hello,
I have implemented a GeoNetwork node and I would like to harverst metadata from a node implemented using the ESRI GIS portal toolkit. How do I go about that?
Your help will be higkly appreciated,
Kind regards,
Alicia
hello,
Kind regards,
Alicia
Hi Alicia,
You will have to configure a harvesting from a CSW server, pointing it to the GIS Portal Toolkit CSW URL. The manual explains how to configure the CSW harvesting. The Portal Toolkit documentation should help you to know the CSW endpoint.
Ciao,
Jeroen
On Jul 23, 2009, at 9:58 AM, Alicia Alicia wrote:
hello,
Kind regards,Alicia
GeoNetwork-users mailing list
geonetwork-users List Signup and Options
GeoNetwork OpenSource is maintained at GeoNetwork - Geographic Metadata Catalog download | SourceForge.net
Hi Alicia,
What is the URL to your GIS Portal Toolkit? I can then tell you its CSW endpoint.
Marten
-----Original Message-----
From: Jeroen Ticheler [mailto:Jeroen.Ticheler@anonymised.com]
Sent: Friday, July 31, 2009 3:56 PM
To: Alicia Alicia
Cc: geonetwork-users@lists.sourceforge.net
Subject: Re: [GeoNetwork-users] help on harvesting
Hi Alicia,
Ciao,
Jeroen
hello,
How do I go about that?Your help will be higkly appreciated,
Kind regards,Alicia
Let Crystal Reports handle the reporting - Free Crystal Reports 2008 30-Day
trial. Simplify your report design, integration and deployment - and focus on
what you do best, core application coding. Discover what's new with
Crystal Reports now. http://p.sf.net/sfu/bobj-july
