[GeoNetwork-users] Help getting geonetwork 3.0 to work with SQL server.
On Wed, Jan 20, 2016 at 1:20 PM, <
geonetwork-users-owner@lists.sourceforge.net> wrote:
You have to be subscribed in order to post to this list. You can do so
at https://lists.sourceforge.net/lists/listinfo/geonetwork-users .
Greetings from the GeoNetwork opensource list administrators.
---------- Forwarded message ----------
To: GeoNetwork-users@lists.sourceforge.net
Cc:
Date: Wed, 20 Jan 2016 13:19:55 -0600
Subject: Help getting geonetwork 3.0 to work with SQL server.
I need help getting geonetwork 3.0 to work with SQL server. I ran the
setup and I get an error when i open geonetwork that says FileError: '
http://localhost:8081/geonetwork/catalog/lib/style/bootstrap-3.0.1/bootstrap.less
wasn't found (404) . I have tried changing back to the default db instead
of sql server and the install works fine. However it is a requirement that
this install uses sql server. I also do not believe that geonetwork is
logging. I don't seem to find the logs for it anywhere. I can see a bunch
of errors in the cmd window but they fly by too fast to get a proper look
at them.
The rest of the error output to the page is truncated in multiple places
but here it is just in case it helps identify what the issue is:
Message
java.lang.RuntimeException: javax.persistence.PersistenceException:
org.hibernate.exception.SQLGrammarException: could not execute statement
Handler
org.fao.geonet.Geonetwork
Exception
java.lang.RuntimeException: java.lang.RuntimeException:
Stack
at org.fao.geonet.Geonetwork.importDatabaseData(Geonetwork.java:532)
at org.fao.geonet.Geonetwork.start(Geonetwork.java:195)
at jeeves.server.JeevesEngine.initAppHandler(JeevesEngine.java:454)
at jeeves.server.JeevesEngine.init(JeevesEngine.java:175)
at jeeves.server.sources.http.JeevesServlet.init(JeevesServlet.java:82)
at javax.servlet.GenericServlet.init(GenericServlet.java:158)
at
org.apache.catalina.core.StandardWrapper.initServlet(StandardWrapper.java:1231)
at
org.apache.catalina.core.StandardWrapper.loadServlet(StandardWrapper.java:1144)
at org.apache.catalina.core.StandardWrapper.load(StandardWrapper.java:1031)
at
org.apache.catalina.core.StandardContext.loadOnStartup(StandardContext.java:4978)
at
org.apache.catalina.core.StandardContext.startInternal(StandardContext.java:5270)
at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:150)
at
org.apache.catalina.core.StandardContext.reload(StandardContext.java:3812)
at
org.apache.catalina.manager.ManagerServlet.reload(ManagerServlet.java:1006)
at
org.apache.catalina.manager.HTMLManagerServlet.reload(HTMLManagerServlet.java:613)
at
org.apache.catalina.manager.HTMLManagerServlet.doPost(HTMLManagerServlet.java:214)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:648)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:729)
at
org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:291)
at
org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
at
org.apache.catalina.filters.CsrfPreventionFilter.doFilter(CsrfPreventionFilter.java:136)
at
org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:239)
at
at org.apache.tomcat.websocket.server.WsFilter.doFilter(WsFilter.java:52)
at
at
at
org.apache.catalina.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:108)
at
at
at
org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:212)
at
org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:106)
at
org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:614)
at
org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:141)
at
org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:79)
at
org.apache.catalina.valves.AbstractAccessLogValve.invoke(AbstractAccessLogValve.java:616)
at
org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:88)
at
org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:518)
at
org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:1096)
at
org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:674)
at
org.apache.tomcat.util.net.AprEndpoint$SocketProcessor.doRun(AprEndpoint.java:2500)
at
org.apache.tomcat.util.net.AprEndpoint$SocketProcessor.run(AprEndpoint.java:2489)
at
java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
at
java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
at
org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61)
at java.lang.Thread.run(Thread.java:745)
Caused by: java.lang.RuntimeException:
at org.fao.geonet.lib.DbLib.runSQL(DbLib.java:122)
at org.fao.geonet.lib.DbLib.access$000(DbLib.java:50)
at org.fao.geonet.lib.DbLib$1.doInTransaction(DbLib.java:70)
at
jeeves.transaction.TransactionManager.runInTransaction(TransactionManager.java:63)
at org.fao.geonet.lib.DbLib.insertData(DbLib.java:65)
at org.fao.geonet.Geonetwork.importDatabaseData(Geonetwork.java:522)
... 44 more
Caused by: javax.persistence.PersistenceException:
at
org.hibernate.jpa.spi.AbstractEntityManagerImpl.convert(AbstractEntityManagerImpl.java:1763)
at
org.hibernate.jpa.spi.AbstractEntityManagerImpl.convert(AbstractEntityManagerImpl.java:1677)
at
org.hibernate.jpa.spi.AbstractEntityManagerImpl.throwPersistenceException(AbstractEntityManagerImpl.java:1771)
at
org.hibernate.jpa.spi.AbstractQueryImpl.executeUpdate(AbstractQueryImpl.java:87)
at org.fao.geonet.lib.DbLib.runSQL(DbLib.java:116)
... 49 more
Caused by: org.hibernate.exception.SQLGrammarException: could not execute
statement
at
org.hibernate.exception.internal.SQLStateConversionDelegate.convert(SQLStateConversionDelegate.java:123)
at
org.hibernate.exception.internal.StandardSQLExceptionConverter.convert(StandardSQLExceptionConverter.java:49)
at
org.hibernate.engine.jdbc.spi.SqlExceptionHelper.convert(SqlExceptionHelper.java:126)
at
org.hibernate.engine.jdbc.spi.SqlExceptionHelper.convert(SqlExceptionHelper.java:112)
at
org.hibernate.engine.jdbc.internal.ResultSetReturnImpl.executeUpdate(ResultSetReturnImpl.java:211)
at
org.hibernate.engine.query.spi.NativeSQLQueryPlan.performExecuteUpdate(NativeSQLQueryPlan.java:211)
at
org.hibernate.internal.SessionImpl.executeNativeUpdate(SessionImpl.java:1310)
at org.hibernate.internal.SQLQueryImpl.executeUpdate(SQLQueryImpl.java:389)
at
org.hibernate.jpa.internal.QueryImpl.internalExecuteUpdate(QueryImpl.java:371)
at
org.hibernate.jpa.spi.AbstractQueryImpl.executeUpdate(AbstractQueryImpl.java:78)
... 50 more
Caused by: com.microsoft.sqlserver.jdbc.SQLServerException: Invalid column
name 'true'.
at
com.microsoft.sqlserver.jdbc.SQLServerException.makeFromDatabaseError(SQLServerException.java:216)
at
com.microsoft.sqlserver.jdbc.SQLServerStatement.getNextResult(SQLServerStatement.java:1515)
at
com.microsoft.sqlserver.jdbc.SQLServerPreparedStatement.doExecutePreparedStatement(SQLServerPreparedStatement.java:404)
at
com.microsoft.sqlserver.jdbc.SQLServerPreparedStatement$PrepStmtExecCmd.doExecute(SQLServerPreparedStatement.java:350)
at com.microsoft.sqlserver.jdbc.TDSCommand.execute(IOBuffer.java:5696)
at
com.microsoft.sqlserver.jdbc.SQLServerConnection.executeCommand(SQLServerConnection.java:1715)
at
com.microsoft.sqlserver.jdbc.SQLServerStatement.executeCommand(SQLServerStatement.java:180)
at
com.microsoft.sqlserver.jdbc.SQLServerStatement.executeStatement(SQLServerStatement.java:155)
at
com.microsoft.sqlserver.jdbc.SQLServerPreparedStatement.executeUpdate(SQLServerPreparedStatement.java:314)
at
org.apache.commons.dbcp.DelegatingPreparedStatement.executeUpdate(DelegatingPreparedStatement.java:105)
at
at
at
org.hibernate.engine.jdbc.internal.ResultSetReturnImpl.executeUpdate(ResultSetReturnImpl.java:208)
... 55 more
Hi Billy
What steps have you undertaken to configure GN to connect to MSSQL?
