[GeoNetwork-users] Hervested nothing
Dear all,
today I realized that the harvest operation does not work fine.
Actually it was working fine up to 2/3 weeks ago, today checking
out the logs, the harvest logs I see my geonetwork does not retrive
metadata from another geonetwork.
Fortunately I manage both geonetwork, whom are both at version 2.10.3
My system consist in one geonetwork(managed by me), named GN1, who harvest metadata from 5 different geonetwork,
where one of these 5 is manage by me, GN2.
GN1 harvest fine the metadata from all the other 4, but not from the mine (GN2).
In the GN1, if I try to harvest from GN2, I got no error, but the sentence 'harvested nothing'.
Looking in the log file with tail -f command to see what happen on harvesting I have:
2015-07-31 15:29:51,664 INFO [jeeves.webapp.csw] - Dispatching operation : GetRecords
2015-07-31 15:29:51,664 INFO [jeeves.service] - -> dispatching to output for : csw
2015-07-31 15:29:51,664 INFO [jeeves.service] - -> writing xml for : csw
2015-07-31 15:29:51,666 INFO [jeeves.service] - -> output ended for : csw
2015-07-31 15:29:51,666 INFO [jeeves.service] - -> dispatch ended for : csw
2015-07-31 15:29:51,667 WARN [geonetwork.harvester] - Raised exception when searching : org.fao.geonet.csw.common.exceptions.InvalidParameterValueEx: code=InvalidParameterValue, locator=typeNames, message=invalid value
2015-07-31 15:29:51,668 DEBUG [geonetwork.harvester] - Raised exception when searching: invalid value
2015-07-31 15:29:51,668 DEBUG [geonetwork.harvester] - Changing to CSW harvester to use POST
2015-07-31 15:29:51,668 INFO [geonetwork.harvester] - Searching on : CNR (1..21)
POST params:<csw:GetRecords xmlns:csw="http://www.opengis.net/cat/csw/2.0.2&quot; xmlns:dc="http://purl.org/dc/elements/1.1/&quot; service="CSW" version="2.0.2" resultType="results" outputFormat="application/xml" outputSchema="http://www.isotc211.org/2005/gmd&quot; startPosition="1" maxRecords="20">
  <csw:Query typeNames="gmd:MD_Metadata,csw:Record">
    <csw:ElementSetName>summary</csw:ElementSetName>
    <csw:Constraint version="1.1.0">
      <ogc:Filter xmlns:ogc="http://www.opengis.net/ogc&quot;&gt;
        <ogc:PropertyIsEqualTo>
          <ogc:PropertyName>csw:AnyText</ogc:PropertyName>
          <ogc:Literal>EGIP</ogc:Literal>
        </ogc:PropertyIsEqualTo>
      </ogc:Filter>
    </csw:Constraint>
  </csw:Query>
</csw:GetRecords>
2015-07-31 15:29:51,676 INFO [jeeves.request] - ==========================================================
2015-07-31 15:29:51,676 INFO [jeeves.request] - HTML Request (from 146.48.97.132) : /geonetwork/srv/eng/csw
2015-07-31 15:29:51,677 INFO [jeeves.service] - Dispatching : csw
2015-07-31 15:29:51,678 INFO [jeeves.webapp.csw] - Received:
      </ogc:Filter>
    </csw:Constraint>
  </csw:Query>
</csw:GetRecords>
Error at xsl:stylesheet on line 9 column 56 of iso-summary.xsl:
  XTSE0120: No character data is allowed between top-level elements
Error at xsl:apply-templates on line 32 column 48 of iso-summary.xsl:
  XPST0081: XPath syntax error at char 12 on line 32 in {sdi:platform}:
    Undeclared namespace prefix {sdi}
2015-07-31 15:29:51,814 ERROR [jeeves.webapp.csw] - Error while transforming metadata with id : 151 using /dati/webapps/geonetwork/WEB-INF/data/config/schema_plugins/iso19139/present/csw/iso-summary.xsl
2015-07-31 15:29:51,816 ERROR [jeeves.webapp.csw] - (C) StackTrace:
javax.xml.transform.TransformerConfigurationException: Failed to compile stylesheet. 2 errors detected.
