Hi Jose,
Thanks for the quick response- I've replicated the index-fields file
structure and added in a default.xsl with just that statement in, but it
hasn't made any difference. I've turned up logging to development level and
I'm not seeing any errors in geonetwork.log relating to the problem.
However in catalina.out, I can see that it loads the metadata records, and
for the record with this schema it shows only the geonet component of the
metadata record, not the actual metadata, with this error:
<idxMsg>GNIDX-XSL||Failed to compile stylesheet. 1 error detected.</idxMsg>
Here's a larger snippet of what's shown for this record:
<metadata>
<popularity>0</popularity>
<owner>1</owner>
<userinfo>admin|admin|admin|Administrator</userinfo>
<isTemplate>n</isTemplate>
<rating>0</rating>
<root>gmd:MD_Metadata</root>
detected.</idxMsg>
<isHarvested>n</isHarvested>
<valid_xsd>1</valid_xsd>
<publishedForGroup>2</publishedForGroup>
<idxError>1</idxError>
<_locale>eng</_locale>
<valid_schematron-rules-iso>1</valid_schematron-rules-iso>
<valid>1</valid>
<logo>/images/logos/.png</logo>
<valid_schematron-rules-geonetwork>1</valid_schematron-rules-geonetwork>
<displayOrder>0</displayOrder>
<groupOwner>2</groupOwner>
<geonet:info xmlns:geonet="http://www.fao.org/geonetwork">
<id>2189</id>
<uuid>dc2e085b-a7cd-4c6b-94b3-ced61f5e55f0</uuid>
<schema>iso19139.gemini22</schema>
<createDate>2016-07-07T13:57:22</createDate>
<changeDate>2016-07-07T16:34:03</changeDate>
<source />
*snip*
I am struggling to find any other error messages relating to the problem
but I might be missing them amongst the extremely verbose logging!
Thanks
Jo
On Thu, Jul 7, 2016 at 4:36 PM, Jose Garcia <jose.garcia@anonymised.com> wrote:
Hi
Another thing, unless you need special indexing for this profile, you can
delegate to iso19139 files, for example for index-fields/default.xsl in
your profile in case no changes from iso19139 are required:
<xsl:stylesheet xmlns:xsl="http://www.w3.org/1999/XSL/Transform"
version="2.0">
<xsl:import href="../../iso19139/index-fields/default.xsl"/>
</xsl:stylesheet>
Thats a good strategy for most of the xsl in the profile that doesn't add
any change from iso19139, instead of copying the full content.
Jose García
On Thu, Jul 7, 2016 at 5:33 PM, Jose Garcia <jose.garcia@anonymised.com>
wrote:
Hi Jo
Note that for 3.0.x+ the index files should be placed in a folder
index-fields (see
https://github.com/geonetwork/core-geonetwork/tree/develop/schemas/iso19139/src/main/plugin/iso19139/index-fields)
with the names indicated there.
There's some fallback code to use index-fields.xsl, but better to use new
structure. Check if that can be the cause.
Jose García
On Thu, Jul 7, 2016 at 3:14 PM, Jo Cook <jocook@anonymised.com>
wrote:
Hi List,
We're in the process of converting Gemini 2.2 (ISO19139) to work with
Geonetwork 3 and we're a bit stuck with the initial search results page.
We're following the documentation here:
http://geonetwork-opensource.org/manuals/trunk/eng/users/customizing-application/implementing-a-schema-plugin.html
and using the schemas here: https://github.com/metadata101 as examples.
We can successfully load our schema into geonetwork and display and
validate metadata using it, but the search results page displays a blank
where the title/alternate title and URL should be. We can click the edit
icon to edit the record and in edit mode it displays correctly.
We believe it's related to the index-fields.xsl, but there is no
consistency between what's present in (for example)
https://github.com/metadata101/iso19139.anzlic and what's present in the
documentation (anzlic has no index-fields folder and no formatter
folder).
Please can someone give us some pointers on where we go to fix this?
Secondly, in edit mode, the drop down box to change views does not show
the
different view options, only the checkboxes to show details and tooltips.
Where does this information come from?
Many thanks
Jo
*Jo Cook*
t:+44 7930 524 155/twitter:@archaeogeek
Astun Technology Ltd, The Coach House, 17 West Street, Epsom, Surrey,
KT18
7RL, UK
t:+44 1372 744 009 w: astuntechnology.com twitter:@astuntech
<https://twitter.com/astuntech>
iShare - enterprise geographic intelligence platform
<https://astuntechnology.com/ishare/>
GeoServer, PostGIS and QGIS training
<https://astuntechnology.com/services/#training>
Helpdesk and customer portal
<http://support.astuntechnology.com/support/login>
Company registration no. 5410695. Registered in England and Wales.
Registered office: 120 Manor Green Road, Epsom, Surrey, KT19 8LN VAT no.
864201149.
Attend Shape: An AT&T Tech Expo July 15-16. Meet us at AT&T Park in San
Francisco, CA to explore cutting-edge tech and listen to tech luminaries
present their vision of the future. This family event has something for
everyone, including kids. Get more information and register today.
http://sdm.link/attshape
GeoNetwork-users mailing list
*Vriendelijke groeten / Kind regards,Jose García
<http://www.geocat.net/>Veenderweg 136721 WD BennekomThe NetherlandsT: +31
(0)318 416664 <+31318416664> <https://www.facebook.com/geocatbv>
<https://twitter.com/geocat_bv>
<https://plus.google.com/u/1/+GeocatNetbv/posts>Please consider the
environment before printing this email.*
*Jo Cook*
Astun Technology Ltd, The Coach House, 17 West Street, Epsom, Surrey, KT18
7RL, UK
864201149.