Are you using Jetty version or tomcat?
If you are using Jetty the logs are found in
\installdir\jetty\logs\geonetwork.log
*Luke Bassett*
* <lukembassett@anonymised.com>*Melbourne Australia
I find that you have to edit the sqlserver.xml as the server name is
hardcoded and not bound to the property from jdbc.properties
The jdbcURL bean modification I make is as follows:
    <bean id="jdbcURL" class="java.lang.String">
       <!-- <constructor-arg
value="jdbc:sqlserver://SERVER;database=${jdbc.database};integratedSecurity=false;"/>-->
  <constructor-arg
value="jdbc:sqlserver://${jdbc.host};database=${jdbc.database};integratedSecurity=false;"/>
    </bean>
On Thu, Jan 21, 2016 at 12:02 PM, BillyZ Design <billyz313@anonymised.com> wrote:
I have changed WEB-INF/config-node/srv.xml to sql server, changed the
connection properties in WEB-INF/config-db/jdbc.properties.
I have added the jdbc driver. When I point it at an empty db it connects
properly and creates tables.
I am using tomcat.
On Wed, Jan 20, 2016 at 6:41 PM, Luke <coolhandluka@anonymised.com> wrote:
Hi Billy
*Luke Bassett*
*Luke Bassett*
Yes, I point to the correct server. It actually makes the tables on the
first run.
  <constructor-arg
    </bean>
I am using tomcat.
Hi Billy
*Luke Bassett*
*Luke Bassett*
Probably best to find your logs and determine what the full error is in
that case.
I have setup a handful of GN 3.0.2 instances with SQL Server but only using
Jetty.
On Thu, Jan 21, 2016 at 12:59 PM, BillyZ Design <billyz313@anonymised.com> wrote:
first run.
  <constructor-arg
    </bean>
connects properly and creates tables.
I am using tomcat.
Hi Billy
*Luke Bassett*
*Luke Bassett*
*Luke Bassett*
Thanx Luke. Since it wasn't logging i decided to video the screen when it
ran so i could read the outputs. I found that it wasn't logging due to
permissions. I corrected the permissions and now i have the log. I still
am not sure what the issue is, but I have more info that you might be able
to help me with. Here is the log.
2016-01-21 17:00:25,355 DEBUG [geonetwork.databasemigration] - DB Migration
/ Running 'class org.apache.commons.dbcp.BasicDataSource' after
initialization of 'javax.sql.DataSource'.
2016-01-21 17:00:25,362 INFO [geonetwork.databasemigration] - -
Migration ...
2016-01-21 17:00:26,328 INFO [geonetwork.databasemigration] - Error
getting database version: Invalid column name 'id'.. Probably due to an old
version. Trying with new Settings structure.
2016-01-21 17:00:26,328 INFO [geonetwork.databasemigration] - Webapp
  version:3.0.3-0 subversion:SNAPSHOT
Database version:null subversion:null
2016-01-21 17:00:26,328 WARN [geonetwork.databasemigration] -
Database does not contain any version information. Check that the database
is a GeoNetwork database with data. The database is probably empty, no
migration required.
2016-01-21 17:00:29,494 ERROR [org.hibernate.tool.hbm2ddl.SchemaUpdate] -
HHH000388: Unsuccessful: create table HarvesterData (harvesterUuid
varchar(255) not null, key varchar(255) not null, value varchar(255) not
null, primary key (harvesterUuid, key))
Incorrect syntax near the keyword 'key'.
HHH000388: Unsuccessful: alter table Services add id int not null
Cannot find the object "Services" because it does not exist or you do not
have permissions.
HHH000388: Unsuccessful: alter table Services add class varchar(1024) not
null
have permissions.
HHH000388: Unsuccessful: alter table Services add description varchar(1024)
have permissions.
HHH000388: Unsuccessful: alter table Services add explicitQuery varchar(255)
have permissions.
2016-01-21 17:00:29,509 ERROR [org.hibernate.tool.hbm2ddl.SchemaUpdate] -
HHH000388: Unsuccessful: alter table ServiceParameters add constraint
FK_t32t4xtdqmjhl8xmjpe95e474 foreign key (service) references Services
Foreign key 'FK_t32t4xtdqmjhl8xmjpe95e474' references invalid table
'Services'.
2016-01-21 17:00:33,937 DEBUG [geonetwork.databasemigration] - DB Migration
/ Running 'class org.springframework.orm.jpa.JpaTransactionManager' after
initialization of 'org.springframework.orm.jpa.JpaTransactionManager'.
2016-01-21 17:00:33,942 INFO [geonetwork.databasemigration] - -
Migration ...
2016-01-21 17:00:33,948 INFO [geonetwork.databasemigration] - Error
2016-01-21 17:00:33,949 INFO [geonetwork.databasemigration] - Webapp
2016-01-21 17:00:33,950 INFO [geonetwork.databasemigration] -
2016-01-21 17:00:33,950 WARN [geonetwork.databasemigration] -
migration required.
2016-01-21 17:00:39,923 WARN [jeeves.engine] - Jeeves DBMS service
configuration lookup failed (database may not be available yet). Message
is: could not extract ResultSet; SQL [n/a]; nested exception is
org.hibernate.exception.SQLGrammarException: could not extract ResultSet
2016-01-21 17:00:39,986 WARN [geonetwork.data.directory] - - Data
directory properties is not set. Use geonetwork.dir or geonetwork.dir
properties.
2016-01-21 17:00:40,001 WARN [geonetwork.data.directory] - - Data
directory provided could not be used. Using default location:
C:\Tomcat\apache-tomcat-8.0.29\webapps\geonetwork\WEB-INF\data
2016-01-21 17:00:40,064 WARN [geonetwork.database] - Executing SQL from:
WEB-INF\classes\setup\sql\data data-db-
2016-01-21 17:00:40,672 WARN [geonetwork.database] - SQL failure for:
INSERT INTO Users (id, username, password, name, surname, profile, kind,
organisation, security, authtype, enabled) VALUES
(1,'admin','46e44386069f7cf0d4f2a420b9a2383a612f316e2024b0fe84052b0b96c479a23e8a0be8b90fb8c2','admin','admin',0,'','','','',
true), error is:org.hibernate.exception.SQLGrammarException: could not
execute statement
at
at
at
at
at
at
at
at
at
at
org.apache.catalina.core.ContainerBase.addChildInternal(ContainerBase.java:725)
at org.apache.catalina.core.ContainerBase.addChild(ContainerBase.java:701)
at org.apache.catalina.core.StandardHost.addChild(StandardHost.java:717)
at org.apache.catalina.startup.HostConfig.deployWAR(HostConfig.java:945)
at
org.apache.catalina.startup.HostConfig$DeployWar.run(HostConfig.java:1795)
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511)
at java.util.concurrent.FutureTask.run(FutureTask.java:266)
at
at
statement
at
at
at
at
at
at
at
at
at
... 27 more
name 'true'.
at
at
at
at
at
at
at
at
at
at
at
at
... 32 more
2016-01-21 17:00:40,689 ERROR [jeeves] - Error occurred within a transaction
at
at
at
at
at
at
at
at
at
at
at
at
at
... 26 more
statement
at
at
at
at
at
at
at
at
at
... 27 more
name 'true'.
at
at
at
at
at
at
at
at
at
at
at
at
... 32 more
2016-01-21 17:00:40,767 ERROR [geonetwork.database] - Error occurred while
trying to execute SQL
at
at
at
at
at
at
at
at
at
at
at
at
at
... 26 more
statement
at
at
at
at
at
at
at
at
at
... 27 more
name 'true'.
at
at
at
at
at
at
at
at
at
at
at
at
... 32 more
2016-01-21 17:00:40,782 ERROR [jeeves.engine] - Raised exception while
starting the application. Fix the error and restart.
