[GeoNetwork-users] Hiding the Map Viewer
Hi Folks,
I've been fiddling with 2.6.0RC0 to customise it for our purposes. I want
to remove the drop-down "map viewer" that appears in the main panel of the
main page because we won't use that function (ability to visualise data)
within geonetwork.
Unfortunately, while the rest of GeoNetwork is lovely and modifiable, that
particular feature seems to be pivotal to page layout. If I remove/rename
the line (specifically the "id" attribute):
          <div id="map_container" style="overflow:hidden; clear: both;">
Then not only does the bar map-bar disappear (good), but the entire page
completely loses its formatting (v. bad).
So the question is simple - is there a way to disable the drop-down map
without losing the formatting?
Jonathan
This transmission is intended for the named addressee(s) only and may contain sensitive or protectively marked material up to RESTRICTED and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us, including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
