[GeoNetwork-users] How to change default base layer in Geonetwork 3.0?
Hi Terry,
Usually this questions should go to the geoNetwork users mailing list:
https://lists.sourceforge.net/lists/listinfo/geonetwork-users. I am
redirecting your email to that mailing list to make sure all answers go
there, someone else may have the answer.
Now, have you tried changing the layers definition in the Settings admin
page? If you did, does the javascript console show any errors? Maybe it is
a projection issue?
On Fri, Sep 2, 2016 at 11:49 PM, Terry <terry.curran@anonymised.com> wrote:
Hi Maria,
You wrote on http://gis.stackexchange.com/questions/167743/ (Oct 27
2015 at 7:06):
"If you enter the administration console, you will find a field where you
can define the base layers (and projection and all the init configuration)
of the map.
More information on the GeoNetwork documentation:
http://geonetwork-opensource.org/manuals/trunk/eng/users/
customizing-application/search-ui/configdefault.html"
Now that MapQuest has changed the access, I need to change to OSM.
I have looked at your comments, the GN manual, and at Francois Prunayre's
comments, without success.
Is it possible to provide me some details as to how to do this? I am
reasonably competent to follow coding instructions, but I am not a
developer.
Thank you.
Terry Curran, P.Eng.
Sidney, BC Canada
[image: Avast logo] <https://www.avast.com/antivirus&gt;
This email has been checked for viruses by Avast antivirus software.
www.avast.com <https://www.avast.com/antivirus&gt;