2016-01-21 17:00:40,782 ERROR [jeeves.engine] - Handler :
2016-01-21 17:00:40,782 ERROR [jeeves.engine] - Exception :
2016-01-21 17:00:40,782 ERROR [jeeves.engine] - Message :
2016-01-21 17:00:40,782 ERROR [jeeves.engine] - Stack :
at
at
at
at
at
at
at
at
at
... 21 more
at
at
at
at
... 26 more
statement
at
at
at
at
at
at
at
at
at
... 27 more
name 'true'.
at
at
at
at
at
at
at
at
at
at
at
at
... 32 more
2016-01-21 17:00:40,814 ERROR [jeeves.engine] -
{Message=java.lang.RuntimeException:
org.hibernate.exception.SQLGrammarException: could not execute statement,
Error=Raised exception while starting the application. Fix the error and
restart., Handler=org.fao.geonet.Geonetwork,
Exception=java.lang.RuntimeException: java.lang.RuntimeException:
Stack=java.lang.RuntimeException: java.lang.RuntimeException:
at
at
at
at
at
at
at
at
at
... 21 more
at
at
at
at
... 26 more
statement
at
at
at
at
at
at
at
at
at
... 27 more
name 'true'.
at
at
at
at
at
at
at
at
at
at
at
at
... 32 more
that case.
using Jetty.
first run.
  <constructor-arg
    </bean>
I am using tomcat.
Hi Billy
*Luke Bassett*
*Luke Bassett*
*Luke Bassett*
So that last log was trying to set it up on an empty db, here is the log
attempting to upgrade the actual db that I am really trying to get to
work...
2016-01-21 17:25:24,659 DEBUG [geonetwork.databasemigration] - DB Migration
2016-01-21 17:25:24,675 INFO [geonetwork.databasemigration] - -
Migration ...
2016-01-21 17:25:25,705 INFO [geonetwork.databasemigration] - Webapp
Database version:2.10.1 subversion:0
2016-01-21 17:25:25,720 DEBUG [geonetwork.databasemigration] -
Migrating from 2.10.1 to 3.0.3 (dbtype:sqlserver)...
2016-01-21 17:25:25,720 INFO [geonetwork.databasemigration] -
Loading SQL migration step configuration from <?xml version="1.0"
encoding="UTF-8"?>
2016-01-21 17:25:25,720 INFO [geonetwork.databasemigration] - -
running tasks for 2.11.0...
SQL migration
file:C:\Tomcat\apache-tomcat-8.0.29\webapps\geonetwork\WEB-INF\classes\setup\sql\migrate\v2110
prefix:1-migrate-db- ...
2016-01-21 17:25:25,736 WARN [geonetwork.database] - SQL failure for:
CREATE TABLE HarvesterSettings ( id int not null,
    parentId int, name varchar(64) not null, value
varchar(max), primary key(id), foreign key(parentId) references
HarvesterSettings(id) ), error is:There is already an object named
'HarvesterSettings' in the database.
2016-01-21 17:25:25,736 INFO [geonetwork.databasemigration] -
Errors occurs during SQL migration file: There is already an object named
2016-01-21 17:25:25,767 INFO [geonetwork.databasemigration] - -
Java migration class:v2110.MoveHarvesterSettings
SQL migration
prefix:2-migrate- ...
2016-01-21 17:25:25,783 WARN [geonetwork.database] - SQL failure for:
ALTER TABLE operations DROP COLUMN reserved, error is:ALTER TABLE DROP
COLUMN failed because column 'reserved' does not exist in table
'Operations'.
2016-01-21 17:25:25,783 INFO [geonetwork.databasemigration] -
Errors occurs during SQL migration file: ALTER TABLE DROP COLUMN failed
because column 'reserved' does not exist in table 'Operations'.
2016-01-21 17:25:25,798 INFO [geonetwork.databasemigration] - -
SQL migration
prefix:3-create-tmp-tables- ...
2016-01-21 17:25:25,814 WARN [geonetwork.database] - SQL failure for:
CREATE TABLE USERGROUPS_TMP ( USERID int NOT NULL, GROUPID int NOT
NULL, PROFILE int NOT NULL ), error is:There is already an object named
'USERGROUPS_TMP' in the database.
2016-01-21 17:25:25,814 INFO [geonetwork.databasemigration] -
2016-01-21 17:25:25,829 INFO [geonetwork.databasemigration] - -
SQL migration
prefix:4-copy-to-tmp- ...
2016-01-21 17:25:25,845 WARN [geonetwork.database] - SQL failure for:
INSERT INTO USERS_TMP SELECT id, username, password, surname, name, 0,
organisation, kind, security, authtype FROM USERS where
profile='Administrator', error is:Violation of PRIMARY KEY constraint
'PK__USERS_TM__3213E83F6CF07955'. Cannot insert duplicate key in object
'dbo.USERS_TMP'. The duplicate key value is (1).
2016-01-21 17:25:25,845 INFO [geonetwork.databasemigration] -
Errors occurs during SQL migration file: Violation of PRIMARY KEY
constraint 'PK__USERS_TM__3213E83F6CF07955'. Cannot insert duplicate key in
object 'dbo.USERS_TMP'. The duplicate key value is (1).
2016-01-21 17:25:25,861 INFO [geonetwork.databasemigration] - -
SQL migration
prefix:5-recreate-old-tables- ...
2016-01-21 17:25:25,907 WARN [geonetwork.database] - SQL failure for:
CREATE TABLE USERGROUPS ( userId int not null,
groupId int not null, profile int not null,
primary key(userId,groupId,profile), foreign key(userId) references
Users(id), foreign key(groupId) references Groups(id) ), error
is:There are no primary or candidate keys in the referenced table 'Users'
that match the referencing column list in the foreign key
'FK__USERGROUP__userI__6BE40491'.
2016-01-21 17:25:25,907 INFO [geonetwork.databasemigration] -
Errors occurs during SQL migration file: There are no primary or candidate
keys in the referenced table 'Users' that match the referencing column list
in the foreign key 'FK__USERGROUP__userI__6BE40491'.
2016-01-21 17:25:25,923 INFO [geonetwork.databasemigration] - -
SQL migration
prefix:6-copy-from-tmp- ...
running tasks for 3.0.0...
Java migration class:SetSequenceValueToMaxOfMetadataAndStats
2016-01-21 17:25:25,939 INFO [geonetwork.databasemigration] - -
SQL migration
file:C:\Tomcat\apache-tomcat-8.0.29\webapps\geonetwork\WEB-INF\classes\setup\sql\migrate\v300
prefix:migrate- ...