  at net.sf.saxon.PreparedStylesheet.prepare(PreparedStylesheet.java:176)
  at net.sf.saxon.TransformerFactoryImpl.newTemplates(TransformerFactoryImpl.java:139)
  at de.fzi.dbs.xml.transform.CachingTransformerFactory.newTransformer(CachingTransformerFactory.java:120)
  at de.fzi.dbs.xml.transform.CachingTransformerFactory.newTransformer(CachingTransformerFactory.java:76)
  at jeeves.utils.Xml.transform(Xml.java:519)
  at jeeves.utils.Xml.transform(Xml.java:400)
  at org.fao.geonet.kernel.csw.services.getrecords.SearchController.applyElementSetName(SearchController.java:306)
  at org.fao.geonet.kernel.csw.services.getrecords.SearchController.retrieveMetadata(SearchController.java:247)
  at org.fao.geonet.kernel.csw.services.getrecords.SearchController.retrieveMetadataMatchingResults(SearchController.java:178)
  at org.fao.geonet.kernel.csw.services.getrecords.SearchController.search(SearchController.java:127)
  at org.fao.geonet.kernel.csw.services.GetRecords.execute(GetRecords.java:267)
  at org.fao.geonet.kernel.csw.CatalogDispatcher.dispatchI(CatalogDispatcher.java:162)
  at org.fao.geonet.kernel.csw.CatalogDispatcher.dispatch(CatalogDispatcher.java:106)
  at org.fao.geonet.services.main.CswDiscoveryDispatcher.exec(CswDiscoveryDispatcher.java:115)
  at jeeves.server.dispatchers.ServiceInfo.execService(ServiceInfo.java:230)
  at jeeves.server.dispatchers.ServiceInfo.execServices(ServiceInfo.java:139)
  at jeeves.server.dispatchers.ServiceManager.dispatch(ServiceManager.java:430)
  at jeeves.server.dispatchers.ServiceManager.dispatch(ServiceManager.java:362)
  at jeeves.server.JeevesEngine.dispatch(JeevesEngine.java:806)
  at jeeves.server.sources.http.JeevesServlet.execute(JeevesServlet.java:216)
  at jeeves.server.sources.http.JeevesServlet.doPost(JeevesServlet.java:125)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:637)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:717)
  at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:290)
  at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
  at org.fao.geonet.monitor.webapp.WebappMetricsFilter.doFilter(WebappMetricsFilter.java:96)
  at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235)
  at org.fao.geonet.monitor.webapp.MetricsRegistryInitializerFilter.doFilter(MetricsRegistryInitializerFilter.java:31)
  at org.tuckey.web.filters.urlrewrite.RuleChain.handleRewrite(RuleChain.java:176)
  at org.tuckey.web.filters.urlrewrite.RuleChain.doRules(RuleChain.java:145)
  at org.tuckey.web.filters.urlrewrite.UrlRewriter.processRequest(UrlRewriter.java:92)
  at org.tuckey.web.filters.urlrewrite.UrlRewriteFilter.doFilter(UrlRewriteFilter.java:381)
  at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:322)
  at jeeves.config.springutil.GeonetworkFilterSecurityInterceptor.invoke(GeonetworkFilterSecurityInterceptor.java:46)
  at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:83)
  at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:334)
  at org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:113)
  at org.springframework.security.web.session.SessionManagementFilter.doFilter(SessionManagementFilter.java:103)
  at org.springframework.security.web.authentication.AnonymousAuthenticationFilter.doFilter(AnonymousAuthenticationFilter.java:113)
  at org.springframework.security.web.savedrequest.RequestCacheAwareFilter.doFilter(RequestCacheAwareFilter.java:45)
  at org.springframework.security.web.authentication.AbstractAuthenticationProcessingFilter.doFilter(AbstractAuthenticationProcessingFilter.java:182)
  at org.springframework.security.web.authentication.www.BasicAuthenticationFilter.doFilter(BasicAuthenticationFilter.java:150)
  at org.fao.geonet.kernel.security.PassthroughFilter.doFilter(PassthroughFilter.java:26)
  at org.springframework.security.web.authentication.logout.LogoutFilter.doFilter(LogoutFilter.java:105)
  at org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:87)
