I’m using migrated database. Migration steps have been 3.0.2->3.0.4->3.2.0
I ran those three linked SQL inserts into settings table and it started working. Seems that it tries to validate the metadata by default if these rows are not available in the database. Anyway, it’s working now. Thanks!
Kai
Lähettäjä: Jose Garcia [mailto:jose.garcia@…444…]
Lähetetty: 10. lokakuuta 2016 14:31
Vastaanottaja: Koistinen Kai (MML) <kai.koistinen@...1538...>
Kopio: geonetwork-users@lists.sourceforge.net
Aihe: Re: [GeoNetwork-users] How to disable metadata validation?
Hi
Are you using a new database or is migrated from previous version?
For new database, I see the settings should be created: https://github.com/geonetwork/core-geonetwork/blob/develop/web/src/main/webapp/WEB-INF/classes/setup/sql/data/data-db-default.sql#L664-L666
Also, the 3.0.5 migration seem fine containing the settings: https://github.com/geonetwork/core-geonetwork/blob/develop/web/src/main/webapp/WEB-INF/classes/setup/sql/migrate/v305/migrate-default.sql, unless the upgrade process failed for any reason.
Can you verify if you have that settings in the database?
Jose García
On Mon, Oct 10, 2016 at 1:01 PM, Koistinen Kai (MML) <kai.koistinen@...1538...<mailto:kai.koistinen@…1538…>> wrote:
I have only the”Enable workflow for record created in the following groups” option available in the UI. I don’t have those 3 extra options that are visible in the PR that you linked.
Kai
Lähetetty: 10. lokakuuta 2016 13:45
Vastaanottaja: Koistinen Kai (MML) <kai.koistinen@...1538...<mailto:kai.koistinen@…1538…>>
Kopio: geonetwork-users@lists.sourceforge.net<mailto:geonetwork-users@lists.sourceforge.net>
Hi
In 3.0.x and 3.2.x was added this feature: https://github.com/geonetwork/core-geonetwork/pull/1659 , but by default should not do any validation for publishing. Check anyway the Settings described in the pull request.
Jose García
On Mon, Oct 10, 2016 at 12:15 PM, Koistinen Kai (MML) <kai.koistinen@...1538...<mailto:kai.koistinen@…1538…>> wrote:
I'm not able to publish any metadata in GN 3.2.0 because the metadata has some schema validation errors. I want to publish the metadata though it has some errors. Can I somehow disable automatic metadata validation in 3.2.0?
Best regards,
Kai Koistinen
Expert
National Land Survey of Finland / Finnish Geospatial Research Institute FGI
+358 40 487 9104<tel:%2B358%2040%20487%209104>
kai.koistinen@...1538...<mailto:kai.koistinen@…1538…><mailto:kai.koistinen@…1538…>
Check out the vibrant tech community on one of the world's most
engaging tech sites, SlashDot.org! http://sdm.link/slashdot
GeoNetwork-users mailing list
GeoNetwork-users@lists.sourceforge.net<mailto:GeoNetwork-users@lists.sourceforge.net>
Vriendelijke groeten / Kind regards,
Jose García
[https://www.geocat.net/wp-content/uploads/2015/07/GeoCat_small1.png\]<http://www.geocat.net/>
Veenderweg 13
6721 WD Bennekom
The Netherlands
T: +31 (0)318 416664<tel:+31318416664>
[https://www.geocat.net/wp-content/uploads/2015/07/facebook_24.png\]<https://www.facebook.com/geocatbv> [https://www.geocat.net/wp-content/uploads/2015/07/Twitter_icon.png\] <https://twitter.com/geocat_bv> [https://www.geocat.net/wp-content/uploads/2015/07/Google-plus-icon.png\] <https://plus.google.com/u/1/+GeocatNetbv/posts>
Please consider the environment before printing this email.
Jose García
Veenderweg 13
6721 WD Bennekom
The Netherlands