2016-01-21 17:25:25,954 WARN [geonetwork.database] - SQL failure for:
INSERT INTO Settings (name, value, datatype, position, internal) VALUES
('region/getmap/background', 'osm', 0, 9590, 'n'), error is:Cannot insert
the value NULL into column 'id', table 'geonet.dbo.Settings'; column does
not allow nulls. INSERT fails.
2016-01-21 17:25:25,954 INFO [geonetwork.databasemigration] -
Errors occurs during SQL migration file: Cannot insert the value NULL into
column 'id', table 'geonet.dbo.Settings'; column does not allow nulls.
INSERT fails.
2016-01-21 17:25:25,970 INFO [geonetwork.databasemigration] - -
SQL migration
prefix:migrate-cswservice- ...
2016-01-21 17:25:25,970 WARN [geonetwork.database] - SQL failure for:
ALTER TABLE ServiceParameters ADD COLUMN occur varchar(1) default '+',
error is:Incorrect syntax near the keyword 'COLUMN'.
Errors occurs during SQL migration file: Incorrect syntax near the keyword
'COLUMN'.
2016-01-21 17:25:25,985 INFO [geonetwork.databasemigration] - -
running tasks for 3.0.1...
SQL migration
file:C:\Tomcat\apache-tomcat-8.0.29\webapps\geonetwork\WEB-INF\classes\setup\sql\migrate\v301
prefix:migrate- ...
2016-01-21 17:25:25,985 WARN [geonetwork.database] - SQL failure for:
('map/is3DModeAllowed', 'false', 2, 9593, 'n'), error is:Cannot insert the
value NULL into column 'id', table 'geonet.dbo.Settings'; column does not
2016-01-21 17:25:26,001 INFO [geonetwork.databasemigration] -
INSERT fails.
2016-01-21 17:25:26,001 INFO [geonetwork.databasemigration] - -
running tasks for 3.0.2...
SQL migration
file:C:\Tomcat\apache-tomcat-8.0.29\webapps\geonetwork\WEB-INF\classes\setup\sql\migrate\v302
prefix:migrate- ...
2016-01-21 17:25:26,017 WARN [geonetwork.database] - SQL failure for:
('metadata/workflow/draftWhenInGroup', '', 0, 100002, 'n'), error is:Cannot
insert the value NULL into column 'id', table 'geonet.dbo.Settings'; column
does not allow nulls. INSERT fails.
2016-01-21 17:25:26,017 INFO [geonetwork.databasemigration] -
INSERT fails.
2016-01-21 17:25:26,032 WARN [geonetwork.databasemigration] - Error
occurs during migration. Check the log file for more details.
2016-01-21 17:25:29,231 ERROR [org.hibernate.tool.hbm2ddl.SchemaUpdate] -
HHH000388: Unsuccessful: alter table CategoriesDes add constraint
FK_69p88c8991letuoq16jddi307 foreign key (idDes) references Categories
Foreign key 'FK_69p88c8991letuoq16jddi307' has implicit reference to object
'Categories' which does not have a primary key defined on it.
HHH000388: Unsuccessful: alter table Groups add constraint
FK_balio8qkvhnitbdw241e4ryb8 foreign key (defaultCategory_id) references
Categories
Foreign key 'FK_balio8qkvhnitbdw241e4ryb8' has implicit reference to object
HHH000388: Unsuccessful: alter table GroupsDes add constraint
FK_4p4fkvpk92euh0l1hrphqmhgp foreign key (idDes) references Groups
2016-01-21 17:25:29,247 ERROR [org.hibernate.tool.hbm2ddl.SchemaUpdate] -
Foreign key 'FK_4p4fkvpk92euh0l1hrphqmhgp' has implicit reference to object
'Groups' which does not have a primary key defined on it.
HHH000388: Unsuccessful: alter table IsoLanguagesDes add constraint
FK_emeavjsu8j7v000m8iyu0skgo foreign key (idDes) references IsoLanguages
Foreign key 'FK_emeavjsu8j7v000m8iyu0skgo' has implicit reference to object
'IsoLanguages' which does not have a primary key defined on it.
HHH000388: Unsuccessful: alter table MetadataCateg add constraint
FK_eq06r8xcyiiibgyl6q3r1ojk4 foreign key (categoryId) references Categories
Foreign key 'FK_eq06r8xcyiiibgyl6q3r1ojk4' has implicit reference to object
FK_691tu1a51wae9905g6gtyjopt foreign key (metadataId) references Metadata
Foreign key 'FK_691tu1a51wae9905g6gtyjopt' has implicit reference to object
'Metadata' which does not have a primary key defined on it.
HHH000388: Unsuccessful: alter table MetadataNotifications add constraint
FK_jbkvo3w3g4twk2bo1b8jn0sw8 foreign key (notifierId) references
MetadataNotifiers
Foreign key 'FK_jbkvo3w3g4twk2bo1b8jn0sw8' has implicit reference to object
'MetadataNotifiers' which does not have a primary key defined on it.
HHH000388: Unsuccessful: alter table MetadataStatus add constraint
FK_b6th8n92l16998imlr7oqytaf foreign key (statusId) references StatusValues
Foreign key 'FK_b6th8n92l16998imlr7oqytaf' has implicit reference to object
'StatusValues' which does not have a primary key defined on it.
HHH000388: Unsuccessful: alter table OperationsDes add constraint
FK_si4h3s9vk085jarb8xbfw1uv foreign key (idDes) references Operations
Foreign key 'FK_si4h3s9vk085jarb8xbfw1uv' has implicit reference to object
'Operations' which does not have a primary key defined on it.
HHH000388: Unsuccessful: alter table Params add constraint
FK_6d52bqoq3c2eitpdq5r7y872g foreign key (requestid) references Requests
Foreign key 'FK_6d52bqoq3c2eitpdq5r7y872g' has implicit reference to object
'Requests' which does not have a primary key defined on it.
Foreign key 'FK_t32t4xtdqmjhl8xmjpe95e474' has implicit reference to object
'Services' which does not have a primary key defined on it.
HHH000388: Unsuccessful: alter table SourcesDes add constraint
FK_c3jxktm4qwai73lddsm5fiecb foreign key (idDes) references Sources
2016-01-21 17:25:29,262 ERROR [org.hibernate.tool.hbm2ddl.SchemaUpdate] -
Foreign key 'FK_c3jxktm4qwai73lddsm5fiecb' has implicit reference to object
'Sources' which does not have a primary key defined on it.
HHH000388: Unsuccessful: alter table StatusValuesDes add constraint
FK_2vkxyjsd2d3tdwn38p5yjhb71 foreign key (idDes) references StatusValues
Foreign key 'FK_2vkxyjsd2d3tdwn38p5yjhb71' has implicit reference to object
HHH000388: Unsuccessful: alter table UserAddress add constraint
FK_f8ecen6kghqbp0tkqc4cdr6q1 foreign key (userid) references Users
Foreign key 'FK_f8ecen6kghqbp0tkqc4cdr6q1' has implicit reference to object
'Users' which does not have a primary key defined on it.
