[GeoNetwork-users] How to add a WMS layer by default on Map (Geonetwork 3.0.1)
I need configure WMS layers by default of my geoserver on Map the Geonetwork
3.0.1 installation. How do it??
Start the map and on the section "ManageLayers", the layers load by default,
view the following image
<http://osgeo-org.1560.x6.nabble.com/file/n5248566/managelayers.png&gt;
I try with json in settings, but not work.
{"viewerMap":"../../map/config-viewer.xml","listOfServices":{"wms":["http://192.168.11.82:8080/geoserver/wms?&quot;\],"wmts":},"useOSM":true,"context":"","layer":{"url":"http://192.168.11.82:8080/geoserver/wms&quot;,&quot;layers&quot;:&quot;add:coberturas\_bo\_2009\_2010&quot;,&quot;version&quot;:&quot;1\.1\.1&quot;\},"projection":"EPSG:3857","projectionList":[{"code":"EPSG:4326","label":"WGS84
(EPSG:4326)"},{"code":"EPSG:3857","label":"Google mercator (EPSG:3857)"}]}
Thanks.
View this message in context: http://osgeo-org.1560.x6.nabble.com/How-to-add-a-WMS-layer-by-default-on-Map-Geonetwork-3-0-1-tp5248566.html
Do you want it as a background layer or a simple layer ?
I think this is depecrated, i need to check.
But usually, everything is managed through the default OWS Context.
Geonetwork
default,
?"],"wmts":},"useOSM":true,"context":"","layer":{"url":"
","layers":"add:coberturas_bo_2009_2010","version":"1.1.1"},"projection":"EPSG:3857","projectionList":[{"code":"EPSG:4326","label":"WGS84
Thanks.
Site24x7 APM Insight: Get Deep Visibility into Application Performance
APM + Mobile APM + RUM: Monitor 3 App instances at just $35/Month
Monitor end-to-end web transactions and take corrective actions now
Troubleshoot faster and improve end-user experience. Signup Now!
http://pubads.g.doubleclick.net/gampad/clk?id=267308311&iu=/4140
GeoNetwork-users mailing list
geonetwork-users List Signup and Options
GeoNetwork - Geographic Metadata Catalog download | SourceForge.net
*camptocamp*
INNOVATIVE SOLUTIONS
BY OPEN SOURCE EXPERTS
*Florent Gravin*
0479444492
Hi Florent
I need it as a single layer. For example in Geonetwork 2.10.4 configured
this:
<http://osgeo-org.1560.x6.nabble.com/file/n5248669/overlay.png&gt;
It works...
On Geonetwork 3.0.1 I modify "config-viewer.xml" but not works
Help me...
Thanks...
View this message in context: http://osgeo-org.1560.x6.nabble.com/How-to-add-a-WMS-layer-by-default-on-Map-Geonetwork-3-0-1-tp5248566p5248669.html
In the viewer, go in Maps/Load default map to load the context you have
changed.
Otherwise, the context come from the localStorage
On Wed, Feb 3, 2016 at 2:57 PM, cbeltran <cbeltran@anonymised.com> wrote:
Hi Florent
this:
It works...
Help me...
Thanks...
*camptocamp*
*Florent Gravin*
0479444492
This is working for me (you can change group so that it is not in background
layers group):
<ows-context:Layer name="0"
                       group="Background layers"
                       hidden="false"
                       opacity="1">
      <ows:Title>DOF5</ows:Title>
      <ows-context:Server service="urn:ogc:serviceType:WMS">
        <ows-context:OnlineResource
xlink:href="http://copernicus.discomap.eea.europa.eu/arcgis/services/GioLandPublic/EU_DEM/MapServer/WmsServer&quot;
xmlns:xlink="http://www.w3.org/1999/xlink&quot;/&gt;
      </ows-context:Server>
    </ows-context:Layer>
View this message in context: http://osgeo-org.1560.x6.nabble.com/How-to-add-a-WMS-layer-by-default-on-Map-Geonetwork-3-0-1-tp5248566p5249056.html
