[GeoNetwork-users] How to Add line break in the suplementary Information in metadata
I want to add large number of information to suplementary information in ISO
19139. I used the ISO 19139 metadata editor to fill the suplementary
information. I added each infomation in new line but when I view the
metadata in the normal view there was no line breaks, every thing had come
together like a paragraph. It is very deficult to read the information.
Therefore I want to view each information in new line in the normal view.
Please can any one advice, how to do this, what changes should be made,
where these changes should be made. I am using geonetwork 2.2
Thank You, Best Regrads.
View this message in context: http://n2.nabble.com/How-to-Add-line-break-in-the-suplementary-Information-in-metadata-tp3470289p3470289.html
Hi.
Is it possible to force id / name of this logo ? To obtain a more human friendly file name and id ?
What would happen if I change the siteId in settings table (and cadascade it in the metadata table, of course) ?
Date: Aug 18, 2009; 10:48pm
Author: pierre vernier
GeoNetwork users (http://n2.nabble.com/GeoNetwork-users-f2013074.html)
Hi, You have to put your new image in : ...\geonetwork\web\geonetwork\images\logos The name of this image has to be the same as the value of "siteID" (bottom right of page "About"). You can also find this value in your database (column "source" in table "metadata"). Pierre
    amrajah wrote:
    I am using geonetwork 2.2. I want to change defalut logo to my node logo. I found an old geonetwork customization tutorial but it explain about the earliar geonetwork version. In the geonetwork 2.2 it is different way to add a node logo. Please, could any one tell me how to change node logo in geonetwork 2.2. Thank You, Best Regards.
Free Forum - Powered by Nabble
Hello Maël,
2009/8/19 REBOUX Maël <M.REBOUX@anonymised.com>:
You could but the idea is to have unique identifier [1] for each
catalogues as for metadata records. The idea is to not to have
duplicates when harvesting information from one node to another. In
previous version of GeoNetwork, node id was a configuration option but
it has been change since 2.1 I think. I do not recommand to change it
if you plan to use harvesting or to be harvested by others using at
least GeoNetwork protocol.
Cheers. Francois
[1] http://en.wikipedia.org/wiki/Universally_Unique_Identifier
Let Crystal Reports handle the reporting - Free Crystal Reports 2008 30-Day
trial. Simplify your report design, integration and deployment - and focus on
what you do best, core application coding. Discover what's new with
Crystal Reports now. http://p.sf.net/sfu/bobj-july
GeoNetwork-users mailing list
We faced the same problem with our older metadata system (NMMR), and solved this with some XSLT that "guessed" when to the author intended to use whitespace for formatting.
It's something we want to add to Geonetwork, too.
I'll dig up this code and pass it on...
--Rich
Richard Fozzard, Computer Scientist
  Geospatial Metadata at NGDC: http://www.ngdc.noaa.gov/metadata
Cooperative Institute for Research in Environmental Sciences (CIRES)
Univ. Colorado & NOAA National Geophysical Data Center, Enterprise Data Systems 325 S. Broadway, Skaggs 1B-305, Boulder, CO 80305
Office: 303-497-6487, Cell: 303-579-5615, Email: richard.fozzard@anonymised.com
amrajah said the following on 08/18/2009 09:59 PM:
Hi Richard,
where can I find the code?
regards
Sarah
--Rich
Systems
ISO
come
30-Day
on
View this message in context: http://n2.nabble.com/How-to-Add-line-break-in-the-suplementary-Information-in-metadata-tp3470289p3742285.html
Sarah,
My code is in another, older metadata app we developed here at NOAA (the "NMMR"). I've not yet integrated it into Geonetwork. It shouldn't be too hard; just some copy/paste/test work to make sure it handles the way the jeeves engine in Geonetwork passes XML to the various XSL transforms.
You're the 3rd or 4th person to ask, so I had better get moving on this!
Jeroen, should this be made into an official "proposal", or is it simple enough to just do it, and offer the code to you guys for committing?
Thanks for the interest,
--Rich
Sarah_S said the following on 09/30/2009 06:13 AM:
Hi Richard,
regards
Sarah
--Rich
ISO
come
30-Day trial. Simplify your report design, integration and deployment - and focus
on what you do best, core application coding. Discover what's new with Crystal Reports now. http://p.sf.net/sfu/bobj-july
Hi Richard,
If it is just a small patch you could send that to the developer list and agree with one of us to integrate it into SVN. A proposal may then be an overkill. If it involves a whole range of files (XSLT, Java. ??) and you see a possible nasty side effect on other parts of the system, then I think you best write a proposal that gives more details.
Jeroen
On Oct 1, 2009, at 5:36 PM, Richard Fozzard wrote:
Sarah,
--Rich
Hi Richard,
regards
Sarah
--Rich
  Geospatial Metadata at NGDC: Index of /waf
Systems
ISO
come
30-Day
on
Crystal Reports now. Best Open Source Mac Front-Ends 2024
geonetwork-users List Signup and Options
GeoNetwork - Geographic Metadata Catalog download | SourceForge.net
Sounds good.
I don't think it will be many files, probably just XSLT. I'll let you all know more when I know more. :slight_smile:
--Rich
Jeroen Ticheler said the following on 10/02/2009 08:54 AM:
Hi Richard,
Jeroen
Sarah,
--Rich
Hi Richard,
regards
Sarah
--Rich
ISO
come