HHH000388: Unsuccessful: alter table UserGroups add constraint
FK_py108k658ig7v8luqf88sgrtu foreign key (groupId) references Groups
Foreign key 'FK_py108k658ig7v8luqf88sgrtu' has implicit reference to object
FK_1x9ybprsvnlrawsk1a7nwgpq6 foreign key (userId) references Users
Foreign key 'FK_1x9ybprsvnlrawsk1a7nwgpq6' has implicit reference to object
HHH000388: Unsuccessful: alter table email add constraint
FK_tlb3l7e2xg65r3nkoahbqlmii foreign key (User_id) references Users
Foreign key 'FK_tlb3l7e2xg65r3nkoahbqlmii' has implicit reference to object
HHH000388: Unsuccessful: alter table group_category add constraint
FK_j8nj5ssnar3byh882nuf38tqw foreign key (CATEGORY_ID) references Categories
Foreign key 'FK_j8nj5ssnar3byh882nuf38tqw' has implicit reference to object
FK_r1y7atocbww201qaj87h9j62e foreign key (GROUP_ID) references Groups
Foreign key 'FK_r1y7atocbww201qaj87h9j62e' has implicit reference to object
2016-01-21 17:25:33,147 DEBUG [geonetwork.databasemigration] - DB Migration
2016-01-21 17:25:33,162 INFO [geonetwork.databasemigration] - -
Migration ...
2016-01-21 17:25:33,162 INFO [geonetwork.databasemigration] - Webapp
2016-01-21 17:25:33,162 DEBUG [geonetwork.databasemigration] -
encoding="UTF-8"?>
2016-01-21 17:25:33,178 INFO [geonetwork.databasemigration] - -
running tasks for 3.0.3...
SQL migration
file:C:\Tomcat\apache-tomcat-8.0.29\webapps\geonetwork\WEB-INF\classes\setup\sql\migrate\v303
prefix:migrate- ...
2016-01-21 17:25:33,178 WARN [geonetwork.database] - SQL failure for:
INSERT INTO MetadataIdentifierTemplate (id, name, template, isprovided)
VALUES (0, 'Custom URN', '', 'y'), error is:Violation of PRIMARY KEY
constraint 'PK__Metadata__3213E83F382A8C46'. Cannot insert duplicate key in
object 'dbo.MetadataIdentifierTemplate'. The duplicate key value is (0).
2016-01-21 17:25:33,194 WARN [geonetwork.databasemigration] - Error
2016-01-21 17:25:39,808 WARN [geonetwork.data.directory] - - Data
properties.
2016-01-21 17:25:39,980 ERROR [geonetwork.settings] - Requested setting
with name: system/z3950/enable not found. Add it to the settings table.
with name: system/z3950/port not found. Add it to the settings table.
2016-01-21 17:25:40,494 WARN [geonetwork.schemamanager] - Cannot resolve
http://www.w3.org/2001/03/xml.xsd: will append last component to current
path (not sure it will help though!)
2016-01-21 17:25:40,791 WARN [geonetwork.schemamanager] - WARNING:
gco:Record is a global element without a type - assuming a string
2016-01-21 17:25:41,087 WARN [geonetwork.schemamanager] - WARNING:
schema-substitutions.xml has wiped out XSD substitution list for
gml:VerticalDatum
gml:CoordinateSystemAxis
gml:VerticalCS
2016-01-21 17:25:41,103 WARN [geonetwork.schemamanager] - WARNING:
2016-01-21 17:25:43,568 ERROR [geonetwork.settings] - Requested setting
with name: system/requestedLanguage/ignorechars not found. Add it to the
settings table.
2016-01-21 17:25:43,630 ERROR [geonetwork.settings] - Requested setting
settings table.
/***********************There were thousands of this same error, i cut them
to save space...**************************************/
2016-01-21 17:25:46,173 ERROR [geonetwork.settings] - Requested setting
settings table.
2016-01-21 17:25:46,485 ERROR [geonetwork.settings] - Requested setting
with name: system/indexoptimizer/enable not found. Add it to the settings
table.
with name: system/server/host not found. Add it to the settings table.
with name: system/server/securePort not found. Add it to the settings
table.
with name: system/server/port not found. Add it to the settings table.
with name: system/site/svnUuid not found. Add it to the settings table.
2016-01-21 17:25:46,485 ERROR [jeeves.engine] - Raised exception while
2016-01-21 17:25:46,485 ERROR [jeeves.engine] - Handler :
2016-01-21 17:25:46,485 ERROR [jeeves.engine] - Exception :
java.util.NoSuchElementException: There is no existing setting element with
the key: system/site/svnUuid
2016-01-21 17:25:46,500 ERROR [jeeves.engine] - Message : There is no
existing setting element with the key: system/site/svnUuid
2016-01-21 17:25:46,500 ERROR [jeeves.engine] - Stack :
at
org.fao.geonet.kernel.setting.SettingManager.setValue(SettingManager.java:280)
at org.fao.geonet.kernel.SvnManager.init(SvnManager.java:126)
at org.fao.geonet.Geonetwork.start(Geonetwork.java:345)
at
at
at
at
at
at
at
at
2016-01-21 17:25:46,500 ERROR [jeeves.engine] - {Message=There is no
existing setting element with the key: system/site/svnUuid, Error=Raised
exception while starting the application. Fix the error and restart.,
Exception=java.util.NoSuchElementException: There is no existing setting
Stack=java.util.NoSuchElementException: There is no existing setting
at
at
at
at
at
at
at
at
at
On Thu, Jan 21, 2016 at 11:05 AM, BillyZ Design <billyz313@anonymised.com> wrote:
Migration / Running 'class org.apache.commons.dbcp.BasicDataSource' after
Migration ...
Webapp version:3.0.3-0 subversion:SNAPSHOT
migration required.
have permissions.
null
have permissions.
have permissions.
have permissions.
'Services'.
org.springframework.orm.jpa.JpaTransactionManager' after initialization of
Migration ...
migration required.
properties.
execute statement
at
at
at
at
at
at
at
at
at
at
at
at
at
statement
at
at
at
at
at
at
at
at
at
... 27 more
name 'true'.
at
at
at
at
at
at
at
at
at
at
at
at
... 32 more
transaction
at
at
at
at
at
at
at
at
at
at
at
at
at
... 26 more
statement
at
at
at
at
at
at
at
at
at
... 27 more
name 'true'.
at
at
at
at
at
at
at
at
at
at
at
at
... 32 more
at
at
at
at
at
at
at
at
at
at
at
at
at
... 26 more
statement
at
at
at
at
at
at
at
at
at
... 27 more
name 'true'.
at
at
at
at
at
at
at
at
at
at
at
at
... 32 more
at
at
at
at
at
at
at
at
at
... 21 more
at
at
at
at
... 26 more
statement
at
at
at
at
at
at
at
at
at
... 27 more
name 'true'.
at
at
at
at
at
at
at
at
at
at
at
at
... 32 more
at
at
at
at
at
at
at
at
at
... 21 more
at
at
at
at
... 26 more
statement
at
at
at
at
at
at
at
at
at
... 27 more
name 'true'.
at
at
at
at
at
at
at
at
at
at
at
at
... 32 more
that case.
using Jetty.
first run.
  <constructor-arg
    </bean>
I am using tomcat.
Hi Billy
*Luke Bassett*
*Luke Bassett*
*Luke Bassett*
Ok getting somewhere
Errors look like the schema deployment is having troubles and then your
instance cant find required entries.
Are you setting up a new db or upgrading a db from an older instance?
Luke
Migration ...
migration required.
have permissions.
null
have permissions.
have permissions.
have permissions.
'Services'.