  at org.springframework.security.web.FilterChainProxy.doFilterInternal(FilterChainProxy.java:184)
  at org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:155)
  at org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:237)
  at org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:167)
  at org.springframework.web.filter.CharacterEncodingFilter.doFilterInternal(CharacterEncodingFilter.java:88)
  at org.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:76)
  at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:233)
  at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:191)
  at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:127)
  at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:102)
  at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109)
  at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:293)
  at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:859)
  at org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.process(Http11Protocol.java:602)
  at org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoint.java:489)
  at java.lang.Thread.run(Thread.java:701)
2015-07-31 15:29:51,816 WARN [jeeves.webapp.csw] - SearchController : Metadata not found or invalid schema : 151
..... [other blocks similar]
2015-07-31 15:29:51,964 WARN [jeeves.webapp.csw] - SearchController : Metadata not found or invalid schema : 154
2015-07-31 15:29:51,969 WARN [jeeves.webapp.csw] - SearchController : Metadata not found or invalid schema : 77
2015-07-31 15:29:51,973 WARN [jeeves.webapp.csw] - SearchController : Metadata not found or invalid schema : 149
2015-07-31 15:29:51,977 WARN [jeeves.webapp.csw] - SearchController : Metadata not found or invalid schema : 133
2015-07-31 15:29:51,981 WARN [jeeves.webapp.csw] - SearchController : Metadata not found or invalid schema : 140
2015-07-31 15:29:51,985 WARN [jeeves.webapp.csw] - SearchController : Metadata not found or invalid schema : 148
2015-07-31 15:29:51,989 WARN [jeeves.webapp.csw] - SearchController : Metadata not found or invalid schema : 128
2015-07-31 15:29:51,993 WARN [jeeves.webapp.csw] - SearchController : Metadata not found or invalid schema : 130
2015-07-31 15:29:51,994 INFO [jeeves.service] - -> dispatching to output for : csw
2015-07-31 15:29:51,994 INFO [jeeves.service] - -> writing xml for : csw
2015-07-31 15:29:51,995 INFO [jeeves.service] - -> output ended for : csw
2015-07-31 15:29:51,996 INFO [jeeves.service] - -> dispatch ended for : csw
2015-07-31 15:29:51,998 DEBUG [geonetwork.harvester] - Sent request POST /geonetwork/srv/eng/csw
User-Agent: Jakarta Commons-HttpClient/3.0.1
Host: geothermcatalog.igg.cnr.it
Cookie: JSESSIONID=6825BC28B3FA8BBA07A078A56C4F8B55
Content-Length: 771
Content-Type: application/xml; charset=UTF8
      </ogc:Filter>
    </csw:Constraint>
  </csw:Query>
</csw:GetRecords>
2015-07-31 15:29:52,000 DEBUG [geonetwork.harvester] - Number of child elements in response: 2
2015-07-31 15:29:52,000 DEBUG [geonetwork.harvester] - getRecordInfo (name): MD_Metadata
2015-07-31 15:29:52,001 DEBUG [geonetwork.harvester] - getRecordInfo (schema): iso19139
2015-07-31 15:29:52,002 WARN [geonetwork.harvester] - Record doesn't have a uuid : MD_Metadata
2015-07-31 15:29:52,002 DEBUG [geonetwork.harvester] - Records declared in response : 36
2015-07-31 15:29:52,002 DEBUG [geonetwork.harvester] - Records found in response : 1
2015-07-31 15:29:52,002 INFO [geonetwork.harvester] - Searching on : CNR (21..41)
POST params:<csw:GetRecords xmlns:csw="http://www.opengis.net/cat/csw/2.0.2&quot; xmlns:dc="http://purl.org/dc/elements/1.1/&quot; service="CSW" version="2.0.2" resultType="results" outputFormat="application/xml" outputSchema="http://www.isotc211.org/2005/gmd&quot; startPosition="21" maxRecords="20">
      </ogc:Filter>
    </csw:Constraint>
  </csw:Query>
</csw:GetRecords>
2015-07-31 15:29:52,008 INFO [jeeves.request] - ==========================================================
