[GeoNetwork-users] Harvesting THREDDS WCS
I'm currently running a relatively recent trunk build (version 2.5, r5946) and was wondering if anyone has had any experience harvesting metadata from a THREDDS WCS?
From what I can tell I can only harvest a single dataset from thredds at a time (by pointing the harvester at 'http://servername/thredds/wcs/dataset/foo.nc’) and I was wondering if anyone knew of a way to nicely harvest metadata from *all* WCS datasets for a given Thredds instance?
Thanks
Josh Vote
On 7/5/10 1:27 AM, Josh.Vote@anonymised.com wrote:
This is a surprising approach. With the other OGC WS, one harvests the GetCapabilities URL and the layers or data sets are pulled in. If this is not configured in the harvester, it should be, as all WCS must support capabilities.
Doug.
Thanks
Josh Vote
This SF.net email is sponsored by Sprint
What will you do first with EVO, the first 4G phone?
Visit sprint.com/first -- http://p.sf.net/sfu/sprint-com-first
GeoNetwork-users mailing list
Douglas D. Nebert
Senior Advisor for Geospatial Technology, System-of-Systems Architect
FGDC Secretariat T:703 648 4151 F:703 648-5755 C:703 459-5860
That's more or less what I'm doing now and it 'works' in a limited fashion.
The problem is that I need to create a harvester entry for each and every dataset I wish to harvest in a given THREDDS instance. I'm really hoping I'm overlooking something obvious because what I'd like to see is a single THREDDS URL I can use with the Geonetwork harvester (ie GetCapabilities) that will allow me to harvest ALL datasets.
I'm probably going a little beyond the scope of this mailing list so I may go bug the THREDDS community with this instead :slight_smile:
Josh
-----Original Message-----
From: Douglas Nebert [mailto:ddnebert@anonymised.com]
Sent: Tuesday, 6 July 2010 10:43 PM
To: geonetwork-users@lists.sourceforge.net
Subject: Re: [GeoNetwork-users] Harvesting THREDDS WCS
Doug.
Thanks
Josh Vote
Douglas D. Nebert
Hi Josh,
A THREDDS catalog harvester was added to geonetwork in 2.5 by
Simon Pigot (csiro).
This harvester takes a THREDDS xml catalog url as a parameter and crawls
through the catalog creating iso19119/19139 metadata for each service
defined in the catalog and optionally iso19115/19139 metadata for each
dataset defined in the catalog. It sounds like something generally
along the lines of what you are looking for but may not meet your exact
needs re WCS services. As it is relatively new, it can probably benefit
from some constructive feedback from the community on its
usefulness and/or suggestions on areas for improvement.
I haven't used the harvester for harvesting WCS (or WMS) services here
myself yet but will probably be looking at it shortly as our need to
harvest this kind of metadata increases.
Craig Jones
eMII Infrastructure Programmer
IMOS e-Marine Information Infrastructure Facility (eMII)
Ph: +61 3 6226 8567
Josh
> Hi,
Doug.
> Thanks
> Josh Vote
