there is available in GeoNetwork a GET request to have an xml with the list
of all published metadata ?
Thx
Andrea Peri
qwerty àèìòù
Thx
Andrea Peri
qwerty àèìòù
I use to put this URL in the browser:
http://localhost:8080/geonetwork/srv/eng/xml.search<http://172.23.5.72/geonetwork/srv/eng/xml.search>
It returns all the metadata. You can even detail your search as in
http://geonetwork-opensource.org/manuals/2.10.2/eng/developer/xml_services/metadata_xml_search_retrieve.html
In the linux shell I use this command:
wget -v --post-file=./search_req.xml --header
"Content-type:application/xml"
And the search_req.xml is like this:
<request />
It returns the same result as putting the xml.search URL in the browser.
Best regards,
Alex
On Mon, Jan 13, 2014 at 3:29 AM, Andrea Peri <aperi2007@anonymised.com> wrote:
of all published metadata ?Thx
Andrea Peri
qwerty àèìòù
CenturyLink Cloud: The Leader in Enterprise Cloud Services.
Learn Why More Businesses Are Choosing CenturyLink Cloud For
Critical Workloads, Development Environments & Everything In Between.
Get a Quote or Start a Free Trial Today.http://pubads.g.doubleclick.net/gampad/clk?id=119420431&iu=/4140/ostg.clktrk
GeoNetwork-users mailing list
Hi Lopes,
thx for you kindly help.
Is exactly was I was searching for.
Study-ing it I see the response return some fields, but don't return the Title (from identification->citation->title) of metadata.
Surely the UUID is a good information to help retrieve the right metadata, but I guess almost the title could be useful, and perhaps also the abstract should be usefult have them in the response.
I read the documentation, but don't find any info on this.
As you know:
is possible tohave in the response also this two information:
title and abstract adding some parameter to the request,
or is possible to have the response customizing the right xslt ?
Many thx.
Andrea.
On 13/01/2014 16:35, Alex Lopes wrote:
I use to put this URL in the browser: http://localhost:8080/geonetwork/srv/eng/xml.search <http://172.23.5.72/geonetwork/srv/eng/xml.search>
It returns all the metadata. You can even detail your search as in http://geonetwork-opensource.org/manuals/2.10.2/eng/developer/xml_services/metadata_xml_search_retrieve.html.
wget -v --post-file=./search_req.xml --header "Content-type:application/xml" http://172.23.5.72/geonetwork/srv/eng/xml.searchAnd the search_req.xml is like this:
<request />It returns the same result as putting the xml.search URL in the browser.
Best regards,
AlexOn Mon, Jan 13, 2014 at 3:29 AM, Andrea Peri <aperi2007@anonymised.com <mailto:aperi2007@anonymised.com>> wrote:
the list
Andrea Peri
qwerty àèìòù
<mailto:GeoNetwork-users@lists.sourceforge.net>
Hi
Possibly you can use also rss.search service, similar query parameters as
xml.search and returns a xml document that has title, abstract and some
other information about the metadata.
Jose García
On Fri, Jan 17, 2014 at 9:02 AM, aperi2007 <aperi2007@anonymised.com> wrote:
Hi Lopes,
the abstract should be usefult have them in the response.I read the documentation, but don't find any info on this.
As you know:
or is possible to have the response customizing the right xslt ?Many thx.
Andrea.
> <request />
> Best regards,
> Alex
> Hi,
> the list
> Thx
> Andrea Peri
> qwerty àèìòù
* GeoCat Bridge for ArcGIS allows instant publishing of data and metadata
on GeoServer and GeoNetwork. Visit http://geocat.net
<http://geocat.net/> for details. _________________________Jose
GarcíaGeoCat bvVeenderweg 13 6721 WD BennekomThe
Netherlandshttp://GeoCat.net/> *
Hi Andrea,
I'm sure the rss.search works because Mr. Garcia is an expert on Geonetwork.
