[GeoNetwork-users] How to check out the geonetwork2.4.2 source code using MyEclipse IDE
Now, I would like to check out the souce code of the geonetwork 2.4.2. And,
I tried to use the below TortoiseCVS settings, but didnot find the 2.4.2
version there. The latest version in CVS root is 2_1_ALPHA_1.
Protocol: Password server (:pserver:)
Protocol parameters:
Server: geonetwork.cvs.sourceforge.net
Port:
Repository folder: /cvsroot/geonetwork
User name: anonymous
How can I check out the latest source code of geonetwork 2.4.2 using IDE?
what's the CVS setting? Any response will be appreciated! Thank you all!
View this message in context: http://n2.nabble.com/How-to-check-out-the-geonetwork2-4-2-source-code-using-MyEclipse-IDE-tp3932745p3932745.html
Use SVN, not CVS.
The 2.4.2 release is at
https://geonetwork.svn.sourceforge.net/svnroot/geonetwork/tags/2.4.2.
Kind regards
Heikki Doeleman
On Mon, Nov 2, 2009 at 5:18 PM, anthonyM <owenfan0715@anonymised.com> wrote:
Port:
Come build with us! The BlackBerry(R) Developer Conference in SF, CA
is the only developer event you need to attend this year. Jumpstart your
developing skills, take BlackBerry mobile applications to market and stay
ahead of the curve. Join us from November 9 - 12, 2009. Register now!
http://p.sf.net/sfu/devconference
GeoNetwork-users mailing list
