[GeoNetwork-users] Headless Install on Ubuntu Server... where is gast.jar?
Hey Folks,
Running into an issue with a missing gast.jar in the gast directory.
I am following instructions found here:
http://trac.osgeo.org/geonetwork/wiki/InstallAndConfig
I checked out SVN trunk and found no gast.jar
The command I am trying to complete is java -jar ./gast.jar -setupdb
I read a post in the developers list on a previous version that had a
similar issue and they suggested to compile a new jar using ant... Well
first off I am not a developer. I know python, not java, I looked at ant
and it looks scary.
I can compile sources following simple directions as used in C make
./configure
make
sudo make install
but java is a different beast
is GAST still relevant?
Looking forward to the solution.
That page is only an outline and is missing some
of the details (as you have noticed).
Yes, this is a good thing.
and it looks scary.
You need to have ant installed, but you
don't need to know any ant syntax
to do the compilation.
See http://trac.osgeo.org/geonetwork/wiki/HowToCompile
for compilation instructions.
./configure
make
sudo make install
You need only type "ant" to do the compilation.
Yes. But since you're using trunk you may
experience strangeness.
There have been changes to GAST since 2.2 (sigh).
Richard Walker
Software Improvements Pty Ltd
Phone: +61 2 6273 2055
Fax: +61 2 6273 2082
Dave Sampson wrote:
should I not start the script from the bin directory?
You _must_ start the scripts from
the bin directory.
> where are the logs directories?
Have a look in the start-geonetwork.sh script.
The very first line is "cd ../jetty".
And that's where you'll find the logs,
namely, in jetty/logs.
Richard Walker
Alright,
The issues was not with all the logs, but I guess just some logs or
backup files that did not exist...
When I run the script it goes through all of its startup processes and
gets to the ===system ready=== stage, but then I can not access the web
interface.
the localhost is actually processed through a hostname mapping but it
should work.
Where do I go from here?
the bin directory.
hi Dave,
could you look inside the log files to see if any error messages appeared ?
Normally there is both output.log, which contains less information, and
geonetwork.log, which contains more information.
The "system ready" message does not mean that the system is actually ready
(that would be a spoiler :slight_smile: You should see some message saying something
like "Started SocketListener on 0.0.0.0:8080". Then, it should be accessible
on a browser pointing at http://localhost:8080/geonetwork.
I'm not quite sure what you mean by " the localhost is actually processed
should work." You're using Apache in front of it ? Maybe try to get it to
work on its own first, and when that works, put Apache in play.
Kind regards
Heikki Doeleman
On Fri, Jul 10, 2009 at 7:35 PM, Dave Sampson <samper.d@anonymised.com> wrote:
Alright,
interface.
should work.
> the bin directory.
Enter the BlackBerry Developer Challenge
This is your chance to win up to $100,000 in prizes! For a limited time,
vendors submitting new applications to BlackBerry App World(TM) will have
the opportunity to enter the BlackBerry Developer Challenge. See full prize
details at: http://p.sf.net/sfu/Challenge
GeoNetwork-users mailing list
hi Dave,
your first log is the geoserver log -- that doesn't concern GeoNetwork, so
much. You second log is geonetwork.log which is relevant.
You don't have a "output.log" ? That's the one where, for me, the message
about "Started SocketListener.. " appears. However I also have in
geonetwork.log the message about "=== System working..", maybe that does
indicate something, after all.
So, indeed I see no errors in your log file.. looks fine, everything. Which
makes me wonder if you have some error in how you're addressing this
machine.
Could you check if you have a file called <this date>.request.log ? If
requests actually do arrive at Jetty, they would be logged there.
Another thing to try might be to use a text browser (lynx) on your target
machine itself, so you could use "localhost" and at least see if you get
some response from the application (although not too many things about it
will function without javascript).
Last tip I can think of now, is to set the logging level to DEBUG -- it will
give you more info in the log file.
But it does seem to me that your GeoNetwork application has started
correctly. I'd start investigating whether your addressing is correct.. try
to get it to work if you point to http://<ip address>:8080/geonetwork ?
regards
Heikki Doeleman
On Sun, Jul 12, 2009 at 7:40 AM, Dave Sampson <samper.d@anonymised.com> wrote:
heikki,
The /jetty/geoserver.log logs, See the full log here: (expires 30 days
from this post) http://pastebin.ca/1492350
I see a lot of geo related stuff but nothing about system upness.
For the /jetty/geonetwork.log see here: http://pastebin.ca/1492353
I could not find what you suggested... where might it be going wrong?
Since I am running headless (read no GUI, No Monitor) I have to log in
through SSH for the command line and when I point my browser to the page
I can't do localhost because that would infact be my local machine, but
the application is sitting on my headless server.
SO. I either need to point my browser to the local IP address or its
name it is known by on the network. For example the computer itself is
called AVALANCHE, so I have to point to http://avalanche.lan:8080
This name is picked up by the DNS and points it to that machine as its
localhost. Does that make sense?
I have many virtual servers running on it (I am learning how to
virtualize) and I want another domain to pick up geoserver for when I
push it out to the internet. for example some.domain.com:8080.
So far I would have to make the recommendation that for a headless
install it would be so much easier to do what most PHP projects do and
point to http://some.domain.com/geonetwork/installer and do the install
over a web interface. I know that it is different with java and tomcat
but a simple PHP page to act as an installer would help greatly IMHO.
> hi Dave,
> appeared ?
> and geonetwork.log, which contains more information.
> ready (that would be a spoiler :slight_smile: You should see some message saying
> something like "Started SocketListener on 0.0.0.0:8080
> <http://0.0.0.0:8080>". Then, it should be accessible on a browser
> to work on its own first, and when that works, put Apache in play.
> Kind regards
> Heikki Doeleman
> <mailto:samper.d@anonymised.com>> wrote:
> Alright,
and
> the web
> interface.
> should work.
> Cheers
> > the bin directory.
> time,
> will have
> full prize
> <mailto:GeoNetwork-users@lists.sourceforge.net>
Hi Dave,
I agree with Heikki's observation that your instance seems to be running correctly and that you are most likely facing an issue in properly accessing the URL to the service.
The System working message relates to the GeoNetwork application that is up, but it needs GeoServer to be also started before it can be accessed. So the final message in the output.log "Started SocketListener..." is required to be sure the servlet engine is up and accessible.
Another thing you can try, besides the lynx suggestion, is to see if the command netstat -tlnp shows that there is a Java program listening on port 8080.
Jeroen
On Jul 12, 2009, at 6:27 AM, heikki wrote:
hi Dave,
machine.
regards
Heikki Doeleman
heikki,
hi Dave,
appeared ?
Kind regards
Heikki Doeleman
   Alright,
and
   the web
   interface.
   should work.
the bin directory.
   time,
   will have
   full prize
   details at: Best Open Source Mac Front-Ends 2024
   geonetwork-users List Signup and Options
   GeoNetwork - Geographic Metadata Catalog download | SourceForge.net
GeoNetwork OpenSource is maintained at GeoNetwork - Geographic Metadata Catalog download | SourceForge.net
