I am using geonetwork 2.2. I want to change defalut logo to my node
logo. I found an old geonetwork customization tutorial but it explain about
the earliar geonetwork version. In the geonetwork 2.2 it is different way to
add a node logo. Please, could any one tell me how to change node logo in
geonetwork 2.2.
Thank You, Best Regards.
View this message in context: http://n2.nabble.com/How-to-add-new-node-logo-tp3464580p3464580.html
You have to put your new image in :
...\geonetwork\web\geonetwork\images\logos
The name of this image has to be the same as the value of "siteID" (bottom
right of page "About").
You can also find this value in your database (column "source" in table
"metadata").
Pierre
about the earliar geonetwork version. In the geonetwork 2.2 it is
different way to add a node logo. Please, could any one tell me how to
change node logo in geonetwork 2.2.
View this message in context: http://n2.nabble.com/How-to-add-new-node-logo-tp3464580p3468514.html
Thank You Very Much.
On Wed, Aug 19, 2009 at 2:18 AM, pierre vernier (via Nabble) <
ml-user+179737-1405889268@anonymised.com<ml-user%2B179737-1405889268@anonymised.com>
wrote:
Hi, You have to put your new image in :
...\geonetwork\web\geonetwork\images\logos The name of this image has to be
the same as the value of "siteID" (bottom right of page "About"). You can
also find this value in your database (column "source" in table "metadata").
Pierre
amrajah wrote:
I am using geonetwork 2.2. I want to change defalut logo to my node logo. I
found an old geonetwork customization tutorial but it explain about the
earliar geonetwork version. In the geonetwork 2.2 it is different way to add
geonetwork 2.2. Thank You, Best Regards.
View message @
To unsubscribe from How to add new node logo, click here< (link removed) >.
View this message in context: http://n2.nabble.com/How-to-add-new-node-logo-tp3464580p3470047.html
