[GeoNetwork-users] How to add a new site for seach metadata
hi
I have to import metadata with an other geonetwork.
I have editing my source.xml but i have not result.
Can you help me please?
Hi Jerome, sources.xml is only used to set the logo and link for metadata you
harvested from another node i guess.
If you want to query nodes using "remote search" you need to set up the node
in repositories.xml and check that there's no firewall issues regarding ports
used.
Which version are you using ? Do you want to do remote query, or harwesting
metadata from one node to yours ?
HTH.
Francois
Office International de l'EAU
Web : http://www.oieau.fr
---------- Original Message -----------
From: "jerome seigneuret" <gglafouine@anonymised.com>
To: geonetwork-users@lists.sourceforge.net
Sent: Tue, 10 Jul 2007 18:19:04 +0100
Subject: [GeoNetwork-users] How to add a new site for seach metadata
hi
This SF.net email is sponsored by DB2 Express
Download DB2 Express C - the FREE version of DB2 express and take
control of your XML. No limits. Just data. Click to get it now.
http://sourceforge.net/powerbar/db2/
GeoNetwork-users mailing list
------- End of Original Message -------
Re-
Basically, you could search in remote node in all version. 2 ways to do that :
- using Z39.50 remote search : configuration occurs in repositories.xml but
main problem is that firewalls and other network stuff could block some ports
(usually 2100), Remote search are usually not so fast.
- using xml synchronisation : metadata are harvested on a regular basis (days,
week, ....) from the remote node. If changes occur on the remote node, on the
next sync it will be updated (configuration for that is in config.xml for
2.0.3 or in the web admin interface for 2.1beta)
Personnaly, i really prefer the second option... it works great and in the
coming release, it's really easy to add a new node (thanks Andrea :).
For example, we have a node for the meditaranean area using xml sync between 3
or 4 nodes http://81.255.115.229:8080/medwip/. It works with the Sandre catalog .
FAO node use that option a lot I think also.
If you want more info on how to config, feel free to ask on the list.
Cheers. Francois
To: "François-Xavier PRUNAYRE" <fx.prunayre@anonymised.com>
Sent: Wed, 11 Jul 2007 11:23:07 +0100
Subject: Re: [GeoNetwork-users] How to add a new site for seach metadata
Bonjour François-Xavier et merci de m'avoir répondu.
j'avais déjà configuré le repositories.xml
A la CCI on utilise la version 2.03. Si il faut que je change de version je
le ferai mais en effet je cherche à pouvoir faire une recherche sur deux
geonetwork en notre possession (IDS du Gers, Infoagri et celui du Projet
GRISI) voir la possibilité de faire des recherches sur les serveurs de sandre
etc.
ps: appaemment je n'ai pas la possibilité de faire des recherches à distance
avec ma version
je dois surement avoir à modifier le main.xsl
pouvez vous m'éclairer?
___________________
Jérôme Seigneuret
CCI du Gers
http://ids.gers.cci.fr/geonetworkgers
___________________
2007/7/11, François-Xavier PRUNAYRE < fx.prunayre@anonymised.com>:Hi Jerome,
used.
HTH.
Francois
> hi
