Hi Archie, two things to try :
- log in as admin to geonetwork and search for templates with the interface
- have a look to your table METADATA and search for row with ISTEMPLATE = y
If nothing there, you could try to import a new one with an xml import,
switch to edit mode and tick the checkbox to set your new metadata as a
template.
HTH. Francois
-----Message d'origine-----
De : geonetwork-users-admin@lists.sourceforge.net
[mailto:geonetwork-users-admin@lists.sourceforge.net] De la part de Archie
Warnock
Envoyé : jeudi 9 février 2006 20:30
À : geonetwork-users@lists.sourceforge.net
Objet : [GeoNetwork-users] Missing templates?
I've just done a clean install of 2.0.1 and am attempting to create some
metadata. When I select Administration|New Metadata, the page that comes up
has a selection box for templates, but nothing is in the box.
What files is it supposed to find to use, and where should they be located?
Thanks!
Archie
-- Archie Warnock warnock@anonymised.com
-- A/WWW Enterprises www.awcubed.com
-- As a matter of fact, I _do_ speak for my employer.
This SF.net email is sponsored by: Splunk Inc. Do you grep through log files
for problems? Stop! Download the new AJAX search engine that makes
searching your log files as easy as surfing the web. DOWNLOAD SPLUNK!
http://sel.as-us.falkag.net/sel?cmd=lnk&kid=103432&bid=230486&dat=121642
GeoNetwork-users mailing list
Ce message a ete verifie par MailScanner pour des virus ou des polluriels et
rien de suspect n'a ete trouve.
Les donnees et renseignements contenus dans ce message sont personnels,
confidentiels et prives. Toute publication, utilisation ou diffusion, meme
partielle, doit etre autorisee.
Any data and information contained in this electronic mail is personal,
confidential and secret. Any total or partial publication, use or
distribution must be authorized.
Ce message a ete verifie par MailScanner pour des virus ou des polluriels et rien de suspect n'a ete trouve.
Les donnees et renseignements contenus dans ce message sont personnels, confidentiels et prives. Toute publication, utilisation ou diffusion, meme partielle, doit etre autorisee.
Any data and information contained in this electronic mail is personal, confidential and secret. Any total or partial publication, use or distribution must be authorized.
