[GeoNetwork-users] Harvesting questions
Hello,
I've installed 2.6.4 and I am trying to harvest different types of remote
nodes. I have successfully harvested other GeoNetwork nodes, but am having
problems with the following.
1. Harvesting a node as a catalog service.
I input what I think is the correct url to a CSW (for example,
http://geo.data.gov/geoportal/csw202/discovery?request=GetCapabilities&service=CSW&version=2.0.2)
and when I run the harvest, I get an error message: Invalid parameter value:
locator constraintLanguage
2. Harvesting a GeoNetwork node that uses https
When I harvest a geonetwork node via the administrator interface, I can't
include http or https, so if I put in a URL for a Geonetwork node that uses
https, the harvest fails. Can I input this request in a file somewhere
instead of through the interface to avoid this problem?
thanks so much!
Alison
Alison Slaats
SharedGeo.org
View this message in context: http://osgeo-org.1560.n6.nabble.com/Harvesting-questions-tp4477425p4477425.html
Hello I opened a ticket for point 2
http://trac.osgeo.org/geonetwork/ticket/803 . Any patch welcomed.
Cheers.
Francois
Le 16 février 2012 20:52, AlisonSlaats <aslaats@anonymised.com> a écrit :
Hello,
thanks so much!
Alison
Alison Slaats
SharedGeo.org
Virtualization & Cloud Management Using Capacity Planning
Cloud computing makes use of virtualization - but cloud computing
also focuses on allowing computing to be delivered as a service.
http://www.accelacomm.com/jaw/sfnl/114/51521223/
GeoNetwork-users mailing list
