Hello,
GeoNetwork's homepage http://geonetwork-opensource.org. has not been
reachable for several weeks. Any technical problems? Have you changed
adress?
Best regards
Jan
Hello,
adress?
Best regards
Jan
Hi Svensson,
It's a known problem and I believe they're planning on a fix sometime in
the future that includes a new webpage or something.
For now you can use:
http://sourceforge.net/projects/geonetwork/
http://trac.osgeo.org/geonetwork/
though they aren't as end-user oriented.
Jonathan
This transmission is intended for the named addressee(s) only and may contain sensitive or protectively marked material up to RESTRICTED and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us, including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
