games/free/puzzle/6169196
Hi Michael,
I'm not sure about the tarball but it certainly looks like it i sthe latest
code, judging from the line numbers.
I've been trying to harvest from the 3 sources you mention, with the results
as below (none successful, all in a different way). In the first source I
get a timeout on GetCapabilities, that's where it ends; in the other 2
sources GetCapabilitites goes fine, but then GetRecords chokes, albeit in 2
different ways.
Meanwhile maybe you could try to harvest from one of the sources that I can
successfully harvest, as a complementary test ? Try for example
http://www.geodata.alterra.nl/excat/csw?request=GetCapabilities&service=CSW&acceptVersions=2.0.2
I'll continue to look into this, in the meantime..
1. Could not test, request timeout
2.
GR request :
<csw:GetRecords xmlns:csw="http://www.opengis.net/cat/csw/2.0.2&quot;
service="CSW" version="2.0.2" resultType="results" startPosition=
"1" maxRecords="10">
  <csw:Query>
    <csw:ElementSetName>summary</csw:ElementSetName>
  </csw:Query>
</csw:GetRecords>
GR response :
<ExceptionReport xmlns="http://www.opengis.net/ows&quot; xmlns:xsi="
http://www.w3.org/2001/XMLSchema-instance&quot; language="en" version="1
.0.0" xsi:schemaLocation="http://www.opengis.net/ows
http://schemas.opengis.net/ows/1.0.0/owsExceptionReport.xsd&quot;&gt;
  <Exception exceptionCode="MissingParameterValue" locator="typeNames">
    <ExceptionText>Attribute 'typeNames' is missing.</ExceptionText>
  </Exception>
</ExceptionReport>
I do not know why this is returned. The GetRecords request is exactly the
same as it is sent to CSW202 servers which I can harvest succesfully. I'll
check this request against the CSW 202 XSD though.
3.
request :
  <csw:Query>
  </csw:Query>
</csw:GetRecords>
the response is unparseable: the GN harvesting client throws
"org.xml.sax.SAXParseException: Invalid encoding name "UTF8"." Xerces does
this if it tries to parse a document that has encoding "UTF8" rather than
"UTF-8" -- apparently this is what the harvesting source returns..
Then I fixed this by setting feature "
http://apache.org/xml/features/allow-java-encodings&quot; in class
org.fao.geonet.csw.common.util.Xml, the response can be parsed but it is
<soapenv:Envelope xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/&quot;
xmlns:xsd="http://www.w3.org/2001/XMLSchema&quot; xmlns:xsi
="http://www.w3.org/2001/XMLSchema-instance&quot;&gt;
  <soapenv:Body>
    <soapenv:Fault>
      <faultcode xmlns:ns1="http://xml.apache.org/axis/
">ns1:Client.NoSOAPAction</faultcode>
      <faultstring>no SOAPAction header!</faultstring>
      <detail>
        <ns2:hostname xmlns:ns2="http://xml.apache.org/axis/
">sdisuite</ns2:hostname>
      </detail>
    </soapenv:Fault>
  </soapenv:Body>
</soapenv:Envelope>
I have no clue yet why this is returned but it is obiously not the
GetRecords response that GeoNetwork is expecting ..
Let's look into this more and find out what's wrong. I'll check in the
allow-java-encodings fix in the trunk.
Kind regards
Heikki Doeleman
On Mon, Sep 15, 2008 at 7:35 AM, Michael Lill <Michael-Lill@anonymised.com> wrote:
code?)
to harvest csw:
Harvester.java 202
Harvester.java 92
Executor.java 87
1.
testing csw..)
2.
3.
give me a hint.
Best regards,
Michael Lill
> hi Michael,
value
the
> throw
> an error.
> svn
> Kind regards
> Heikki Doeleman
wrote:
> > Hello to all,
> Prof.
> (what
> and
> takes
> any
> CSW
> 2.0.2-CSW
> > with Geonetwork!?
> concerned as
> here
> different
> not
> > Michael Lill
> > Jetzt dabei sein:
> > challenge
> > prizes
> world
> > _______________________________________________
> challenge
> prizes
> world
Passion!
Okay, as for the 3rd source, it specifies that SOAP encoding must be used in
GetRecords in its GetCapabilities response, but the GeoNetwork harvester
ignores this, and doesn't use SOAP. I'll see if I can fix that quickly and
try again.
Kind regards
Heikki Doeleman
On Wed, Sep 17, 2008 at 8:56 AM, heikki <tropicano@anonymised.com> wrote:
Hi Michael,
results as below (none successful, all in a different way). In the first
source I get a timeout on GetCapabilities, that's where it ends; in the
other 2 sources GetCapabilitites goes fine, but then GetRecords chokes,
albeit in 2 different ways.
2.
GR request :
  <csw:Query>
  </csw:Query>
</csw:GetRecords>
GR response :
  </Exception>
</ExceptionReport>
3.
request :
  <csw:Query>
  </csw:Query>
</csw:GetRecords>
  <soapenv:Body>
    <soapenv:Fault>
      <detail>
      </detail>
    </soapenv:Fault>
  </soapenv:Body>
</soapenv:Envelope>
Kind regards
Heikki Doeleman
code?)
to harvest csw:
Harvester.java 202
Harvester.java 92
Executor.java 87
1.
testing csw..)
2.
3.
give me a hint.
Best regards,
Michael Lill
> hi Michael,
value
the
> throw
> an error.
> svn
> Kind regards
> Heikki Doeleman
wrote:
> > Hello to all,
> Prof.
> (what
harvesting
> and
> takes
harvest
> any
main
> CSW
> 2.0.2-CSW
> > with Geonetwork!?
> concerned as
> here
the
> different
is
> not
> > Michael Lill
> > Jetzt dabei sein:
> > challenge
> > prizes
> world
> challenge
> prizes
> world
Passion!
Hello All,
I did try to set up CSW harvesting from
http://geossregistries.info:1090/GEOSSCSW202/discovery?Request=GetCapabilities&Service=CSW
I do also get the error
Harvester.java 202
Harvester.java 92
Executor.java 87
I saw you had similar problem in the past and was wondering if you have any
advice?
Thank you.
Best Regards,
Nicola Trocino
View this message in context: http://n2.nabble.com/Harvesting-of-CSW-2.0.2-tp2014625p2474962.html
Sent from the geonetwork-users mailing list archive at Nabble.com.
Hi Nicola,
ntrocino wrote:
Hello All,
Not sure what CSW server you're using here,
but you have in your GetCapabilities to change the case of operation
named "GetRecordByID" by "GetRecordById"
See OGC CSW 07-045 p61 :
"Note that the parameter names in all KVP encodings must be
handled in a case insensitive manner while parameter values shall be
handled in a case sensitive manner."
Testing on GeoNetwork, I'm having :
"OperationAbortedEx : GetRecordById operation not found"
so fixing this on your CSW server will help for the next steps of
harvesting from GeoNetwork.
HTH.
Francois
Harvester.java 202
Harvester.java 92
Executor.java 87
advice?
Thank you.
Best Regards,
Nicola Trocino
