[GeoNetwork-users] Harvesting problem
Hello Everybody,
We are currently having some problems in configurating the harvesting
mechanism. We have setup 2 geonetwork nodes within our company.
Each node had his own metadata in a database.
Node A: (windows machine)
- Desktop installation
- Jetty servlet engine (running on port 8081)
- McKoi database
Node B: (linux machine)
- Server installation
- Tomcat servlet engine (running on port 8080)
- PostgreSQL database
- Apache webserver (port 80)
Harvesting metadata from node B into node A works fine! But
harvesting metadata from node A into node B fails with this
errormessage:
2006-08-25 17:41:02 | [geonetwork sync] Searching on : geonetwork
2006-08-25 17:41:02 | [geonetwork sync] Raised exception when
executing schedule : geonetwork sync
2006-08-25 17:41:02 | [geonetwork sync] (C) Stack trace :
java.net.ConnectException: Connection refused
        at java.net.PlainSocketImpl.socketConnect(Native Method)
        at java.net.PlainSocketImpl.doConnect(PlainSocketImpl.java:333)
        at java.net.PlainSocketImpl.connectToAddress(PlainSocketImpl.java:195)
        at java.net.PlainSocketImpl.connect(PlainSocketImpl.java:182)
        at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:364)
        at java.net.Socket.connect(Socket.java:507)
        at java.net.Socket.connect(Socket.java:457)
        at java.net.Socket.<init>(Socket.java:365)
        at java.net.Socket.<init>(Socket.java:178)
        at jeeves.xml.XmlRequest.execute(XmlRequest.java:136)
        at org.fao.geonet.schedules.MetadataSync.exec(MetadataSync.java:194)
        at jeeves.server.ScheduleManager.executeSchedule(ScheduleManager.java:190)
        at jeeves.server.ScheduleManager.doJob(ScheduleManager.java:170)
        at jeeves.server.ScheduleManager.run(ScheduleManager.java:143)
Firewall has been set open for port 8080 en port 8081 on both incoming
and outgoing requests to these servers.
config.xml node B:
  <appHandler class="org.fao.geonet.Geonetwork">^M
    <param value="xxx.xx.xxx.xx" name="network" />^M
    <param value="255.255.255.0" name="netmask" />^M
    <param value="8080" name="port" />^M
    <param value="WEB-INF/lucene" name="luceneDir" />^M
    <param value="2100" name="z3950Port" />^M
    <param value="schema-mappings.xml" name="schemaMappings" />^M
    <param value="WEB-INF/data" name="dataDir" />^M
    <param value="abc" name="siteId" />^M
    <param value="abcgeonetwork.thisco.eu" name="publicHost" />^M
    <param value="80" name="publicPort" />^M
  </appHandler>^M
                <schedule name="geonetwork sync"
class=".schedules.MetadataSync" when="30 sec">
                        <param name="sites">
                                <site name="geonetwork">
                                        <general>
<host>xxx.xx.xxx.xxx</host> (= IP of node A)
                                                <port>8080</port>
                                                <language>en</language>
                                                <username></username>
                                                <password></password>
                                        </general>
                                        <services>
                                                <login>xml.user.login</login>
                                                <logout>xml.user.logout</logout>
                                                <search>xml.search</search>
                                                <get>xml.metadata.get</get>
                                        </services>
                                        <search>
                                                <extended>off</extended>
                                                <help>off</help>
                                                <relation>equal</relation>
                                                <any />
                                                <remote>off</remote>
                                                <region></region>
                                                <paper>off</paper>
                                                <siteId>nodeAid</siteId>
                                        </search>
                                        <group id="1">
                                                <privilege>view</privilege>
                                <privilege>download</privilege>
                                <privilege>dynamic</privilege>
                                        </group>
                                        <group id="0">
                                        </group>
                                </site>
                        </param>
                </schedule>
config.xml node A:
    <param value="xxx.xx.xxx.xxx" name="network" />
    <param value="8081" name="port" />
    <param value="nodeAid" name="siteId" />
    <param value="xxx.xx.xxx.xxx" name="publicHost" />
    <param value="8081" name="publicPort" />
  </appHandler>
Thank you,
Michael.
Hi Michael,
the error is in config.xml for node B:
   <general>
   <port>8080</port>
As you can see the port is 8080 but node A is installed into 8081.
Hello Everybody,
- McKoi database
errormessage:
config.xml node B:
  </appHandler>^M
                                        <general>
                                                <port>8080</port>
                                        </general>
                                        <services>
                                        </services>
                                        <search>
                                                <help>off</help>
                                                <any />
                                                <region></region>
                                                <paper>off</paper>
                                        </search>
                                        <group id="1">
                                        </group>
                                        <group id="0">
                                        </group>
                                </site>
                        </param>
                </schedule>
config.xml node A:
  </appHandler>
Thank you,
Michael.
Using Tomcat but need to do more? Need to support web services, security?
Get stuff done quickly with pre-integrated technology to make your job easier
Download IBM WebSphere Application Server v.1.0.1 based on Apache Geronimo
http://sel.as-us.falkag.net/sel?cmd=lnk&kid=120709&bid=263057&dat=121642
GeoNetwork-users mailing list