Migration ...
migration required.
properties.
execute statement
at
at
at
at
at
at
at
at
at
at
at
at
at
statement
at
at
at
at
at
at
at
at
at
... 27 more
name 'true'.
at
at
at
at
at
at
at
at
at
at
at
at
... 32 more
transaction
at
at
at
at
at
at
at
at
at
at
at
at
at
... 26 more
statement
at
at
at
at
at
at
at
at
at
... 27 more
name 'true'.
at
at
at
at
at
at
at
at
at
at
at
at
... 32 more
at
at
at
at
at
at
at
at
at
at
at
at
at
... 26 more
statement
at
at
at
at
at
at
at
at
at
... 27 more
name 'true'.
at
at
at
at
at
at
at
at
at
at
at
at
... 32 more
at
at
at
at
at
at
at
at
at
... 21 more
at
at
at
at
... 26 more
statement
at
at
at
at
at
at
at
at
at
... 27 more
name 'true'.
at
at
at
at
at
at
at
at
at
at
at
at
... 32 more
at
at
at
at
at
at
at
at
at
... 21 more
at
at
at
at
... 26 more
statement
at
at
at
at
at
at
at
at
at
... 27 more
name 'true'.
at
at
at
at
at
at
at
at
at
at
at
at
... 32 more
that case.
using Jetty.
first run.
  <constructor-arg
    </bean>
I am using tomcat.
Hi Billy
*Luke Bassett*
* <javascript:_e(%7B%7D,'cvml','lukembassett@anonymised.com');>*Melbourne
Australia
*Luke Bassett*
Australia
*Luke Bassett*
Australia
*Luke Bassett*
I have gone thru the sql commands one by one and fixed the issues. The
site now works, however the user logins no longer work. Is there a way to
reset the passwords thru the db or a script? I am also having issues with
the password reset link on the sign in page. It returns the following
error:
Error getting password information
InvalidDataAccessResourceUsageException
Any suggestions?
On Mon, Jan 25, 2016 at 2:50 PM, Luke <coolhandluka@anonymised.com> wrote:
Not sure on that one sorry - might be best to ask the group
On Tue, Jan 26, 2016 at 5:54 AM, BillyZ Design <billyz313@anonymised.com>
wrote:
Thanx Luke.
error:
Any suggestions?
On Fri, Jan 22, 2016 at 6:44 PM, Luke <coolhandluka@anonymised.com> wrote:
Looks like the sequence of SQL commands to update an exisitng db isnt
working then.
You could try work out why it isnt and update the SQL files
Otherwise you could let it build a new db and compare the schema from
one to the other - potentially you could manually restructure your old db.
No quick fix in either case unfortunately
On Sat, Jan 23, 2016 at 3:18 AM, BillyZ Design <billyz313@anonymised.com>
wrote:
I am trying to upgrade. I have debugged some of the error messages and
here is the top portion of the new log.
2016-01-21 22:08:24,635 DEBUG [geonetwork.databasemigration] - DB
2016-01-21 22:08:24,651 INFO [geonetwork.databasemigration] - -
Migration ...
2016-01-21 22:08:26,320 INFO [geonetwork.databasemigration] -
2016-01-21 22:08:26,336 DEBUG [geonetwork.databasemigration] -
2016-01-21 22:08:26,336 INFO [geonetwork.databasemigration] -
encoding="UTF-8"?>
2016-01-21 22:08:26,336 INFO [geonetwork.databasemigration] - -
- SQL migration
2016-01-21 22:08:26,351 WARN [geonetwork.database] - SQL failure for:
2016-01-21 22:08:26,351 INFO [geonetwork.databasemigration] -
2016-01-21 22:08:26,367 INFO [geonetwork.databasemigration] -
- Java migration class:v2110.MoveHarvesterSettings
- SQL migration
2016-01-21 22:08:26,398 WARN [geonetwork.database] - SQL failure for:
'Operations'.
2016-01-21 22:08:26,398 INFO [geonetwork.databasemigration] -
2016-01-21 22:08:26,414 INFO [geonetwork.databasemigration] -
- SQL migration
2016-01-21 22:08:26,429 WARN [geonetwork.database] - SQL failure for:
2016-01-21 22:08:26,429 INFO [geonetwork.databasemigration] -
2016-01-21 22:08:26,445 INFO [geonetwork.databasemigration] -
- SQL migration
2016-01-21 22:08:26,461 WARN [geonetwork.database] - SQL failure for:
INSERT INTO USERGROUPS_TMP (userid, groupid, profile) SELECT userid,
groupid, 0 FROM USERGROUPS where profile='Administrator', error
is:Conversion failed when converting the varchar value 'Administrator' to
data type int.
2016-01-21 22:08:26,461 INFO [geonetwork.databasemigration] -
  Errors occurs during SQL migration file: Conversion failed when
converting the varchar value 'Administrator' to data type int.
- SQL migration
2016-01-21 22:08:26,476 WARN [geonetwork.database] - SQL failure for:
INSERT INTO USERGROUPS SELECT * FROM USERGROUPS_TMP, error is:Violation of
PRIMARY KEY constraint 'PK__USERGROU__6456E09C931E7CAF'. Cannot insert
duplicate key in object 'dbo.USERGROUPS'. The duplicate key value is (5, 3,
1).
2016-01-21 22:08:26,492 INFO [geonetwork.databasemigration] -
constraint 'PK__USERGROU__6456E09C931E7CAF'. Cannot insert duplicate key in
object 'dbo.USERGROUPS'. The duplicate key value is (5, 3, 1).
2016-01-21 22:08:26,507 INFO [geonetwork.databasemigration] -
- SQL migration
2016-01-21 22:08:26,523 INFO [geonetwork.databasemigration] - -
- Java migration class:SetSequenceValueToMaxOfMetadataAndStats
2016-01-21 22:08:26,539 INFO [geonetwork.databasemigration] -
- SQL migration
prefix:migrate- ...
2016-01-21 22:08:26,554 WARN [geonetwork.database] - SQL failure for:
2016-01-21 22:08:26,554 INFO [geonetwork.databasemigration] -
into column 'id', table 'geonet.dbo.Settings'; column does not allow nulls.
INSERT fails.
2016-01-21 22:08:26,570 INFO [geonetwork.databasemigration] -
- SQL migration
2016-01-21 22:08:26,570 WARN [geonetwork.database] - SQL failure for:
keyword 'COLUMN'.
2016-01-21 22:08:26,585 INFO [geonetwork.databasemigration] - -
- SQL migration
prefix:migrate- ...
2016-01-21 22:08:26,601 WARN [geonetwork.database] - SQL failure for:
2016-01-21 22:08:26,601 INFO [geonetwork.databasemigration] -
INSERT fails.
2016-01-21 22:08:26,617 INFO [geonetwork.databasemigration] - -
- SQL migration
prefix:migrate- ...
2016-01-21 22:08:26,617 WARN [geonetwork.database] - SQL failure for:
INSERT fails.
2016-01-21 22:08:26,632 WARN [geonetwork.databasemigration] -
Error occurs during migration. Check the log file for more details.
2016-01-21 22:08:33,154 DEBUG [geonetwork.databasemigration] - DB
2016-01-21 22:08:33,154 INFO [geonetwork.databasemigration] - -
Migration ...
2016-01-21 22:08:33,170 INFO [geonetwork.databasemigration] -
2016-01-21 22:08:33,170 DEBUG [geonetwork.databasemigration] -
encoding="UTF-8"?>
2016-01-21 22:08:33,170 INFO [geonetwork.databasemigration] - -
- SQL migration
prefix:migrate- ...