Although, I would like to share to the community my solution to do a batch
retrieve of Geonetwork metadata using linux shell commands.
1) Do a xml.search and find all the metadata you need. The following
example does it.
wget -v --post-file=../req.xml --header "Content-type:application/xml"
The simplest req.xml is:
<request />
2) Step 1 returns an xml file with several fields for each metadata. One of
the fields is the uuid. Then, use an xslt processor to create xml request
files for each metadata. Each xml request file should look like this:
<request xmlns:geonet="http://www.fao.org/geonetwork">
<format>full</format>
<uuid>3200ecaa-4226-461a-af6f-6eca989a6cb2</uuid>
</request>
I use saxonb on ubuntu, with this command:
saxonb-xslt -ext:on -s:../xml.search_result -xsl:../template.xsl
My the template.xls contains is this:
<?xml version="1.0" encoding="ISO-8859-1"?>
<xsl:stylesheet xmlns:xsl="http://www.w3.org/1999/XSL/Transform"
version="2.0"
xmlns:geonet="http://www.fao.org/geonetwork" >
<xsl:output method="xml" indent="yes" name="xml"/>
<xsl:template match="metadata">
<xsl:result-document href="metadata{position()}" format="xml">
<request>
<uuid>
<xsl:value-of select="geonet:info/uuid"/>
</uuid>
</request>
</xsl:result-document>
</xsl:template>
</xsl:stylesheet>
This commands generate as many xml files as the number of metadata in the
response file xml.search_result. Each one look like this:
</request>
3) Now, just do a xml.metadata.get request passing this file as parameter.
wget -v --post-file=./data/metadata_req --header
http://localhost:8080/geonetwork/srv/eng/xml.metadata.get
The result will contain the abstract and the title you wanted.
Then, I combined all of this in a script shell.
I guess there might be an elegant way to do it. But it does the job.
(Mr. Garcia), any improvement in such procedure would still be useful...
Best regards,
Alex Lopes Pereira
On Fri, Jan 17, 2014 at 4:09 AM, Jose Garcia <jose.garcia@anonymised.com> wrote:
Hi
other information about the metadata.Regards,
Jose GarcíaOn Fri, Jan 17, 2014 at 9:02 AM, aperi2007 <aperi2007@anonymised.com> wrote:
Hi Lopes,
As you know:
Andrea.
> <http://172.23.5.72/geonetwork/srv/eng/xml.search>>
> <request />
> Best regards,
> Alex
> Hi,
> the list
> Thx
> Andrea Peri
> qwerty àèìòù
Between.
> <mailto:GeoNetwork-users@lists.sourceforge.net>> https://lists.sourceforge.net/lists/listinfo/geonetwork-users
http://sourceforge.net/projects/geonetwork--
Hi Jose,
thx for your solution.
Try-ing it I found perhaps a little bug.
Infact the parsing for the link will produce a wrong link.
The link was wrong because our front-end will do a redirect forward the
application-server.
So the link it give is like this:
http://urlto-the-server/geonetwork?uuid=2183d4c9-4149-425a-bc16-7153f5085983
And seem to miss a / . The right url should be this:
http://urlto-the-server/geonetwork/?uuid=2183d4c9-4149-425a-bc16-7153f5085983
I guess this is a wrong build in a xslt.
2014/1/17 Jose Garcia <jose.garcia@anonymised.com>
Hi
Hi Lopes,
As you know:
Andrea.
> <request />
> Best regards,
> Alex
> Hi,
> the list
> Thx
> Andrea Peri
> qwerty àèìòù
Between.
Andrea Peri
qwerty àèìòù
Hi Alex
Related to the method you propose, should work fine, but I you can get get
similar results with less http requests using CSW GetRecords.
