[GeoNetwork-users] How to deploy several geonetwork servers on one computer?
Hi Mathieu,
Thank you very much. Now, I want to used the sencond method you mentioned to host several instances. Do you mean just to modifiy the "geonetwork" file folder name, then copy to the "web" folder? Now, I am going to use mysql database as their backend databases. How to set their related databases separately?
Tim
------------------ Original ------------------
From: "Mathieu Coudert"<mathieu.coudert@...137...>;
Date: Wed, Dec 9, 2009 05:43 PM
To: "Anython M."<lanlandemlz@...702...>;
Cc: "geonetwork-users"<geonetwork-users@lists.sourceforge.net>;
Subject: Re: [GeoNetwork-users] How to deploy several geonetwork servers on one computer?
Hi Tim,
Just be careful with port number of each geonetwork instance and everything will should be good.
I mean each instance of geonetwork must be accessible via a different port : 8080, 8081, 8082....
Moreover, if you use a mckoi database, you must change the database port too (default one is 9157 I guess).
Another alternative could be to have one application server (i.e jetty or tomcat) and rename each web-app of geonetwork in order to access each one under the same port.
HTH,
ciao,
Mathieu
On Wed, Dec 9, 2009 at 12:46 AM, Anython M.. <lanlandemlz@...702...> wrote:
Hi List,
How to install/deploy several csw servers (geonetwork) on one computer? Any help will be appreciated!
Tim
Return on Information:
Google Enterprise Search pays you back
Get the facts.
http://p.sf.net/sfu/google-dev2dev
GeoNetwork-users mailing list
On Wed, Dec 9, 2009 at 9:00 PM, Anython M. <lanlandemlz@anonymised.com> wrote:
Hi Mathieu,
Yes, I do. Changing the name of the webapp, and also other references such
as index.html file and so on.
Only by configuring the config.xml file, and especially the resource part
with appropriates parameters. In order to access to your different databases
or schema.
<!-- mysql -->
<resource enabled="false">
<name>main-db</name>
<provider>jeeves.resources.dbms.DbmsPool</provider>
<config>
<user>admin</user>
<password>admin</password>
<driver>com.mysql.jdbc.Driver</driver>
<url>jdbc:mysql://$WEBSERVER_HOST/geonetwork</url>
<poolSize>10</poolSize>
<reconnectTime>3600</reconnectTime>
</config>
</resource>
Ciao,
Mathieu
Tim
*From: * "Mathieu Coudert"<mathieu.coudert@anonymised.com>;
*Date: * Wed, Dec 9, 2009 05:43 PM
*To: * "Anython M."<lanlandemlz@anonymised.com>;
*Cc: * "geonetwork-users"<geonetwork-users@lists.sourceforge.net>;
*Subject: * Re: [GeoNetwork-users] How to deploy several geonetwork
Hi Tim,
HTH,
ciao,
Mathieu
On Wed, Dec 9, 2009 at 12:46 AM, Anython M.. <lanlandemlz@anonymised.com>wrote:
Hi List,
Tim
Get the facts.
Hi Mathieu,
Thank you very much!
I copied one file folder of "geonetwork" and renamed as "airquality". Then, moved to the file folder named "web" in geonetwork program files, and changed something as below,
1.Configured the MYSQL database parameters (Set correctly because many metadata records displayed there after logging in )
2.Changed "/airquality/srv/en/main.home" into "/geonetwork/srv/en/main.home" in ...\web\airquality\index.html
Now, I run start-geonetwork.bat in WindowsXP. Many errors occured in command console (I think there are something needed to configure, I didnot do).
I can open the URL: http://localhost:8080/airquality and log in successfully. However, some buttons did not work such as "+" button to see the details of the metadata record.
Mathieu, do you think which files are needed to configure or change further?
Thanks for your help again!
Best Regards,
2009-12-15
Tim
发件人: Mathieu Coudert
发送时间: 2009-12-11 08:45:43
收件人: Anython M.
抄送: geonetwork-users
主题: Re: [GeoNetwork-users] How to deploy several geonetwork servers onone computer?
On Wed, Dec 9, 2009 at 9:00 PM, Anython M. <lanlandemlz@...702...> wrote:
Hi Mathieu,
Yes, I do. Changing the name of the webapp, and also other references such as index.html file and so on.
Only by configuring the config.xml file, and especially the resource part with appropriates parameters. In order to access to your different databases or schema.
<!-- mysql -->
<config>
<user>admin</user>
</config>
</resource>
Ciao,
Mathieu
Tim
Hi Tim,
HTH,
ciao,
Mathieu
Hi List,
Tim
Get the facts.
Hi List,
As Mathieu said,
Best Regards,
2009-12-15
Tim
收件人: Anython M.
Hi Mathieu,
<!-- mysql -->
<config>
<user>admin</user>
</config>
</resource>
Ciao,
Mathieu
Tim
Hi Tim,
HTH,
ciao,
Mathieu
Hi List,
Tim
Get the facts.
Hi List,
I still didn't resort this issue. Any detail steps to change the instance name successfully.
Thanks in advance!
Tim
On 2009/12/18 11:14, Anthony wrote:
Hi List,
As Mathieu said,
Best Regards,
2009-12-15
Tim
Date: 2009-12-11 08:45:43
To: Anython M.
Cc: geonetwork-users
Subject: Re: [GeoNetwork-users] How to deploy several geonetwork servers onone computer?
On Wed, Dec 9, 2009 at 9:00 PM, Anython M.<lanlandemlz@anonymised.com> wrote:
Hi Mathieu,
<!-- mysql -->
<config>
<user>admin</user>
</config>
</resource>
Ciao,
Mathieu
Tim
From: "Mathieu Coudert"<mathieu.coudert@anonymised.com>;
To: "Anython M."<lanlandemlz@anonymised.com>;
Hi Tim,
HTH,
ciao,
Mathieu
On Wed, Dec 9, 2009 at 12:46 AM, Anython M..<lanlandemlz@anonymised.com> wrote:
Hi List,
Tim
Get the facts.
This SF.Net email is sponsored by the Verizon Developer Community
Take advantage of Verizon's best-in-class app development support
A streamlined, 14 day to market process makes app distribution fast and easy
Join now and get one step closer to millions of Verizon customers
http://p.sf.net/sfu/verizon-dev2dev
