[GeoNetwork-users] How to add cgi-bin based web application in GeoNetwok's jetty web server.
Hello.
I've created following fragments in jetty.xml of
GeoNetwrok running on windows xp professional.
  <Call name="addWebApplication">
    <Arg>/test</Arg>
    <Arg>../web/test</Arg>
  </Call>
And I created following web.xml in "web\test" directory.
<web-app xmlns="http://java.sun.com/xml/ns/j2ee&quot;
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance&quot;
xsi:schemaLocation="http://java.sun.com/xml/ns/j2ee
http://java.sun.com/xml/ns/j2ee/web-app_2_4.xsd&quot;
version="2.4">
  <display-name>cgi-bin test</display-name>
        <servlet>
                 <servlet-name>CGI</servlet-name>
<servlet-class>org.mortbay.servlet.CGI</servlet-class>
                 <load-on-startup>1</load-on-startup>
                 <init-param>
                            <param-name>Path</param-name>
<param-value>D:/ms4w/apache/cgi-bin/</param-value>
                 </init-param>
                 <init-param>
<param-name>ENV_SystemRoot</param-name>
<param-value>C:/windows</param-value>
                 </init-param>
                 <init-param>
<param-name>commandPrefix</param-name>
<param-value>php-cgi</param-value>
                 </init-param>
        </servlet>
        <servlet-mapping>
                 <url-pattern>/cgi-bin/*</url-pattern>
        </servlet-mapping>
        <welcome-file-list>
                 <welcome-file>index.html</welcome-file>
        </welcome-file-list>
  <session-config>
    <!-- 3 hours -->
    <session-timeout>180</session-timeout>
  </session-config>
</web-app>
However Jetty can't recognize this "test" directory and
run scripts under "test/cgi-bin".
And any other additional settngs reuired for GeoNetwork'
jetty?
Regards.
