I'm testing the connection from geonetwork to IBM-DB2.
I have create an explicit section for db2 with its connection settings in
the
config.xml file
And after I have put the sql script to create the tables in the
classes/setup/sql/create
path
naming it as
create-db-db2.sql
But I don't find how to connect this file to the
db2 section in the config.xml to use this instead of using the default
scripts.
I think there is some other setting I don't know.
Any help is welcome
Thx,
Andrea Peri
qwerty àèìòù