2016-01-21 22:08:33,185 WARN [geonetwork.database] - SQL failure for:
2016-01-21 22:08:33,185 INFO [geonetwork.databasemigration] -
2016-01-21 22:08:33,185 WARN [geonetwork.databasemigration] -
2016-01-21 22:08:39,035 WARN [geonetwork.data.directory] - - Data
properties.
2016-01-21 22:08:39,051 WARN [geonetwork.data.directory] - - Data
2016-01-21 22:08:39,254 WARN [jeeves.apphand] - Cannot initialize
Z39.50 repositories : Illegal char <:> at index 2:
/C:/Tomcat/apache-tomcat-8.0.29/webapps/geonetwork/WEB-INF/classes/JZKitConfig.xml
2016-01-21 22:08:39,254 ERROR [jeeves.apphand] - Repositories file
builder FAILED - Z3950 server disabled and Z3950 client services (remote
search, harvesting) may not work.
2016-01-21 22:08:39,753 WARN [geonetwork.schemamanager] - Cannot
resolve http://www.w3.org/2001/03/xml.xsd: will append last component
to current path (not sure it will help though!)
2016-01-21 22:08:40,065 WARN [geonetwork.schemamanager] - WARNING:
2016-01-21 22:08:40,346 WARN [geonetwork.schemamanager] - WARNING:
2016-01-21 22:08:40,361 WARN [geonetwork.schemamanager] - WARNING:
gml:VerticalDatum
gml:VerticalCS
2016-01-21 22:08:40,377 WARN [geonetwork.schemamanager] - WARNING:
2016-01-21 22:08:44,672 WARN [geonetwork.lucene] - Stopwords file with
incorrect ISO 639-2 language as filename: README
2016-01-21 22:08:45,171 WARN [geonetwork.settings] - Requested
setting with name: system/indexoptimizer/enable but null value found. Check
the settings table.
2016-01-21 22:08:47,636 ERROR [geonetwork.settings] - Requested
setting with name: system/proxy/use not found. Add it to the settings
table.
setting with name: system/inspire/enable not found. Add it to the settings
table.
2016-01-21 22:08:57,051 WARN [geonetwork.settings] - Requested
setting with name: system/metadata/allThesaurus but null value found. Check
the settings table.
2016-01-21 22:08:57,457 ERROR [geonetwork.datamanager] - The metadata
document index with id=4 is corrupt/invalid - ignoring it. Error: JDBC
exception on Hibernate data access: SQLException for SQL [n/a]; SQL state
[null]; error code [0]; Could not read entity state from ResultSet :
EntityKey[org.fao.geonet.domain.User#1]; nested exception is
org.hibernate.exception.GenericJDBCException: Could not read entity state
from ResultSet : EntityKey[org.fao.geonet.domain.User#1]
org.springframework.orm.hibernate3.HibernateJdbcException: JDBC
at
org.springframework.orm.hibernate3.SessionFactoryUtils.convertHibernateAccessException(SessionFactoryUtils.java:651)
at
org.springframework.orm.jpa.vendor.HibernateJpaDialect.translateExceptionIfPossible(HibernateJpaDialect.java:106)
at
org.springframework.orm.jpa.AbstractEntityManagerFactoryBean.translateExceptionIfPossible(AbstractEntityManagerFactoryBean.java:403)
at
org.springframework.dao.support.ChainedPersistenceExceptionTranslator.translateExceptionIfPossible(ChainedPersistenceExceptionTranslator.java:58)
at
org.springframework.dao.support.DataAccessUtils.translateIfNecessary(DataAccessUtils.java:213)
at
org.springframework.dao.support.PersistenceExceptionTranslationInterceptor.invoke(PersistenceExceptionTranslationInterceptor.java:163)
at
org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:172)
at
org.springframework.data.jpa.repository.support.LockModeRepositoryPostProcessor$LockModePopulatingMethodIntercceptor.invoke(LockModeRepositoryPostProcessor.java:92)
at
at
org.springframework.aop.interceptor.ExposeInvocationInterceptor.invoke(ExposeInvocationInterceptor.java:91)
at
at
org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:204)
at com.sun.proxy.$Proxy118.findOne(Unknown Source)
at org.fao.geonet.kernel.DataManager.indexMetadata(DataManager.java:563)
at
org.fao.geonet.kernel.IndexMetadataTask.run(IndexMetadataTask.java:90)
at
at
Caused by: org.hibernate.exception.GenericJDBCException: Could not read
entity state from ResultSet : EntityKey[org.fao.geonet.domain.User#1]
at
org.hibernate.exception.internal.StandardSQLExceptionConverter.convert(StandardSQLExceptionConverter.java:54)
at
at
at
org.hibernate.loader.plan.exec.process.internal.EntityReferenceInitializerImpl.loadFromResultSet(EntityReferenceInitializerImpl.java:339)
at
org.hibernate.loader.plan.exec.process.internal.EntityReferenceInitializerImpl.hydrateEntityState(EntityReferenceInitializerImpl.java:251)
at
org.hibernate.loader.plan.exec.process.internal.AbstractRowReader.readRow(AbstractRowReader.java:107)
at
org.hibernate.loader.plan.exec.internal.EntityLoadQueryDetails$EntityLoaderRowReader.readRow(EntityLoadQueryDetails.java:255)
at
org.hibernate.loader.plan.exec.process.internal.ResultSetProcessorImpl.extractResults(ResultSetProcessorImpl.java:129)
at
org.hibernate.loader.plan.exec.internal.AbstractLoadPlanBasedLoader.executeLoad(AbstractLoadPlanBasedLoader.java:138)
at
org.hibernate.loader.plan.exec.internal.AbstractLoadPlanBasedLoader.executeLoad(AbstractLoadPlanBasedLoader.java:102)
at
org.hibernate.loader.entity.plan.AbstractLoadPlanBasedEntityLoader.load(AbstractLoadPlanBasedEntityLoader.java:186)
at
org.hibernate.persister.entity.AbstractEntityPersister.load(AbstractEntityPersister.java:4126)
at
org.hibernate.event.internal.DefaultLoadEventListener.loadFromDatasource(DefaultLoadEventListener.java:503)
at
org.hibernate.event.internal.DefaultLoadEventListener.doLoad(DefaultLoadEventListener.java:468)
at
org.hibernate.event.internal.DefaultLoadEventListener.load(DefaultLoadEventListener.java:213)
at
org.hibernate.event.internal.DefaultLoadEventListener.proxyOrLoad(DefaultLoadEventListener.java:275)
at
org.hibernate.event.internal.DefaultLoadEventListener.onLoad(DefaultLoadEventListener.java:151)
at org.hibernate.internal.SessionImpl.fireLoad(SessionImpl.java:1070)
at org.hibernate.internal.SessionImpl.access$2000(SessionImpl.java:176)
at
org.hibernate.internal.SessionImpl$IdentifierLoadAccessImpl.load(SessionImpl.java:2551)
at org.hibernate.internal.SessionImpl.get(SessionImpl.java:955)
at
org.hibernate.jpa.spi.AbstractEntityManagerImpl.find(AbstractEntityManagerImpl.java:1110)
at
org.hibernate.jpa.spi.AbstractEntityManagerImpl.find(AbstractEntityManagerImpl.java:1068)
at sun.reflect.GeneratedMethodAccessor117.invoke(Unknown Source)
at
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:497)
at
org.springframework.orm.jpa.SharedEntityManagerCreator$SharedEntityManagerInvocationHandler.invoke(SharedEntityManagerCreator.java:241)
at com.sun.proxy.$Proxy75.find(Unknown Source)
at
org.springframework.data.jpa.repository.support.SimpleJpaRepository.findOne(SimpleJpaRepository.java:212)
at sun.reflect.GeneratedMethodAccessor116.invoke(Unknown Source)
at
at
org.springframework.data.repository.core.support.RepositoryFactorySupport$QueryExecutorMethodInterceptor.executeMethodOn(RepositoryFactorySupport.java:344)
at
org.springframework.data.repository.core.support.RepositoryFactorySupport$QueryExecutorMethodInterceptor.invoke(RepositoryFactorySupport.java:329)
at
at
org.springframework.transaction.interceptor.TransactionInterceptor$1.proceedWithInvocation(TransactionInterceptor.java:96)
at
org.springframework.transaction.interceptor.TransactionAspectSupport.invokeWithinTransaction(TransactionAspectSupport.java:260)
at
org.springframework.transaction.interceptor.TransactionInterceptor.invoke(TransactionInterceptor.java:94)
at
at
org.springframework.dao.support.PersistenceExceptionTranslationInterceptor.invoke(PersistenceExceptionTranslationInterceptor.java:155)
... 12 more
Caused by: com.microsoft.sqlserver.jdbc.SQLServerException: An error
occurred while converting the varchar value to JDBC data type INTEGER.
