I am looking for some advice on what people have done regarding the initial
load of their spatial data / metadata into GeoNetwork and to maintain it
when datasets are updated?
The reason I ask is that we have over 400 datasets from a variety of
sources that are currently being stored in PostGIS and manipulated in a
range of software including QGIS. I want to try and find a way to quickly
upload the metadata into GeoNetwork and harvest and updates on a regular
basis from our own databases to reflect the current status of the data.
We are not currently set on the technology solution, although we would like
to try and stick with an open source solution, so want to try and find out
what others have done and the processes they have used to keep the metadata
current.
Thanks
Dean Howell
deanhowell2009@anonymised.com
Hi, An option would be to use Talend Spatial with this set of jobs
https://github.com/talend-spatial/workspace-metadata-crawler
which are scanning folders, databases or webservices, generates metadata
records and populates a catalog using CSW.
Cheers.
Francois
2015-05-18 7:16 GMT+02:00 Dean Howell <deanhowell2009@anonymised.com>:
current.
Thanks
Dean Howell
One dashboard for servers and applications across Physical-Virtual-Cloud
Widest out-of-the-box monitoring support with 50+ applications
Performance metrics, stats and reports that give you Actionable Insights
Deep dive visibility with transaction tracing using APM Insight.
http://ad.doubleclick.net/ddm/clk/290420510;117567292;y
GeoNetwork-users mailing list
Thanks I will give that a go
On Mon, May 18, 2015 at 4:13 PM Francois Prunayre <fx.prunayre@anonymised.com>
Cheers.
Francois
initial
like
metadata
current.
Thanks
Dean Howell
Hello again Francois, this looks like a great tool and perfect fit to what
I am trying to achieve. I have just one question, do we need the main
Talend software installed first or will the metadata crawler work
independently of it.
Thanks
Dean
On Mon, May 18, 2015 at 4:38 PM Dean Howell <deanhowell2009@anonymised.com>
Cheers.
Francois
initial
like
out
metadata
current.
Thanks
Dean Howell
2015-05-18 9:52 GMT+02:00 Dean Howell <deanhowell2009@anonymised.com>:
You should have a look to the doc
https://docs.google.com/document/d/1Z-lJDGMX1tO3377Ytgoos0nGxqqN2rF-GyqiOB4iAVY/edit
Usually, you first test it from Talend Studio and then you can export the
job as an autonomous Java app or webservice and run it without the Studio.
Cheers.
Francois
Thanks
Dean
Cheers.
Francois
initial
quickly
like
out
metadata
current.
Thanks
Dean Howell
Thanks Francois, terrific
thanks for all your help. It is very much
appreciated - Merci beaucoup
On Mon, May 18, 2015 at 5:54 PM Francois Prunayre <fx.prunayre@anonymised.com>
what I am trying to achieve. I have just one question, do we need the main
Cheers.
Francois
Thanks
Dean
metadata records and populates a catalog using CSW.
Cheers.
Francois
initial
it
quickly
regular
like
out
metadata
current.
Thanks
Dean Howell
Insights