2015-07-31 15:29:52,009 INFO [jeeves.request] - HTML Request (from 146.48.97.132) : /geonetwork/srv/eng/csw
2015-07-31 15:29:52,010 INFO [jeeves.service] - Dispatching : csw
2015-07-31 15:29:52,010 INFO [jeeves.webapp.csw] - Received:
      </ogc:Filter>
    </csw:Constraint>
  </csw:Query>
</csw:GetRecords>
2015-07-31 15:29:52,105 WARN [jeeves.webapp.csw] - SearchController : Metadata not found or invalid schema : 132
2015-07-31 15:29:52,109 WARN [jeeves.webapp.csw] - SearchController : Metadata not found or invalid schema : 136
2015-07-31 15:29:52,114 WARN [jeeves.webapp.csw] - SearchController : Metadata not found or invalid schema : 129
2015-07-31 15:29:52,118 WARN [jeeves.webapp.csw] - SearchController : Metadata not found or invalid schema : 131
2015-07-31 15:29:52,122 WARN [jeeves.webapp.csw] - SearchController : Metadata not found or invalid schema : 135
2015-07-31 15:29:52,126 WARN [jeeves.webapp.csw] - SearchController : Metadata not found or invalid schema : 137
2015-07-31 15:29:52,130 WARN [jeeves.webapp.csw] - SearchController : Metadata not found or invalid schema : 138
2015-07-31 15:29:52,134 WARN [jeeves.webapp.csw] - SearchController : Metadata not found or invalid schema : 139
2015-07-31 15:29:52,139 WARN [jeeves.webapp.csw] - SearchController : Metadata not found or invalid schema : 141
2015-07-31 15:29:52,143 WARN [jeeves.webapp.csw] - SearchController : Metadata not found or invalid schema : 142
2015-07-31 15:29:52,147 WARN [jeeves.webapp.csw] - SearchController : Metadata not found or invalid schema : 143
2015-07-31 15:29:52,151 WARN [jeeves.webapp.csw] - SearchController : Metadata not found or invalid schema : 146
2015-07-31 15:29:52,155 WARN [jeeves.webapp.csw] - SearchController : Metadata not found or invalid schema : 147
2015-07-31 15:29:52,159 WARN [jeeves.webapp.csw] - SearchController : Metadata not found or invalid schema : 134
2015-07-31 15:29:52,163 WARN [jeeves.webapp.csw] - SearchController : Metadata not found or invalid schema : 144
2015-07-31 15:29:52,168 WARN [jeeves.webapp.csw] - SearchController : Metadata not found or invalid schema : 145
2015-07-31 15:29:52,168 INFO [jeeves.service] - -> dispatching to output for : csw
2015-07-31 15:29:52,168 INFO [jeeves.service] - -> writing xml for : csw
2015-07-31 15:29:52,170 INFO [jeeves.service] - -> output ended for : csw
2015-07-31 15:29:52,170 INFO [jeeves.service] - -> dispatch ended for : csw
2015-07-31 15:29:52,171 DEBUG [geonetwork.harvester] - Sent request POST /geonetwork/srv/eng/csw
Content-Length: 772
      </ogc:Filter>
    </csw:Constraint>
  </csw:Query>
</csw:GetRecords>
2015-07-31 15:29:52,171 DEBUG [geonetwork.harvester] - Search results:
<csw:GetRecordsResponse xmlns:csw="http://www.opengis.net/cat/csw/2.0.2&quot; xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance&quot; xsi:schemaLocation="http://www.opengis.net/cat/csw/2.0.2 http://schemas.opengis.net/csw/2.0.2/CSW-discovery.xsd&quot;&gt;
  <csw:SearchStatus timestamp="2015-07-31T15:29:52" />
  <csw:SearchResults numberOfRecordsMatched="36" numberOfRecordsReturned="0" elementSet="summary" nextRecord="21" />
</csw:GetRecordsResponse>
2015-07-31 15:29:52,171 DEBUG [geonetwork.harvester] - Number of child elements in response: 2
2015-07-31 15:29:52,171 DEBUG [geonetwork.harvester] - Records declared in response : 36
2015-07-31 15:29:52,171 DEBUG [geonetwork.harvester] - Records found in response : 0
2015-07-31 15:29:52,171 INFO [geonetwork.harvester] - Records added to result list : 0
2015-07-31 15:29:52,172 INFO [geonetwork.harvester] - Total records processed in all searches :0
2015-07-31 15:29:52,172 INFO [geonetwork.harvester] - Start of alignment for : CNR
2015-07-31 15:29:52,178 INFO [geonetwork.harvester] - End of alignment for : CNR
2015-07-31 15:29:52,178 INFO [geonetwork.harvester] - Ended harvesting from node : CNR (CswHarvester)
here the complete output:
http://paste.ubuntu.com/11973328/
Could you give me hints to solve this problem?
Best
Eugenio