at com.microsoft.sqlserver.jdbc.DDC.convertStreamToObject(DDC.java:475)
at com.microsoft.sqlserver.jdbc.ServerDTVImpl.getValue(dtv.java:2536)
at com.microsoft.sqlserver.jdbc.DTV.getValue(dtv.java:193)
at com.microsoft.sqlserver.jdbc.Column.getValue(Column.java:132)
at
com.microsoft.sqlserver.jdbc.SQLServerResultSet.getValue(SQLServerResultSet.java:2082)
at
com.microsoft.sqlserver.jdbc.SQLServerResultSet.getValue(SQLServerResultSet.java:2067)
at
com.microsoft.sqlserver.jdbc.SQLServerResultSet.getInt(SQLServerResultSet.java:2319)
at
org.apache.commons.dbcp.DelegatingResultSet.getInt(DelegatingResultSet.java:275)
at
at
at
org.hibernate.type.EnumType$OrdinalEnumValueMapper.getValue(EnumType.java:372)
at org.hibernate.type.EnumType.nullSafeGet(EnumType.java:107)
at org.hibernate.type.CustomType.nullSafeGet(CustomType.java:127)
at org.hibernate.type.AbstractType.hydrate(AbstractType.java:106)
at
org.hibernate.persister.entity.AbstractEntityPersister.hydrate(AbstractEntityPersister.java:2969)
at
org.hibernate.loader.plan.exec.process.internal.EntityReferenceInitializerImpl.loadFromResultSet(EntityReferenceInitializerImpl.java:324)
... 48 more
Caused by: java.lang.NumberFormatException: For input string:
"Administrator"
at
java.lang.NumberFormatException.forInputString(NumberFormatException.java:65)
at java.lang.Integer.parseInt(Integer.java:580)
at java.lang.Integer.valueOf(Integer.java:766)
at com.microsoft.sqlserver.jdbc.DDC.convertStringToObject(DDC.java:294)
at com.microsoft.sqlserver.jdbc.DDC.convertStreamToObject(DDC.java:438)
... 63 more
your instance cant find required entries.
Luke
when it ran so i could read the outputs. I found that it wasn't logging
due to permissions. I corrected the permissions and now i have the log. I
still am not sure what the issue is, but I have more info that you might be
able to help me with. Here is the log.
Migration ...
Error getting database version: Invalid column name 'id'.. Probably due to
an old version. Trying with new Settings structure.
migration required.
[org.hibernate.tool.hbm2ddl.SchemaUpdate] - HHH000388: Unsuccessful: create
table HarvesterData (harvesterUuid varchar(255) not null, key varchar(255)
not null, value varchar(255) not null, primary key (harvesterUuid, key))
[org.hibernate.tool.hbm2ddl.SchemaUpdate] - Incorrect syntax near the
keyword 'key'.
[org.hibernate.tool.hbm2ddl.SchemaUpdate] - HHH000388: Unsuccessful: alter
[org.hibernate.tool.hbm2ddl.SchemaUpdate] - Cannot find the object
"Services" because it does not exist or you do not have permissions.
table Services add class varchar(1024) not null
table ServiceParameters add constraint FK_t32t4xtdqmjhl8xmjpe95e474 foreign
[org.hibernate.tool.hbm2ddl.SchemaUpdate] - Foreign key
'FK_t32t4xtdqmjhl8xmjpe95e474' references invalid table 'Services'.
Migration ...
migration required.
Data directory properties is not set. Use geonetwork.dir or geonetwork.dir
properties.
Data directory provided could not be used. Using default location:
for: INSERT INTO Users (id, username, password, name, surname, profile,
kind, organisation, security, authtype, enabled) VALUES
execute statement
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
execute statement
at
at
at
at
at
at
at
at
at
at
... 27 more
column name 'true'.
at
at
at
at
at
at
at
at
at
at
at
at
... 32 more
transaction
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
... 26 more
execute statement
at
at
at
at
at
at
at
at
at
at
... 27 more
column name 'true'.
at
at
at
at
at
at
at
at
at
at
at
at
... 32 more
while trying to execute SQL
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
... 26 more
execute statement
at
at
at
at
at
at
at
at
at
at
... 27 more
column name 'true'.
at
at
at
at
at
at
at
at
at
at
at
at
... 32 more
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
... 21 more
at
at
at
at
... 26 more
execute statement
at
at
at
at
at
at
at
at
at
at
... 27 more
column name 'true'.
at
at
at
at
at
at
at
at
at
at
at
at
... 32 more
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
... 21 more
at
at
at
at
... 26 more
execute statement
at
at
at
at
at
at
at
at
at
at
... 27 more
column name 'true'.
at
at
at
at
at
at
at
at
at
at
at
at
... 32 more
in that case.
only using Jetty.
on the first run.
is hardcoded and not bound to the property from jdbc.properties
  <constructor-arg
    </bean>
changed the connection properties in WEB-INF/config-db/jdbc.properties.
I am using tomcat.
wrote:
Hi Billy
MSSQL?
*Luke Bassett*
Melbourne Australia
*Luke Bassett*
Melbourne Australia
*Luke Bassett*
Melbourne Australia
*Luke Bassett*
*Luke Bassett*
*Luke Bassett*
error:
Any suggestions?
Hi Billy
It still looks like GN is having troubles reading the DB
I would recommend validating your db schema against a working version of
3.0.*. Try get GN to generate a new db and then cross reference the schema
particularly the users tables.
On Tue, Jan 26, 2016 at 7:58 AM, BillyZ Design <billyz313@anonymised.com> wrote:
to
with
> error:
> Any suggestions?
Site24x7 APM Insight: Get Deep Visibility into Application Performance
APM + Mobile APM + RUM: Monitor 3 App instances at just $35/Month
Monitor end-to-end web transactions and take corrective actions now
Troubleshoot faster and improve end-user experience. Signup Now!
http://pubads.g.doubleclick.net/gampad/clk?id=267308311&iu=/4140
GeoNetwork-users mailing list
*Luke Bassett*
