Hi List,
How to install/deploy several csw servers (geonetwork) on one computer? Any help will be appreciated!
Tim
Hi Tim,
Just be careful with port number of each geonetwork instance and everything
will should be good.
I mean each instance of geonetwork must be accessible via a different port :
8080, 8081, 8082....
Moreover, if you use a mckoi database, you must change the database port too
(default one is 9157 I guess).
Another alternative could be to have one application server (i.e jetty or
tomcat) and rename each web-app of geonetwork in order to access each one
under the same port.
HTH,
ciao,
Mathieu
On Wed, Dec 9, 2009 at 12:46 AM, Anython M. <lanlandemlz@anonymised.com> wrote:
Hi List,
Tim------------------------------------------------------------------------------
Return on Information:
Google Enterprise Search pays you back
Get the facts.
http://p.sf.net/sfu/google-dev2dev
GeoNetwork-users mailing list
Dear Tim,
I am also trying to deploy two geonetwork services in a single server with
single port (8080) in tomcat servlet. Since you also have tried to do same.
Did you get any success and could you please share the information if you
succeed.
Thanks in advance.
Kiran
View this message in context: http://n2.nabble.com/How-to-deploy-several-geonetwork-servers-on-one-computer-tp4136355p4782321.html