A request like the following:
<?xml version="1.0"?>
<csw:GetRecords xmlns:csw="http://www.opengis.net/cat/csw/2.0.2"
xmlns:gmd="http://www.isotc211.org/2005/gmd" service="CSW"
version="2.0.2"
resultType="results">
<csw:Query typeNames="gmd:MD_Metadata">
<csw:ElementSetName>*full*</csw:ElementSetName>
<csw:Constraint version="1.1.0">
<Filter xmlns="http://www.opengis.net/ogc" xmlns:gml="
http://www.opengis.net/gml"/>
</csw:Constraint>
</csw:Query>
</csw:GetRecords>
Should return csw:Record in full format (if need less information can try
with brief or summary values in csw:ElementSetName).
Or if require the original xml documents instead of csw:Record in results:
version="2.0.2"
resultType="results" *outputSchema="http://www.isotc211.org/2005/gmd
<http://www.isotc211.org/2005/gmd>"\*>
<csw:ElementSetName>full</csw:ElementSetName>
</csw:Constraint>
</csw:Query>
</csw:GetRecords>
Jose García
On Fri, Jan 17, 2014 at 2:24 PM, Alex Lopes <alexlopespereira@anonymised.com>wrote:
Hi Andrea,
Geonetwork.Although, I would like to share to the community my solution to do a batch
retrieve of Geonetwork metadata using linux shell commands.--------------
example does it.
http://localhost:8080/geonetwork/srv/eng/xml.searchThe simplest req.xml is:
<request />--------------
of the fields is the uuid. Then, use an xslt processor to create xml
request files for each metadata. Each xml request file should look like
this:
</request>I use saxonb on ubuntu, with this command:
saxonb-xslt -ext:on -s:../xml.search_result -xsl:../template.xslMy the template.xls contains is this:
version="2.0"
<request>
<uuid>
</uuid>
</request>
</xsl:template>
</xsl:stylesheet>This commands generate as many xml files as the number of metadata in the
</request>-----------
http://localhost:8080/geonetwork/srv/eng/xml.metadata.getThe result will contain the abstract and the title you wanted.
---------------------------------I guess there might be an elegant way to do it. But it does the job.
Best regards,
Alex Lopes PereiraOn Fri, Jan 17, 2014 at 4:09 AM, Jose Garcia <jose.garcia@anonymised.com>wrote:
Hi
Hi Lopes,
As you know:
Andrea.
> <request />
browser.
> Best regards,
> Alex
> Hi,
> the list
> Thx
> Andrea Peri
> qwerty àèìòù
Between.
I'm try to use the csw to do the request,
but I see it will return exactly 100 records.
I try to add to the request a parameter to up the limit to 100.000 records
(a really huge value) ,
bit it seem tdon't used.
The geonetwork csw return always 100 records.
service="CSW" version="2.0.2"
maxRecords="100000"
Any hints ?
Thx,
Andrea.
2014-01-22 Jose Garcia <jose.garcia@anonymised.com>
Hi Alex
similar results with less http requests using CSW GetRecords.A request like the following:
version="2.0.2"
</csw:Constraint>
</csw:Query>
</csw:GetRecords>Should return csw:Record in full format (if need less information can try
with brief or summary values in csw:ElementSetName).Or if require the original xml documents instead of csw:Record in results:
version="2.0.2"
</csw:Constraint>
</csw:Query>
</csw:GetRecords>Regards,
Jose GarcíaOn Fri, Jan 17, 2014 at 2:24 PM, Alex Lopes <alexlopespereira@anonymised.com>wrote:
Hi Andrea,
batch retrieve of Geonetwork metadata using linux shell commands.--------------
example does it.
this:
version="2.0"
<request>
<uuid>
</uuid>
</request>
</xsl:template>
Best regards,
Hi
as xml.search and returns a xml document that has title, abstract and some
Hi Lopes,
As you know:
Andrea.
> <request />
browser.
> Best regards,
> Alex
> Hi,
> the list
> Thx
> Andrea Peri
> qwerty àèìòù
Between.
metadata on GeoServer and GeoNetwork. Visit http://geocat.net
Netherlandshttp://GeoCat.net/> *--
Andrea Peri
qwerty àèìòù
